Vieux 12/10/2018, 21h47   #1
repcles
Avatar de repcles
repcles is a name known to allrepcles is a name known to allrepcles is a name known to allrepcles is a name known to allrepcles is a name known to allrepcles is a name known to all
Par défaut pb lors install wow pb interface
slt a tous , lors install wow , message verification du numero de serie a echoué de l interface
ci-joint image ecran.
merci a tous.
Type de fichier : jpg pb wow.jpg (92,6 Ko, 12 affichages)
Vieux 12/10/2018, 21h51   #2
seadoo831
Avatar de seadoo831
Pouvoir de réputation: 115
Salut ca serai pas la version 5008 R2 que tu as installer par hasard??
Pas de Thank's plus d aides
Vieux 12/10/2018, 22h13   #3
repcles
Avatar de repcles
slt c est sa .
y a un souci avec ?
Vieux 12/10/2018, 22h29   #4
seadoo831
Avatar de seadoo831
non il faut aller dans un dossier et ouvrir un fichier texte et y mettre ton numero d interface sinon marchera pas mais je sais plus quel dossier faut ouvrir
---------- Post added at 21h29 ---------- Previous post was at 21h27 ----------
voila l ami
Ouvrez le fichier C / wow5.00.8R2eng / ac_diagnosis_module / data / serial_numbers.txt
Watch a enregistré votre S / N numéro de l'appareil
The Following User Says Thank You to seadoo831 For This Useful Post:
repcles (13/10/2018)
Vieux 12/10/2018, 22h44   #5
repcles
Avatar de repcles
ok merci je teste sa demain.
---------- Post added at 23h44 ---------- Previous post was at 23h41 ----------
Envoyé par repcles Voir le message
re numero interface tu trouve ou?
Vieux 12/10/2018, 22h57   #6
martinn
Avatar de martinn
martinn is a splendid one to beholdmartinn is a splendid one to beholdmartinn is a splendid one to beholdmartinn is a splendid one to beholdmartinn is a splendid one to beholdmartinn is a splendid one to beholdmartinn is a splendid one to beholdmartinn is a splendid one to behold
si tu as delphi tu la dans installation materiel quand tu fais la detection
Vieux 12/10/2018, 23h03   #7
repcles
Avatar de repcles
mais moi j ai installé le wow , je trouve pas s/n?
Vieux 12/10/2018, 23h16   #8
martinn
Avatar de martinn
tu as pas delphi sur un pc? tu peux pas l installer vite fait?
Vieux 13/10/2018, 09h47   #9
repcles
Avatar de repcles
slt je peux pas savoir autrement?
Vieux 13/10/2018, 10h48   #10
abdel93
Avatar de abdel93
abdel93 has a brilliant futureabdel93 has a brilliant futureabdel93 has a brilliant futureabdel93 has a brilliant futureabdel93 has a brilliant futureabdel93 has a brilliant futureabdel93 has a brilliant futureabdel93 has a brilliant futureabdel93 has a brilliant futureabdel93 has a brilliant futureabdel93 has a brilliant future
slt les sn pour la plupart 100251 ,si t'arrive pas donne moi la main jte le fait en 5 seconde la
Vieux 13/10/2018, 12h29   #11
repcles
Avatar de repcles
slt a tous , c sa abdel 100251, j ai fait comme a dit martinn install delphi m a donne s/n et renseigne sur mon pc wow , suivi etape seadoo, merci a tous pour votre aide .
sujet clos
Vieux 13/10/2018, 12h39   #12
khoums
Avatar de khoums
khoums is a name known to allkhoums is a name known to allkhoums is a name known to allkhoums is a name known to allkhoums is a name known to allkhoums is a name known to all
Il faut entrer le numéro de série de ta sonde dans le ficher serial.txt dans le dossier wow.
Connecte bien le Bluetooth aussi avant
Envoyé de mon BLA-L29 en utilisant Tapatalk
LES COÏNCIDENCES SONT UNE MANIÈRE POUR DIEU DE RESTER ANONYME.
Albert EINSTEIN
khoums est déconnecté   Réponse avec citation
Vieux 13/10/2018, 13h01   #13
repcles
Avatar de repcles
slt khoums , j ai sonde delphi sans Bluetooth, je prefere filaire.
Vieux 13/10/2018, 14h05   #14
khoums
Avatar de khoums
Ah OK la je ne sait pas désolé. Mais je pense que c'est pareil que la wow
Albert EINSTEIN
Erreur lors du diag Monkey_ Renault clip, DDT2000, Nissan consult 4 21/12/2016 18h03
Moteur 307 hdi explosé lors d une regeneration FAP MOUS25 Peugeot, Citroën 13 23/09/2015 11h09
Erreur lors du test des calculateurs ! neiji Renault clip, DDT2000, Nissan consult 11 02/08/2015 18h05
fumee blanche lors de la regeneration jpay2 Fiat, Alfaromeo, Lancia 11 02/11/2014 21h57
problème lors de l installation de diagbox Adrien13 LEXIA, PP2000, DiagBox 11 15/03/2014 13h45
Fuseau horaire GMT +1. Il est actuellement 01h08.
