Rep Power: 19 ![]() ![]() ![]() |
Salam,
svp j'ai besoin le schema de pin d'une calculateur symbol Siemens ems 3132 c'est urgent merci |
il ne a personne.........
#3 | |
Rep Power: 90 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Quote:
Fuel injection system petrol engine. ECU Siemens EMS-3132: 90-pin black. Contact Designation 01 - Office of the ignition coil cylinder 2.3 02 - Not used 03 - "Massa" 04 - Control solenoid valve purge adsorber 05 - Not used 06 - Not used 07 - Not used 08 - The Office "-" relay fan engine cooling system 09 - Signal lamp emergency coolant temperature 10 - Signal conditioner off 11 - Signal fuel 12 - Control signal 1 on the control of idling 13 - Alarm coolant temperature sensor 14 - Not used 15 - "Massa" absolute pressure sensor 16 - absolute pressure sensor signal 17 - Not used 18 - signal transducer pressure refrigerant 19 - Screen knock sensor 20 - Signal "+" knock sensor 21 - Not used 22 - Not used 23 - Not used 24 - signal transducer top dead center 25 - Not used 26 - Diagnostic connector line L 27 - Not used 28 - "Massa" 29 - "+" after the ignition 30 - "+" battery 31 - Not used 32 - Office of the ignition coil cylinder 1.4 33 - "Massa" 34 - Control signal light malfunctions of the system reduce the toxicity 35 - Not used 36 - Not used 37 - Not used 38 - Control signal "-" to switch the fan engine cooling system 39 - Control signal "-" on the relay coil samopitaniya ECU 40 - Not used 41 - Control signal 2 on the control of idling 42 - Control signal 3 on the regulator idling 43 - Signal "+" throttle position sensor 44 - signal lower oxygen sensor 45 - Alarm of the upper oxygen sensor 46 - Control signal "-" on the air conditioner compressor 47 - Not used 48 - Not used 49 - Signal "+" air temperature sensor 50 - Not used 51 - Not used 52 - Not used 53 - Alarm of speed 54 - Alarm sensor crankshaft rotation 55 - Not used 56 - Diagnostic connector line K 57 - Not used 58 - Alarm system with an anti-lock the engine start 59 - "-" control signal to the nozzle of the cylinder number 1 60 - "-" control signal to the nozzle of the cylinder number 3 61 - Not used 62 - Not used 63 - "-" control signal to the heater element of the upper oxygen sensor 64 - Not used 65 - "-" control signal to the heater element of the lower oxygen sensor 66 - "+" injectors 67 - Not used 68 - The Office "-" coil relay fuel pump 69 - Not used 70 - Signal tachometer 71 - Not used 72 - Control signal 4 by regulator idling 73 - "-" signal coolant temperature sensor 74 - "+" signal throttle position sensor 75 - "-" signal throttle position sensor 76 - "Massa" lower oxygen sensor 77 - "-" air temperature sensor 78 - "+" absolute pressure sensor 79 - "-" knock sensor 80 - "Massa" upper oxygen sensor 81 - Not used 82 - "+" control signal to the resistor of low speed electric fans engine cooling system 83 - "+" pressure sensor coolant 84 - Not used 85 - Signal "+" pressure sensor in the hydraulic steering system 86 - Not used 87 - Not used 88 - Not used 89 - "-" control signal to the nozzle of the cylinder number 4 90 - "-" control signal to the nozzle of the cylinder number 2 |
| Bookmarks |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| immo off clio 2 essence siemense ems 3132 urgent plz | auto diag | Immobilizer dumps/solutions | 6 | 12-23-2011 04:32 PM |
| immo off clio 1.2 ECU siemens EMS 3132 | auto diag | Immobilizer dumps/solutions | 4 | 03-01-2011 11:31 PM |
| Please immo off ems 3132 | BIMBA777 | Immobilizer dumps/solutions | 6 | 04-12-2010 05:56 PM |
| logan seimense 3132 probleme ECU | justinyours | Renault, Dacia, Nissan | 3 | 12-09-2009 02:39 PM |
