Vieux 30/11/2016, 21h01   #1
Simple
Avatar de Simple
Simple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud of
Par défaut DiagBox 8.01 Installation (updated)
Installing DiagBox 8.01
This procedure and the software provided are intended for personal, educational and experimental use to install DiagBox 8.01 and related updates. I hold no responsibility for any illegal or improper usage. Carry out this procedure at your own risk.
Notice
- Links for all required software, updates and tools are in the attachments.
Preparation for Installing DiagBox 8.01 on Notebooks and VMWare Workstation
- Starting with any (32 bit) Windows preferably (XP or 7), install .NET 3.51 and Windows drivers or VMWare Tools (if on VMWare Workstation or Player).
Preparation for Installing DiagBox 8.01 on VirtualBox
- Having installed 32 bit Windows + VirtualBox Guest Additions + .NET 3.51, use the Powershell Command "Get-WMIObject win32_BIOS" or the "DMIdecode" tool to obtain BIOS information (not essential).
- Close VirtualBox and start an administrator's CMD, navigate to "C:\Program Files\Oracle\VirtualBox\" and execute the following command (Replacing "Your VM" with your Virtual Machine's name, and System Serial with your hardware's or any code or text such as "CDN29326BH"):
C:\Program Files\Oracle\VirtualBox>VBoxManage setextradata "Your VM" "VBoxInternal/Devices/pcbios/0/Config/DmiSystemSerial" "System Serial"
1- Install DiagBox 7.01 and restart DiagBox to run update 7.02. Install update 7.xx-7.57 (this will create "C:\AWRoot\dtwr\cfg\Config.sys").
2- Install "VC++ 2008 Redistributable Package", a copy will be available in "C:\teleassistance\visualC\vcredist_x86.exe" after installing DiagBox.
3- Restart the computer and use “Kill_DiagBox_Tasks.bat” to stop related processes and rename "C:\AWRoot" to "C:\AWRoot7"
4- Run DiagBox 8.01 installation (it will uninstall v7.xx first) until it requests Activation. Close it (X) and run the tool "AWRoot_v7_Conf+Ativation_v8.exe" it will copy configuration from "C:\AWRoot7\.." and inject the necessary files.
5- Run DiagBox again, it should continue the installation successfully.
Done !,
Restart DiagBox 8.01 as Administrator to confirm all is well (don't be concerned about the reported version and do not start Lexia or PP2000 yet). If you face an issue, run the activation tool again and/or review "Versions" below.
If DiagBox runs fine, ensure you keep a backup copy of the file “C:\AWRoot\bin\fi\APPDIAG.SYS” in a safe location.
Installing Updates
1- Download and install "DiagBox_updt_802.ISO" update.
2- Download and install subsequent v8.xx updates or Maitresox updates (from 7.66+).
Versions
The order of the version lines and which one is active in VERSION.INI is important for the correct running of the system. DiagBox will display 08.01 if set as shown below. But Lexia will NOT work with the line (version=08.xx) in "version.ini" (xx is the version number depending on which update is applied).
[APPLICATION]
version=08.01
version=07.65
If Lexia is started with "version=08.01" in Version.ini not commented, "APPDIAG.SYS" will be corrupted and it will need to be restored before DiagBox will work again. To operate Lexia (after starting DiagBox with 8.xx), edit "version.ini" and comment "version=08.xx" (by inserting ";" as shown below) and save BEFORE starting LEXIA.
Setting "version.ini" to 07.xx (by removing or commenting "version=8.xx" permanently) before starting DiagBox, will prompt DiagBox to report V 07.xx, but everything will work fine as version 8.xx..
[APPLICATION]
;version=08.08
version=07.72
Updates
- DiagBox v7 and v8 install and run on all x86 (32bit) Windows including 10 TH1, TH2, RS1 and RS2.
- Entering a System Serial for the Virtual Machine (as described above) resolves the "psaAagent.exe" and the missing tabs issue on VirtualBox.
- If you get "Error 2" after restarting DiagBox, try commenting "version=8.xx" in "version.ini" before restarting DiagBox again.
P.S. DiagBox has been running on Firmware 4.3.4 since 7.66/8.02.
Enjoy; Simple.
Type de fichier : txt DBox_8xx_Install_and_update.txt (1,3 Ko, 526 affichages)
Type de fichier : zip Kill_DiagBox_Tasks.zip (301 octets, 351 affichages)
Simple est déconnecté   Réponse avec citation
The Following 36 Users Say Thank You to Simple For This Useful Post:
2009mohrice (24/09/2018), alinjadii (20/12/2017), autodiagauto (29/11/2018), brahim chafa3 (28/01/2023), cracker563 (04/07/2020), dancostea20022 (13/03/2017), dart (28/08/2017), DIAGAUTO33 (24/11/2017), drissdiag (25/02/2018), electronico (16/12/2017), estwood68 (06/01/2018), fefjp (15/03/2020), hamiza (07/11/2017), Incisif (29/03/2019), indians42 (14/04/2018), joe1984 (20/05/2018), juju13fr (16/04/2018), karimseri (23/07/2019), KBK (05/01/2020), kilm (02/03/2018), mustaphcl (21/01/2018), Nextrick (13/03/2017), ouragh (20/02/2019), prodiag2017 (13/04/2018), prt93 (28/12/2019), raf68 (21/02/2020), Scanworld2020 (29/07/2018), starcrysis (01/03/2018), tatel (01/02/2018), taxi5114 (26/11/2017), Tidus97 (05/12/2017), transitforum (06/02/2019), Walid25 (07/04/2019), xavi5757 (28/02/2020), Y.B tec (01/03/2018), yvespapou (13/03/2017)
Vieux 29/01/2017, 04h02   #2
Simple
Avatar de Simple
It seems some people are packaging and selling Diagox 8.17. I guess I cannot complain, it already happened to maitresox before.
Here is the video (dated July 2016); it is ******ly quite good:
https://www.youtube.com/watch?v=100rbi5Ge20
The Following 2 Users Say Thank You to Simple For This Useful Post:
2009mohrice (24/09/2018), Walid25 (07/04/2019)
Vieux 29/01/2017, 08h20   #3
guyguy307
Avatar de guyguy307
Hello simple, this is a shame, people are idiots and thieves who do not recognize the fableful work you did. It must be denounced and stopped
The Following User Says Thank You to guyguy307 For This Useful Post:
Vieux 26/02/2017, 19h12   #4
kilm
Avatar de kilm
kilm has a brilliant futurekilm has a brilliant futurekilm has a brilliant futurekilm has a brilliant futurekilm has a brilliant futurekilm has a brilliant futurekilm has a brilliant futurekilm has a brilliant futurekilm has a brilliant futurekilm has a brilliant futurekilm has a brilliant future
Tout d'abord merci beaucoup à Simple pour son travail, et pour le partager gracieusement !
Je suis entrain de faire l'installation. J'en suis à la V08.02. Mais je ne suis pas doué en anglais et j'ai du mal à comprendre (même avec google translation) la partie du tuto qui a pour titre "Versions".
Apparemment il y a une modif à faire dans le fichier Version.ini mais je ne comprend pas laquelle. Quelqu'un pourrait m'éclairer ?
kilm est déconnecté   Réponse avec citation
The Following User Says Thank You to kilm For This Useful Post:
Vieux 26/02/2017, 22h38   #5
Simple
Avatar de Simple
For Lexia and PP2000 to work, version needs to be 07.xxx and NOT 08.xxx. Use this standard [version=07.Update#]. So after update 8.02 --> set version=07.802 and after 8.10 --> version=07.810 etc.
Basically, after the update and before starting DiagBox, set the "version.ini" file to :
[APPLICATION]
version=07.817
You can keep the version # the same (07.817) with all updates if you wish, it will work fine regardless..
Now, set the language of your choice through the menu while you are at update 8.02. Otherwise it will not be possible through the menu if you install later updates, and you will have to edit some other files.
The Following 3 Users Say Thank You to Simple For This Useful Post:
kilm (02/03/2018), Walid25 (07/04/2019), Y.B tec (01/03/2018)
Vieux 26/02/2017, 23h02   #6
kilm
Avatar de kilm
Merci beaucoup pour ta réponse. Je comprend mieux maintenant.
Il ne faut changer que le contenu du fichier "Version.Ini" ? Le fichier "Version" on ne modifie pas ?
J'ai déjà installé les mises à jour suivantes. Sans changer la langue. Mais à l'ouverture de Diagbox, sur la page d’accueil, je suis déjà en français. Je suppose que le reste du programme sera aussi en français ?
Dernière modification par kilm ; 26/02/2017 à 23h04.
Vieux 16/03/2017, 19h46   #7
kilm
Avatar de kilm
Je me répond à moi même si ça peut servir à d'autres
Envoyé par kilm Voir le message
Modifier que le fichier "Version.Ini" ça n'a pas suffit chez moi, en essayant d'ouvrir Lexia j'ai fait planter Diagbox, par contre en changeant le fichier "Version" aussi là ça passe bien.
Oui ! ^^
Merci encore à Simple.
The Following 3 Users Say Thank You to kilm For This Useful Post:
Nextrick (30/03/2018), Walid25 (07/04/2019), Y.B tec (01/03/2018)
Vieux 01/03/2018, 20h59   #8
guyguy307
Avatar de guyguy307
Salut update jusqu'a 7.82 ensuite fait mise a jour v8
Vieux 30/03/2018, 18h50   #9
Pouvoir de réputation: 249
salut cette version n'est pas stable
salut, j'ai installé la version de Simple sur un autre post ici sur TE diagbox 8.17 fonctionne bien il ne mets pas le vci a jour ! il detecte moin de calculateurs que 7.76 !! calculateurs inconu !!, mais sur un C8 j'ai eu besoin de lexia !, il s'ouvre me demande le DAM je le tape , il me met
"une erreur est survenue !"
" les outils s'ont maintenant désactivés "...
je relance diagbox il me demande de proceder a l'activation !!
je remplace l'app diag sys par un que j'avais sauvegardé , diagbox démarre activé , je relance lexia !! et pareil !! je vais devoir revenir en 7.76 ou 7.82
cette version n'est pas stable !
@ bon week end
diago2001 (06/11/2018)
TUTO installation diagbox ( détaillé ) Problème installation JOohns LEXIA, PP2000, DiagBox 3 03/01/2023 07h30
installation diagbox foulques LEXIA, PP2000, DiagBox 12 19/05/2014 16h30
Installation pas a pas DiagBox v. 7.1 papi68 Tutoriels 0 30/07/2013 23h07
installation diagbox 7.xx machin76 LEXIA, PP2000, DiagBox 7 20/06/2013 07h49
Fuseau horaire GMT +1. Il est actuellement 00h25.
