Vieux 24/07/2017, 15h34   #1
Simple
Avatar de Simple
Simple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud of
Par défaut XS Evolution Automatic Firmware up******
To make DiagBox check the VCI firmware and update if necessary,
Precaustion:
Copy or move all files (NOT folders) inside "C:\AWRoot\bin\Launcher" to a safe location before perfoming the following:
1- Download "Launcher.rar" from the link provided
2- Create a back-up of all (only) files inside "C:\AWRoot\bin\Launcher"
3- Extract all files into "C:\AWRoot\bin\Launcher" replacing/overwriting existing files.
3- Rename your preferred Firmware inside Launcher folder to APPLI.COM
4- Connect your XS Evolution VCI and wait until it is recognised
5- Launch DiagBox, it will check the VCI Firmware and update ONLY if necessary.
The update function can be disabled by setting "MAJ_COM=TRUE" to "MAJ_COM=FALSE" in "C:\AWRoot\bin\Launcher\ap.ini"
In case reverting to the original setting is needed,
1- Delete all files (only) inside "C:\AWRoot\bin\launcher".
2- Restore backed-up files back to their original state.
Note: Some users may be afraid that a damaging APPLI.COM may be included in a future update release. It does not matter if this is feasible or not, you can change AP.INI settings to disable firmware update after performing your desired update and put your mind at rest.
Simple !..
Type de fichier : txt Launcher_850.txt (1,2 Ko, 80 affichages)
Simple est déconnecté   Réponse avec citation
The Following 17 Users Say Thank You to Simple For This Useful Post:
adiago (24/07/2017), autodiagauto (28/09/2017), bebert1234 (28/09/2017), caroptimum (25/07/2017), DIAGAUTO33 (25/07/2017), elbomberos40 (17/04/2019), HDIV6 (11/12/2018), hichamdz128 (27/01/2018), kitty-hawk (08/08/2017), nounour10 (10/01/2020), octave (04/08/2017), pouettedu76 (24/07/2017), Roturbo (03/06/2018), samii1955 (27/07/2017), tatel (02/02/2018), Tidus97 (24/07/2017), tony60 (24/07/2017)
Vieux 24/07/2017, 19h48   #2
Simple
Avatar de Simple
I need to correct words Precaution and performing (miss-typed) and change the name of the Laubcher850.zip. To make posts accurate and concise..
Would the site Administrator grant me rights to make changes, or I will have to post on other sites first, until I am happy that post covers all member's concerns.
The Following 3 Users Say Thank You to Simple For This Useful Post:
adiago (24/07/2017), pouettedu76 (24/07/2017), samii1955 (27/07/2017)
AL4 Automatic Gearbox Software Simple Peugeot, Citroën 3 09/09/2015 01h07
boite automatic mercedes E 270 charifcharif Mercedes Benz 0 11/04/2015 15h19
phare automatic sur W203 Ecomouv Mercedes Benz 9 18/11/2014 19h34
PEUGEOT PPS 2000 LATEST 22.14 up****** to 23 version MAXIMUS1000 LEXIA, PP2000, DiagBox 1 16/03/2010 19h31
CITROEN xia 45 up******,,tested 100% MAXIMUS1000 LEXIA, PP2000, DiagBox 0 15/03/2010 16h21
Fuseau horaire GMT +1. Il est actuellement 06h03.
