27/01/2016, 01h52 | #16 |
Pouvoir de réputation: 20 |
Hi ballajunior,
I installed all updates from 8.02 to 8.19, they went fine and the system ran without problems, but I haven't had the chance to test on a car yet. Please notice that all Diagbox updates from 7.67/8.03 are equal.. I think PSA has added connectivity to dealers to obtain data on serviced cars in version 8. I tried porting the full solution to an another computer (extract without install, thinking of packaging it fully updated) but I had challenges with PC Identifier; Look into "C:\AWRoot\dtwr\cfg\infopds.xml". As I said earlier, I might do a write up on this subject, I need to evaluate the value of the exercise.. If you wish, you could try the complete "C:\APP" folder for DiagBox version 8.19 (includes Lexia and PP2000) already updated (838MB).. it does not include the DiagBox 8.19 "C:\AWRoot" which has the Profile Configuration files, but it should work with your current "C:\AWRoot" setup. It might require the installation of VC++ 2008.. If you notice any operational difference; share the experience. Try at your own risk... To try it: 1- Kill all DiagBox services (including sim and FireBird) 2- Rename your current "C:\APP" folder to "C:\APP7" 3- Extract (Here) the App819 to the "C:\" drive and you should have "C:\APP" (make sure you don't have another APP folder inside C:\App\) 4- Restart the computer and try the complete DiagBox 8.19 Engines.. To revert: 1- Just kill all services (including sim and FireBird). 2- Rename the "C:\App" folder to "C:\APP819" 3- Rename "C:\APP7" to "C:\APP" 4- Restart the computer and run DiagBox, 5- If all is well, delete "C:\APP819" or keep it to try whatever you wish at a later stage.. |
29/01/2016, 08h42 | #17 |
Pouvoir de réputation: 13 |
For me it doen't works. I exactly do what you said, and I'm stil in 7.83.
Do I need to be in 7.82 to do that APP folder change ??? |
29/01/2016, 09h14 | #18 |
It is working...
When you install APP 8.19, the version number on your DiagBox installation will NOT change, because it is coming from AWRoot and we have not changed AWRoot.. So, if you have V7.66 and install APP 8.19. You will have APP 8.19 running but your DiagBox will say V7.66. |
29/01/2016, 10h58 | #19 |
ok now I understand, thinks for your Simple quick answer
30/01/2016, 17h44 | #20 |
Pouvoir de réputation: 0 |
as simple said, id0479... error solved installing Microsoft Visual C++ 2008 SP1 Redistributable
it won't be solved with 2005 or 2010 versions but 2008 only tested by myself in new diagbox installation up to 7.83 on xp sp3 partition, not virtual pc |
31/01/2016, 09h45 | #21 |
as i cannot edit my posts, here is link for Microsoft Visual C++ 2008 SP1 Redistributable
https://www.microsoft.com/en-US/down...s.aspx?id=5582 |
04/02/2016, 05h31 | #22 |
Pouvoir de réputation: 30 |
Salut les amis, quelqu'un peut me dire en quelle version de firmware passe l'interface avec cette version de diagbox s'il vous plait ?
Merci. Envoyé de mon SM-G920F en utilisant Tapatalk |
04/02/2016, 06h48 | #23 |
fw 4.3.4
since diagbox 7.6x firmware autoupdate is disabled, use interface checker instead |
04/02/2016, 06h58 | #24 |
here all firmwares
http://www.tlemcen-electronic.com/fo...ad.php?t=40633 |
The Following User Says Thank You to manocao For This Useful Post: | pug_dari (05/07/2016) |
04/02/2016, 07h11 | #25 |
OK merci friend! Je regarde ça...
11/11/2017, 18h13 | #26 |
salut Simple et maitresox,
tout d'abord un grand merci pour tout le travail accompli sur ce logiciel "diagbox" |
Sponsored Link |
Liens sociaux |
Discussions similaires | ||||
DiagBox v7.77 update | Simple | LEXIA, PP2000, DiagBox | 1 | 21/09/2015 04h40 |
diagbox ask for update | Chumovoy | LEXIA, PP2000, DiagBox | 0 | 10/07/2014 15h56 |
Diagbox update 7.44 to 77.45 | fufounet | LEXIA, PP2000, DiagBox | 5 | 23/06/2014 10h57 |
Diagbox update 7.33 to 7.34 | fufounet | LEXIA, PP2000, DiagBox | 5 | 24/02/2014 00h16 |
diagbox update 6.32 | deedee | LEXIA, PP2000, DiagBox | 0 | 23/12/2012 21h15 |
