22/07/2022, 09h55 | #1 |
Pouvoir de réputation: 0 |
Rapport erreurs vcds
Quelqu'un pourrait jeter un coup d oeil sur le rapport d erreur et m indiquer les erreurs/défauts les plus importants/urgents a corriger ?? Passat b6 1.6tdi (fin 2010) Nb : la spirale des commandes du volant est cassée (plus de claxon, airbag...) https://pastebin.com/iUKCdJPw Merci ---------- Post added at 09h55 ---------- Previous post was at 09h53 ---------- Friday,22,July,2022,0944:39744 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 17.1.3.0 Data version: 20170203 DS267.2 www.Ross-Tech.com VIN: WVWZZZ3CZAP055312 License Plate: Mileage: 243570km-151347mi Repair Order: Chassis Type: 3C (3C0) Scan: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 4F 52 53 56 61 62 72 VIN: WVWZZZ3CZAP055312 Mileage: 243570km-151347miles 01-Engine -- Status: Malfunction 0010 03-ABS Brakes -- Status: Malfunction 0010 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 10-Park/Steer Assist -- Status: Malfunction 0010 15-Airbags -- Status: Malfunction 1010 16-Steering wheel -- Status: Malfunction 1010 17-Instruments -- Status: Malfunction 1010 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: Malfunction 0010 37-Navigation -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: Malfunction 0010 44-Steering Assist -- Status: Malfunction 0010 46-Central Conv. -- Status: Malfunction 0010 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: Malfunction 0010 53-Parking Brake -- Status: Malfunction 0010 56-Radio -- Status: OK 0000 61-Battery Regul. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CAYC) Labels: 03L-906-023-CAY.clb Part No SW: 03L 906 023 GL HW: 03L 906 023 A Component: 1,6l R4 CR td H23 9972 Revision: --H23--- Serial number: VWZCZ000000000 Coding: 00114036032401080000 Shop #: WSC 00028 028 00022 ASAM Dataset: EV_ECM16TDI02103L906023GL 003013 ROD: EV_ECM16TDI02103L906023GL_003.rod VCID: 76E43D9AC95C7DF1C3-8022 10 Faults Found: 7329 - Mass Air Flow Sensor (G70) P0101 00 [104] - Implausible Signal Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 94 Mileage: 241288 km Date: 2022.07.22 Time: 17:19:53 Engine speed: 1997.75 /min Normed load value: 0.0 % Vehicle speed: 54 km/h Coolant temperature: 99 °C Intake air temperature: 41 °C Ambient air pressure: 1000 mbar Voltage terminal 30: 13.553 V Unlearning counter according OBD: 40 Air mass: ****** value (mg/stroke)-MAF_MES: 346.45 mg/stroke Air mass proportion filtered-FAC_MAF_CYL_KGH_RATIO_FIL: 1.23651 EGR solenoid valve: ****** value-ANG_EGRV[0]: 0.000 % Throttle valve adapter: ****** value-ANG_THR[0]: 95.868 % Charge air pressure specified value-MAP_SP_MMV: 1139.45 hPa Charge air pressure: ****** value-MAP_MMV: 1139.45 hPa Engine torque-TQI_SP: 0.00 Nm 7391 - Fuel Pump Relay Control Circuit P0628 00 [032] - Short to Ground Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 242849 km Date: 2022.07.22 Time: 0036 Engine speed: 0.00 /min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 63 °C Intake air temperature: 39 °C Ambient air pressure: 1000 mbar Voltage terminal 30: 11.972 V Unlearning counter according OBD: 11 Engine speed: 0 /min Vehicle speed: 0 km/h Battery voltage: 12.0 V Fuel high pressure: ****** value-FUP_FIL: 0.000 MPa Fuel Metering Valve-VCV: 0.000 % Fuel Pressure Regulator Valve-PCV: 0.000 % 6056 - No Communications with HVAC Control Module (J301) U0164 00 [032] - - Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Mileage: 242849 km Date: 2022.07.22 Time: 0023 Engine speed: 0.00 /min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 63 °C Intake air temperature: 39 °C Ambient air pressure: 1000 mbar Voltage terminal 30: 11.972 V Unlearning counter according OBD: 11 Driver request torque-TQI_DRIV_SUB: 0.00 Nm Control Module temperature-TECU: 48 °C 6068 - No Communication with Instrument Cluster U0155 00 [032] - - Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 2 Mileage: 242849 km Date: 2022.07.22 Time: 0023 Engine speed: 0.00 /min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 63 °C Intake air temperature: 39 °C Ambient air pressure: 1000 mbar Voltage terminal 30: 11.972 V Unlearning counter according OBD: 11 Driver request torque-TQI_DRIV_SUB: 0.00 Nm Control Module temperature-TECU: 48 °C 7430 - No Communication with Diagnostic Gateway U0146 00 [032] - - Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Mileage: 242849 km Date: 2022.07.22 Time: 0023 Engine speed: 0.00 /min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 63 °C Intake air temperature: 39 °C Ambient air pressure: 1000 mbar Voltage terminal 30: 11.972 V Unlearning counter according OBD: 11 Driver request torque-TQI_DRIV_SUB: 0.00 Nm Control Module temperature-TECU: 48 °C 6082 - Steering Column Control Module U0212 00 [032] - No Communications Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Mileage: 242849 km Date: 2022.07.22 Time: 0023 Engine speed: 0.00 /min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 63 °C Intake air temperature: 39 °C Ambient air pressure: 1000 mbar Voltage terminal 30: 11.972 V Unlearning counter according OBD: 11 Driver request torque-TQI_DRIV_SUB: 0.00 Nm Control Module temperature-TECU: 48 °C 10231 - Valve for Fuel Metering (N290) P0090 00 [032] - Open Circuit Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 242849 km Date: 2022.07.22 Time: 0003 Engine speed: 0.00 /min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 63 °C Intake air temperature: 39 °C Ambient air pressure: 1000 mbar Voltage terminal 30: 11.972 V Unlearning counter according OBD: 11 Battery voltage: 12.0 V Valve for fuel metering: feedback value measured-CFB_VCV_MES: 0.076 A Voltage equivalent of valve for fuel metering-VP_CFB_VCV: 3.2877 V Fuel pressure regulator valve: specified value rail pressure-LV_PCV_CTL: 00000000 Fuel Pressure Regulator Valve-PCV: 0.000 % Fuel Metering Valve-VCV: 0.000 % Fuel high pressure: ****** value-FUP_FIL: 0.000 MPa 10113 - Fuel Pressure Regulator Valve (N276) P2294 00 [032] - Open Circuit Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 242849 km Date: 2022.07.22 Time: 0003 Engine speed: 0.00 /min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 63 °C Intake air temperature: 39 °C Ambient air pressure: 1000 mbar Voltage terminal 30: 11.972 V Unlearning counter according OBD: 11 Battery voltage: 12.0 V Fuel pressure regulator valve ****** value-CFB_PCV_MES: 0.076 A Voltage equiv. current of regulating valve for fuel pressure-VP_CFB_PCV: 3.2877 V Fuel pressure regulator valve: specified value rail pressure-LV_PCV_CTL: 00000000 Fuel Pressure Regulator Valve-PCV: 0.000 % Fuel Metering Valve-VCV: 0.000 % Fuel high pressure: ****** value-FUP_FIL: 0.000 MPa 9875 - Boost Pressure Control Valve/Solenoid (Bank 1) P0047 00 [032] - Short to GND Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 242849 km Date: 2022.07.22 Time: 0028 Engine speed: 0.00 /min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 63 °C Intake air temperature: 39 °C Ambient air pressure: 1000 mbar Voltage terminal 30: 12.085 V Unlearning counter according OBD: 11 Charge Pressure Actuator: acknowledgment-ANG_BPA[0]: 10.626 % Charge Pressure Actuator: activation-ANG_SP_BPA[0]: 20.000 % High press turbocharger actuator: ****** uncond volt value-V_BPA[0]: 0.674 V Turbocharger boost control: offset open-V_BPA_BOL[0]: 0.498 V Turbocharger boost control: offset -V_BPA_TOL[0]: 3.330 V Charge air pressure: ****** value-MAP_MMV: 200.00 hPa Sensor for temp after charge air cooler: raw value-TBA_MES: 39 °C 10123 - ECM Power Relay Control Circuit P0685 00 [032] - Open Circuit Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 242849 km Date: 2022.07.22 Time: 00:19:13 Engine speed: 0.00 /min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 63 °C Intake air temperature: 39 °C Ambient air pressure: 1000 mbar Voltage terminal 30: 0.000 V Unlearning counter according OBD: 11 Battery voltage: 0.0 V Voltage terminal 15-V_IGK: 12.1 V Starter control: Start interruption status-Binary 16 Bit: 00011001 00000000 Fuel pressure regulator valve ****** value-CFB_PCV_MES: 0.067 A Valve for fuel metering: feedback value measured-CFB_VCV_MES: 0.057 A Readiness: 1100 0000 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb Part No SW: 3C0 614 109 AK HW: 3C0 614 109 AK Component: J104 C4 440 V2 0027 Revision: --025--- Serial number: 00000705619431 Coding: 0035311 Shop #: WSC 00028 790 00002 VCID: 67DA60DE56F6947948-8032 8 Faults Found: 00576 - Terminal 15 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 2 Reset counter: 104 Mileage: 242848 km Time Indication: 0 Date: 2016.12.12 Time: 18:30:15 Freeze Frame: Speed: 0.0 km/h Hex Value: 0x0000 Bin. Bits: 00000000 00000000 Voltage: 12.00 V Bin. Bits: 00111110 Count: 123 Hex Value: 0x0000 01309 - Power Steering Control Module (J500) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 2 Reset counter: 104 Mileage: 242848 km Time Indication: 0 Date: 2016.12.12 Time: 18:30:15 01321 - Control Module for Airbags (J234) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 104 Mileage: 242848 km Time Indication: 0 Date: 2016.12.12 Time: 18:34:52 Freeze Frame: Speed: 0.0 km/h Hex Value: 0x0000 Bin. Bits: 00000000 00000000 Voltage: 12.00 V Bin. Bits: 00011111 Count: 191 Hex Value: 0x0000 01317 - Control Module in Instrument Cluster (J285) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 104 Mileage: 242848 km Time Indication: 0 Date: 2016.12.12 Time: 18:34:52 01200 - ABS Valves Supply Voltage 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 1 Fault Frequency: 1 Reset counter: 104 Mileage: 242849 km Time Indication: 0 Date: 2016.12.12 Time: 0020 Freeze Frame: Speed: 0.0 km/h Hex Value: 0x0000 Bin. Bits: 00000000 00000000 Voltage: 3.00 V Bin. Bits: 00011111 Count: 64 Hex Value: 0x0000 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 1 Fault Frequency: 1 Reset counter: 104 Mileage: 242849 km Time Indication: 0 Date: 2016.12.12 Time: 0020 01299 - Diagnostic Interface for Data Bus (J533) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 104 Mileage: 242849 km Time Indication: 0 Date: 2016.12.12 Time: 0024 Freeze Frame: Speed: 0.0 km/h Hex Value: 0x0000 Bin. Bits: 00000000 00000000 Voltage: 12.00 V Bin. Bits: 00011111 Count: 192 Hex Value: 0x0000 00474 - Control Module for Immobilizer 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 104 Mileage: 242849 km Time Indication: 0 Date: 2016.12.12 Time: 0024 ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb Part No SW: 5K0 907 044 BS HW: 5K0 907 044 BS Component: Climatronic H15 0709 Revision: 00003001 Coding: 0000000003 Shop #: WSC 00028 028 00022 ASAM Dataset: EV_Climatronic A01006 ROD: EV_ClimaAutoBasis_VW36.rod VCID: 7DF622B6EC6A2EA982-8028 3 Faults Found: 13701376 - Function Restricted due to Missing Message(s) U1111 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 2 Reset counter: 104 Mileage: 242849 km Date: 2022.07.22 Time: 0055 13701408 - Function Restricted due to Missing Message(s) U1111 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 104 Mileage: 242849 km Date: 2022.07.22 Time: 0023 13701456 - Function Restricted due to Missing Message(s) U1111 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 2 Reset counter: 104 Date: 2022.07.22 Time: 1856 ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl Part No SW: 3C8 937 049 AB HW: 3C8 937 049 AB Component: Bordnetz-SG H57 3204 Revision: 00H57000 Serial number: 00000003798256 Coding: E1900F0700041A00470A00000F00000000015D435C00012000 0308000000 Shop #: WSC 00028 028 00001 VCID: 71EE0E8668325AC916-FFFE Subsystem 1 - Part No: 3C1 955 419 B Labels: 1KX-955-119.CLB Component: Wischer 270410 006 0208 Coding: 00046997 Shop #: WSC 00028 Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB Component: RLS 140510 054 0403 Coding: 00208936 Shop #: WSC 00028 10 Faults Found: 00156 - Control Circuit for Windshield Washer Pump 009 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 00101001 Fault Priority: 3 Fault Frequency: 2 Reset counter: 104 Mileage: 242848 km Time Indication: 0 Date: 2016.12.12 Time: 1801 Freeze Frame: ON Voltage: 12.10 V ON ON ON OFF OFF 00906 - Horn (H1) 009 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 00101001 Fault Priority: 3 Fault Frequency: 2 Reset counter: 104 Mileage: 242848 km Time Indication: 0 Date: 2016.12.12 Time: 1801 02403 - Terminal 15 for Interior 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 104 Mileage: 242849 km Time Indication: 0 Date: 2016.12.12 Time: 0001 Freeze Frame: ON Voltage: 12.10 V ON ON ON OFF OFF 01321 - Control Module for Airbags (J234) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 104 Mileage: 242849 km Time Indication: 0 Date: 2016.12.12 Time: 0001 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 2 Reset counter: 104 Mileage: 242849 km Time Indication: 0 Date: 2016.12.12 Time: 0001 Freeze Frame: ON Voltage: 12.10 V ON ON ON OFF OFF 00466 - Control Module for Steering Column Electronics (J527) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 2 Reset counter: 104 Mileage: 242849 km Time Indication: 0 Date: 2016.12.12 Time: 0001 00059 - Terminal 30 for Interior Lighting 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 0 Fault Frequency: 0 Reset counter: 0 Mileage: 0 km Time Indication: 0 Freeze Frame: Raw, Form. N/A: 000 000 000 Raw, Form. N/A: 000 000 000 Raw, Form. N/A: 000 000 000 Raw, Form. N/A: 000 000 000 Raw, Form. N/A: 000 000 000 Raw, Form. N/A: 000 000 000 Raw, Form. N/A: 000 000 000 Raw, Form. N/A: 000 000 000 00926 - Terminal 30 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 0 Fault Frequency: 0 Reset counter: 0 Mileage: 0 km Time Indication: 0 01317 - Control Module in Instrument Cluster (J285) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 0 Fault Frequency: 0 Reset counter: 0 Mileage: 0 km Time Indication: 0 01309 - Power Steering Control Module (J500) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 0 Fault Frequency: 0 Reset counter: 0 Mileage: 0 km Time Indication: 0 ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels: 3C8-919-475.clb Part No SW: 3C8 919 475 A HW: 3C8 919 475 Component: PARKHILFE 8K H07 0009 Revision: -------- Serial number: 08791012036875 Coding: 100002 Shop #: WSC 00028 028 00001 VCID: 326CC18A6DB421D12F-8066 3 Faults Found: 01299 - Diagnostic Interface for Data Bus (J533) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 1 Reset counter: 104 Mileage: 242849 km Time Indication: 0 Date: 2016.12.12 Time: 0024 Freeze Frame: Temperature: 31.0°C 01317 - Control Module in Instrument Cluster (J285) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 1 Reset counter: 104 Mileage: 242848 km Time Indication: 0 Date: 2016.12.12 Time: 1857 Freeze Frame: Temperature: 32.0°C 00466 - Control Module for Steering Column Electronics (J527) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 1 Reset counter: 104 Mileage: 242848 km Time Indication: 0 Date: 2016.12.12 Time: 1857 ------------------------------------------------------------------------------- Address 15: Airbags Labels: 5N0-959-655.lbl Part No SW: 5N0 959 655 N HW: 5N0 959 655 N Component: J234__005 VW10 HI 1916 Revision: 21014000 Serial number: 003GHP9C1YH5 Coding: 0012341 Shop #: WSC 01383 790 00002 VCID: 489883623B28BB0161-801C Subsystem 1 - Serial number: 6332MTS615421100 Subsystem 2 - Serial number: 6342MTS647871100 Subsystem 3 - Serial number: 6351HTS6AA0UA6KR Subsystem 4 - Serial number: 6361HTS619VTA6KR Subsystem 5 - Serial number: 00000000000000000 Subsystem 6 - Serial number: 00000000000000000 2 Faults Found: 01317 - Control Module in Instrument Cluster (J285) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 2 Reset counter: 104 Mileage: 242848 km Time Indication: 0 Date: 2016.12.12 Time: 1857 00588 - Airbag Igniter; Driver Side (N95) 001 - Upper Limit Exceeded - MIL ON Freeze Frame: Fault Status: 11100001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 255 Mileage: 242551 km Time Indication: 0 Date: 2016.12.12 Time: 07:08:24 ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels: 3C0-953-569.clb Part No SW: 3C5 953 501 BN HW: 5K0 953 569 AB Component: LENKS.MODUL 009 0135 Revision: FF010036 Serial number: 20100514200078 Coding: 0182270002 Shop #: WSC 00028 028 00022 ASAM Dataset: EV_VW360SteerWheelUDS A03004 ROD: EV_VW360SteerWheelUDS.rod VCID: 72EC018AA53461D1EF-8026 6 Faults Found: 226827 - Turn Signal Switch B1144 13 [008] - Open Circuit Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 111 Mileage: 0 km Date: 2000.01.01 Time: 00:00:00 227339 - Windshield Wiper Switch B1145 13 [008] - Open Circuit Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 111 Mileage: 0 km Date: 2000.01.01 Time: 00:00:00 227355 - Windshield Wiper/Washer Switch B1149 13 [008] - Open Circuit Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 3 Fault Frequency: 1 Reset counter: 111 Mileage: 0 km Date: 2000.01.01 Time: 00:00:00 332564 - Databus U1121 00 [008] - Missing Message Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 104 Mileage: 242849 km Date: 2022.07.22 Time: 0023 332660 - Databus U1121 00 [008] - Missing Message Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 104 Mileage: 242849 km Date: 2022.07.22 Time: 0023 365080 - Controls in Steering Wheel U108E 00 [009] - No Communications Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 63 Mileage: 242551 km Date: 2022.07.22 Time: 07:08:23 ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 3C8-920-xxx-17.clb Part No SW: 3C0 920 872 G HW: 3C0 920 872 G Component: KOMBI H03 0305 Serial number: 00000000000000 Coding: 160F00 Shop #: WSC 00028 028 00022 ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052 ROD: EV_Kombi_UDS_VDD_RM09_004_VW25.rod VCID: 295E26E6486262099E-807C 7 Faults Found: 12604928 - Combination / Chassis CAN Bus (SAE Bus D) U0056 00 [008] - Performance Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 104 Mileage: 242849 km Date: 2022.07.22 Time: 0023 12648448 - Function Restricted due to Missing Message(s) U1111 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 104 Mileage: 242849 km Date: 2022.07.22 Time: 0055 12664832 - Function Restricted due to Missing Message(s) U1111 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 104 Mileage: 242849 km Date: 2022.07.22 Time: 0023 12669184 - Function Restricted due to Missing Message(s) U1111 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 2 Reset counter: 104 Mileage: 242848 km Date: 2022.07.22 Time: 18:34:52 13638912 - Function Restricted due to Missing Message(s) U1111 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 104 Mileage: 242849 km Date: 2022.07.22 Time: 0023 12718592 - Function Restricted due to Missing Message(s) U1111 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 4 Reset counter: 111 Mileage: 243260 km Date: 2022.07.22 Time: 1740 12666368 - Function Restricted due to Missing Message(s) U1111 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 104 Mileage: 242849 km Date: 2022.07.22 Time: 0023 ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 3C0-907-530-V3.clb Part No SW: 3C0 907 530 N HW: 3C0 907 951 Component: J533 Gateway H14 0172 Revision: H14 Serial number: 1021G104280283 Coding: F9A07F06400203041002 Shop #: WSC 00028 028 00001 VCID: 2C50DFF28F90772165-8078 3 Faults Found: 01321 - Control Module for Airbags (J234) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 104 Mileage: 242848 km Time Indication: 0 Date: 2016.12.12 Time: 18:34:52 01317 - Control Module in Instrument Cluster (J285) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 104 Mileage: 242848 km Time Indication: 0 Date: 2016.12.12 Time: 1857 00466 - Control Module for Steering Column Electronics (J527) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 104 Mileage: 242848 km Time Indication: 0 Date: 2016.12.12 Time: 1857 ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 3C0-959-433-25.clb Part No SW: 3C0 959 433 AR HW: 3C0 959 433 AR Component: IMMO 043 0383 Revision: 00043000 Serial number: VWZCZ000000000 Shop #: WSC 131071 1023 2097151 VCID: 7AFC29AA35441991A7-802E Subsystem 1 - Part No: 3C0 905 861 H Component: ELV 028 0380 3C0905861H ELV 028 0380 1 Fault Found: 02828 - Enabling Steering Column Lock from Diagnostic Interface 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 4 Fault Frequency: 3 Reset counter: 104 Mileage: 242848 km Time Indication: 0 Date: 2016.12.12 Time: 1815 ------------------------------------------------------------------------------- Address 37: Navigation Cannot be reached ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb Part No SW: 3C0 959 701 A HW: 3C0 959 793 A Component: TUER-SG FT 002 0305 Revision: 12101005 Serial number: 0000871874 Coding: 0210B7 Shop #: WSC 00028 028 00022 ASAM Dataset: EV_DCU42BroseDriveSide A03004 ROD: EV_DCU42BroseDriveSide.rod VCID: 26442DDA597C4D71B3-8072 Slave Driver: Subsystem 1 - Part No SW: 3C0 959 703 HW: 3C0 959 795 Labels: 1K0-959-70X-GEN4.CLB Component: J388__TSG-HL 004 0402 Serial number: 00000001461478 Coding: 000090 7 Faults Found: 66561 - Motor for mirror fold-in B11F6 01 [008] - Electrical Failure Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 254 Reset counter: 132 Mileage: 201184 km Date: 2021.05.30 Time: 18:02:44 67589 - Turn Signal in Exterior Mirror B11FD 01 [009] - Electrical Failure Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 254 Reset counter: 113 Mileage: 201144 km Date: 2021.05.29 Time: 1630 68102 - Function Restricted due to Missing Message(s) U1111 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 2 Reset counter: 104 Mileage: 242848 km Date: 2022.07.22 Time: 1856 68103 - Function Restricted due to Missing Message(s) U1111 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 104 Mileage: 242849 km Date: 2022.07.22 Time: 0023 68107 - Function Restricted due to Missing Message(s) U1111 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 3 Reset counter: 104 Mileage: 242848 km Date: 2022.07.22 Time: 18:34:52 68108 - Function Restricted due to Missing Message(s) U1111 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 2 Reset counter: 104 Mileage: 242849 km Date: 2022.07.22 Time: 0055 131584 - Motor for Rear Window Regulator B11EE 54 [008] - Missing Calibration / Basic Setting Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 7 Fault Frequency: 1 Reset counter: 106 Mileage: 242859 km Date: 2022.07.22 Time: 18:54:31 ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 5N1-909-144.clb Part No SW: 5N1 909 144 K HW: 5N1 909 148 G Component: J500__APA-BS KL.147 0703 Revision: 1AH03726 Serial number: 00101230108101 Coding: 0000258 Shop #: WSC 00028 028 00001 VCID: 3A7CE9AA75C4D991E7-806E 6 Faults Found: 00576 - Terminal 15 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 6 Fault Frequency: 2 Reset counter: 104 Mileage: 242848 km Time Indication: 0 Date: 2016.12.12 Time: 18:30:42 Freeze Frame: Term 15 Off RPM: 0 /min Speed: 0.0 km/h (no units): 12.0 Voltage: 12.30 V 01317 - Control Module in Instrument Cluster (J285) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 6 Fault Frequency: 2 Reset counter: 104 Mileage: 242848 km Time Indication: 0 Date: 2016.12.12 Time: 18:30:42 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 104 Mileage: 242849 km Time Indication: 0 Date: 2016.12.12 Time: 0056 Freeze Frame: Term 15 On RPM: 1500 /min Speed: 0.0 km/h (no units): 4.0 Voltage: 12.10 V 01299 - Diagnostic Interface for Data Bus (J533) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 104 Mileage: 242849 km Time Indication: 0 Date: 2016.12.12 Time: 0056 01299 - Diagnostic Interface for Data Bus (J533) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 104 Mileage: 242849 km Time Indication: 0 Date: 2016.12.12 Time: 0024 Freeze Frame: Term 15 On RPM: 0 /min Speed: 0.0 km/h (no units): 4.0 Voltage: 12.10 V 00474 - Control Module for Immobilizer 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 104 Mileage: 242849 km Time Indication: 0 Date: 2016.12.12 Time: 0024 ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 3C0-959-433-46.clb Part No SW: 3C0 959 433 AR HW: 3C0 959 433 AR Component: KSG PQ46 ELV 043 0612 Revision: 00043000 Serial number: VWZCZ000000000 Coding: 00910A0001860E763004941570084F0B607C01 Shop #: WSC 00028 028 00001 VCID: 7AFC29AA35441991A7-802E Subsystem 1 - Component: Sounder n.mounted Subsystem 2 - Component: NGS n.mounted Subsystem 3 - Component: IRUE n.mounted 1 Fault Found: 01321 - Control Module for Airbags (J234) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 3 Reset counter: 104 Mileage: 242848 km Time Indication: 0 Date: 2016.12.12 Time: 18:34:53 ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II (J520) Labels: 1K0-907-532.clb Part No SW: 1K0 907 532 HW: 3C0 907 951 Component: EZE_2 H14 0172 Revision: -------- Serial number: 1021G104280283 Coding: 00000000 Shop #: WSC 00028 028 00001 VCID: 66C46DDA91FC8D7173-8032 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb Part No SW: 3C0 959 702 A HW: 3C0 959 792 A Component: TUER-SG BT 002 0305 Revision: 14101005 Serial number: 0000864696 Coding: 0210B6 Shop #: WSC 00028 028 00022 ASAM Dataset: EV_DCU52BrosePasseSide A03004 ROD: EV_DCU52BrosePasseSide.rod VCID: 275A20DE5E76547988-8072 Slave Passenger: Subsystem 1 - Part No SW: 3C0 959 704 HW: 3C0 959 794 Labels: 1K0-959-70X-GEN4.CLB Component: J389__TSG-HR 004 0402 Serial number: 00000001459122 Coding: 000090 7 Faults Found: 66562 - Heated Exterior Mirror B11F8 14 [008] - Open or Short to Ground Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 3 Reset counter: 99 Mileage: 241624 km Date: 2022.07.22 Time: 12:49:43 67589 - Turn Signal in Exterior Mirror B11FD 01 [009] - Electrical Failure Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 228 Reset counter: 208 Mileage: 201144 km Date: 2021.05.29 Time: 1630 68102 - Function Restricted due to Missing Message(s) U1111 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 2 Reset counter: 104 Mileage: 242848 km Date: 2022.07.22 Time: 1856 68103 - Function Restricted due to Missing Message(s) U1111 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 104 Mileage: 242849 km Date: 2022.07.22 Time: 0023 68107 - Function Restricted due to Missing Message(s) U1111 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 3 Reset counter: 104 Mileage: 242848 km Date: 2022.07.22 Time: 18:34:52 68108 - Function Restricted due to Missing Message(s) U1111 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 2 Reset counter: 104 Mileage: 242849 km Date: 2022.07.22 Time: 0055 131072 - Rear Door Control Module B11ED 04 [009] - Internal System Fault Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 4 Fault Frequency: 1 Mileage: 199316 km Date: 2021.04.13 Time: 1542 ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 5N0-907-801.clb Part No SW: 3C8 907 801 E HW: 3C8 907 801 E Component: J540 EPB3 VW-15417 0007 Revision: 010 Serial number: 00000000274620 Coding: 0000056 Shop #: WSC 00028 028 00001 VCID: 2C50DFF28F90772165-8078 5 Faults Found: 00474 - Control Module for Immobilizer 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 104 Mileage: 242849 km Time Indication: 0 Date: 2016.12.12 Time: 0024 Freeze Frame: Voltage: 11.80 V Count: 36 Speed: 0.0 km/h Hex Value: 0x1271 Hex Value: 0x0001 Hex Value: 0x1010 00576 - Terminal 15 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 104 Mileage: 242849 km Time Indication: 0 Date: 2016.12.12 Time: 0024 03182 - Clutch Position Sensor (G476) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 3 Fault Frequency: 4 Reset counter: 104 Mileage: 242849 km Time Indication: 0 Date: 2016.12.12 Time: 00:03:45 Freeze Frame: Voltage: 11.90 V Count: 57 Speed: 0.0 km/h Hex Value: 0x1261 Hex Value: 0x0001 Hex Value: 0x1010 01299 - Diagnostic Interface for Data Bus (J533) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 3 Fault Frequency: 4 Reset counter: 104 Mileage: 242849 km Time Indication: 0 Date: 2016.12.12 Time: 00:03:45 02442 - Function Lamp in Control Head 009 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 00101001 Fault Priority: 2 Fault Frequency: 254 Reset counter: 133 Mileage: 225602 km Time Indication: 0 Date: 2016.12.12 Time: 0809 Freeze Frame: Voltage: 12.50 V Count: 81 Speed: 0.0 km/h Hex Value: 0x1260 Hex Value: 0x0001 Hex Value: 0x0202 ------------------------------------------------------------------------------- Address 56: Radio Cannot be reached ------------------------------------------------------------------------------- Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb Part No SW: 1K0 907 534 HW: 3C0 907 951 Component: Batt.regelung H14 0172 Revision: -------- Serial number: 1021G104280283 Coding: 030B085A Shop #: WSC 00028 028 00001 VCID: 68D863E29BE89B0141-803C Subsystem 1 - Part No SW: 1K0 915 181 C HW: 1K0 915 181 A Component: J367-BDM H07 0125 Serial number: 00000000002790121372 No fault code found. End-------------------------(Elapsed Time: 02:40)-------------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 17: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 01: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 03: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 08: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 09: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 10: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 15: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 16: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 19: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 25: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 42: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 44: DTCs cleared |
22/07/2022, 10h30 | #2 |
Pouvoir de réputation: 48 |
Problème d'alim. Efface les DTC et refait un scan direct . Utilise les balises "code" bouton "#" quand tu inserts le rapport dans ton message : Code:
2 erreurs | nycos57 | LEXIA, PP2000, DiagBox | 8 | 26/10/2020 20h18 |
Erreurs ECU et Compteur Audi A3 8P7 | Blackout06 | Electronique | 23 | 20/01/2020 09h28 |
Aide pour log erreurs | sami_b | VAS5054, VCDS, ODIS | 1 | 26/08/2019 01h45 |
Liens pour erreurs ODB | Goqu | Logiciel & autres documentations général | 1 | 29/03/2014 16h01 |
Trouver les 3 erreurs TOP du TOP | Amine-TE | Café du forum | 14 | 23/02/2014 17h26 |
