S'inscrire | FAQ | Membres | Groupes sociaux | Donate | Recherche | Messages du jour | Marquer les forums comme lus |
18/11/2017, 21h19 | #1 |
Pouvoir de réputation: 20 |
Lexia & PP2000 update 8.50-8.55 (DiagBox v8.55)
The software provided and the procedures proposed are intended for personal, educational and experimental use to install DiagBox 8.xx related updates. I hold no responsibility for any illegal or improper usage. Carry out this procedure at your own risk.
Link is provided in the attachment for "APP_Update_850-855.exe". This is intended to update Lexia and PP2000 components of DiagBox 8.50, 8.53 or 8.54 to 8.55. Procedure: 1- Ensure you have a backup copy of the file "C:\AWRoot\bin\fi\APPDIAG.SYS" before you start. 2- Download and execute the appropriate file for your own setup. The process will copy all necessary files to the updt folder, it will then automatically kill all DiagBox associated processes to enable overwriting without conflicts. 3- Run DiagBox to start the update process and wait until DiagBox is operational. Close DiagBox and restart your computer to ensure all processes are running. Done..! you may run DiagBox as usual.. Notice that DiagBox version will change to 07.855 after the update.. Have fun! Regards, Simple. |
The Following 42 Users Say Thank You to Simple For This Useful Post: | abdel93 (19/11/2017), adiago (19/11/2017), AKDAN (14/01/2018), al1962 (19/10/2018), amine08 (13/04/2018), bej 974 (08/11/2018), bzkmatrix (14/01/2019), catley (19/10/2018), chafi (17/01/2018), colas (20/12/2017), DIAGAUTO33 (19/11/2017), dingo307 (19/11/2017), djslowrnb (20/11/2017), dounga (21/10/2018), elie (19/11/2017), Florian Doke (21/02/2018), frank-ebert (30/10/2018), franz93 (23/10/2018), gchx (16/08/2018), guyguy307 (18/11/2017), Ian995 (15/08/2018), indians42 (14/04/2018), k.emra (13/04/2018), kam306 (19/11/2017), lazizouille (21/01/2018), lounaisse (13/04/2018), mahfoud lichani (19/11/2017), mehdi1-1 (15/10/2018), Mer (11/08/2018), ouragh (02/11/2019), prinzo57 (18/11/2017), REDZONE31 (19/11/2017), Roturbo (27/04/2018), saidsaad (28/10/2018), saigne (14/03/2020), samii1955 (18/11/2017), tatel (08/02/2018), taxi5114 (19/05/2018), techtronic1 (19/11/2017), titic (31/10/2018), tony60 (18/11/2017), zenata (20/11/2017) |
19/11/2017, 01h21 | #2 |
Pouvoir de réputation: 28 |
salam aleycom merci
un petit thank ca fait pas de mal |
20/11/2017, 08h43 | #3 |
Pouvoir de réputation: 79 |
selem alikom chekran for the update
https://t.me/OMARZORO https://join.skype.com/invite/bvm0ebQDz78l |
20/11/2017, 10h49 | #4 |
ِوعليكم وعلى الجميع السلام
Enjoy.. Simple. |
13/04/2018, 07h45 | #5 |
Pouvoir de réputation: 16 |
merci thank
sonde clip interface peugeot citroen AUTEL MX 808 TS Launch CRP 429 |
15/08/2018, 18h35 | #7 |
Pouvoir de réputation: 0 |
Thank you Simple
Worked after a bit of messing Some reason my v7.83 had jre and not jre7 in the c\:APP\bin It failed to load SIM after updates 817 to 837 I deleted the jre folder and made new folder jre7 in that location Then loaded java 7 to that location and the SIM then loaded fine Cheers Simple keep up the good work |
The Following User Says Thank You to Ian995 For This Useful Post: | 2009mohrice (30/09/2018) |
15/08/2018, 18h46 | #8 |
Should of said I loaded all fine to 8.55
No problem |
19/10/2018, 08h05 | #9 |
Pouvoir de réputation: 6 |
merci pour cette update pack. la mise à jour s'est bien effectuée (diagbox 7.855 affiché), par contre en analysant les fichiers, j'ai l'impression que tout n'est pas mis à jour: dans C:\AWRoot\dtwr\updt\Appli\Extract\MajListe on retrouve les 3 updates non décompressées. et si je regarde un fichier d'un calculateur de véhicule au hasard provenant de ces archives, je ne le retrouve pas dans mon arborescence exemple: C:\AWRoot\dtwr\updt\Appli\Extract\MajListe\inter8_ 55.rar contient AWRoot\dtrd\tree\Vehicle\W2\AAS\AAS_UDS\W2_AAS_AAS _UDS_VARIANTE_CALCULATEUR.s, 38044 octets, date 12/09/2017 15:17 dans mon arborescence C:\AWRoot\dtrd\tree\Vehicle\W2\AAS\AAS_UDS\ le fichier en question date toujours du 24/06/2015 et fait 22543 octets je me trompe peut-être... mais peux tu quand même vérifier la bonne exécution de cette update ? merci |
19/10/2018, 13h55 | #10 |
En complément:
j'ai fait une analyse avec un comparateur de fichiers (WinMerge) entre l'arborescence de diagbox 8.55 (7.855) et le dossier updt\MAJDIST contenant les 3 archives inter8_53,54,55 décompressés. Il en ressort une grande différence de fichiers non à jour et/ou manquants. Est-ce normal ? Est-ce que @Simple pourrait corriger ? |
22/10/2018, 08h13 | #11 |
En 2ème complément:
J'ai discuté avec @Simple à propos de ces update pack: En fait il ne s'occupe que de mettre à jour la partie PP2000/Lexia. Il ne s'occupe pas de la partie Diagbox car il n'en a pas l'utilité (son véhicule personnel n'est que sous PP2000/Lexia). Donc lorsque l'on exécute ses packs, bien que la version de Diagbox soit incrémentée, cela ne met pas à jour les fichiers que Diagbox utilise. Donc peut-être que @MaitreSox ou une autre personne compétente pourrait se pencher sur ces mises à jour pour Diagbox... ? |
22/10/2018, 09h22 | #12 |
Pouvoir de réputation: 31 |
MaitreSox ne fait plus les mises à jour depuis un moment pour cause revente de ses updates .
Veuillez donner suite à votre diag et à la résolution du problème !! un petit merci ne coûte rien . |
The Following User Says Thank You to adiago For This Useful Post: | maitresox (22/10/2018) |
22/10/2018, 09h27 | #13 |
OK.
J'ai discuté également avec Maitresox et je comprend son point de vue. |
22/10/2018, 09h43 | #14 |
Pouvoir de réputation: 66 |
il a bossé pour se faire piquer sont boulot,rorry n´a pas fait la meme erreur
28/10/2018, 18h47 | #15 | |
Outils de la discussion | |
Lexia & PP2000 (from DiagBox 8.35) | Simple | LEXIA, PP2000, DiagBox | 63 | 25/11/2018 21h25 |
Diagbox pp2000 lexia | YomGui | Peugeot, Citroën | 35 | 16/06/2017 12h12 |
Lexia and PP2000 update without internet | scarymistake | LEXIA, PP2000, DiagBox | 0 | 14/01/2012 09h20 |
Lexia and PP2000 update without internet | reda75 | Peugeot, Citroën | 4 | 28/09/2010 12h31 |
Lexia and PP2000 update without internet | reda75 | Peugeot, Citroën | 2 | 06/09/2010 08h33 |
