IMPORTANT MESSAGE FOR OUR USER
si vous avez été banni pour une raison de spam sur le forum (hacked account) c'est parce que votre compte a été utilisé par des Bots, merci d'envoyer un message via le formulaire de contact en bas de cette page afin de récupérer votre compte, les messages/discussions supprimés ne seront malheureusement pas restaurés.
Discussion fermée
Vieux 15/08/2017, 14h13   #1
Pouvoir de réputation: 79
Par défaut Diagbox Révérence 921815 /C
Mon problème est que je fais une bêtise sur mon interface Diagbox Révérence 921815 /C qui marche bien ; en le flashons avec un fichier révérence 963830 /c et du-cou il naît plus reconnu!
vous n'avez pas le firmware d’origine révérence 921815 /C pour le reflasher svp ?
omarzoro est déconnecté
Vieux 19/08/2017, 07h36   #2
Simple
Avatar de Simple
Simple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud of
I tried Google Translate but I am not sure if I understand it properly.
However, if you have a problem with the VCI NOT being recognized after flashing the firmware, it could be due to error during the flashing process. This can be due to:
1- Corrupt Firmware file. (bad file from source or during extraction (unZIP) or download)
2- Corruption in flashing process. (Low or fluctuating voltage or Anti Virus)
3- Problem with the Chip or the device hardware. (Loose connector/cable or bad component affected by cold or heat)
To see if this can be fixed do the following:
1- Download the Firmware again from a different source, like here:
use a Torrent downloader and download only the Firmware. Or from other source.
2- Use a different computer to flash the firmware, and ensure that the computer is connected to the mains (Electricity not Battery). It is possible that the computer USB voltage was at or below the threshold needed for the flashing process.
After flashing is successful, keep the VCI connected to USB for at least 10 seconds before disconnecting the device.
3- If it is bad connection or a faulty chip, then ensure that cables are plugged in properly and do not move them during the flashing process. chip replacement would be necessary, and could be more difficult to fix. I hope this is not the case.
Good luck.
---------- Post added at 07:36 AM ---------- Previous post was at 07:33 AM ----------
http://www.tlemcen-electronic.com/fo...ad.php?t=64153
Simple est déconnecté
The Following 3 Users Say Thank You to Simple For This Useful Post:
boris93600 (07/04/2022), omarzoro (19/08/2017), vortex (24/08/2017)
Vieux 19/08/2017, 12h52   #3
Thank you simple i will try
Vieux 24/08/2017, 17h40   #4
Résolu merci tout le monde
Vieux 24/08/2017, 19h44   #5
Simple
Avatar de Simple
Just for all to know, it was the ACTIA Drivers on Windows that did not recognize the VCI. So a reinstall did the trick.
@omarzoro,
I told you in a post on the other forum this:
https://www.lesamisdudiag.com/diagbo...tml#post211605
Salam omarzoro,
The Firmware you installed on your VCI should work, if you can communicate with the VCI then uninstall the Drivers and reinstall them. I think it is accidental that it did not work and the problem may be in a connection.
On August 21st.. You see why sometimes we get fed up because the user does not feedback properly..
The Following 2 Users Say Thank You to Simple For This Useful Post:
omarzoro (29/08/2017), Pilouf (25/08/2017)
Discussion fermée
Lexia, diagbox... Vin Lu par diagbox mais pas de communication avec les calculateurs julien34560 LEXIA, PP2000, DiagBox 24 13/12/2015 09h42
DIAGBOX 7.34->7.35 et 7.35->7.36 fufounet LEXIA, PP2000, DiagBox 6 23/03/2014 21h58
Diagbox garageducentre LEXIA, PP2000, DiagBox 13 14/03/2014 15h58
Diagbox lis que le vin Niga LEXIA, PP2000, DiagBox 6 13/10/2013 10h56
Révérence Formator Café du forum 37 23/10/2011 19h14
Fuseau horaire GMT +1. Il est actuellement 14h36.
