Vieux 09/02/2018, 10h34   #1
Loupiot
Avatar de Loupiot
Loupiot has a spectacular aura aboutLoupiot has a spectacular aura aboutLoupiot has a spectacular aura about
Par défaut Code wow 5.00.8 r2
Salut est ce que quelqu'un pourrais me donner le code d'activation pour ma clé WOW-359-096-332-423016-9790295
Merci d'avance :)
Loupiot est déconnecté   Réponse avec citation
Vieux 09/02/2018, 11h22   #2
autodiagauto
Avatar de autodiagauto
autodiagauto has a reputation beyond reputeautodiagauto has a reputation beyond reputeautodiagauto has a reputation beyond reputeautodiagauto has a reputation beyond reputeautodiagauto has a reputation beyond reputeautodiagauto has a reputation beyond reputeautodiagauto has a reputation beyond reputeautodiagauto has a reputation beyond reputeautodiagauto has a reputation beyond reputeautodiagauto has a reputation beyond reputeautodiagauto has a reputation beyond repute
ICI:
0306801-vgptxwphqi2225xu22222229-76190421-464898-1083212 [WoW! Basic]
0306801-vgptxwphqi2325xurhpxxwx9-76190421-464898-1883217 [WoW! Pro]
0306801-2222222iq222222222222222-76190421-464898-1483213 [WoW! PocketPc]
0306801-22222222q2322232429xxwx2-76190421-464898-1583218 [WoW! Mercedes-Benz - Open License]
0306801-22222222q222222242222222-76190421-464898-1883212 [WoW! Mercedes-Benz - Extension Package]
0306801-22222222q2422232629xxwx2-76190421-464898-1083212 [WoW! BMW - Open License]
0306801-22222222q222222262222222-76190421-464898-1283216 [WoW! BMW - Extension Package]
0306801-vgptxwphqi2225xu22222229-76190421-464898-1083212 [Technische Daten SD-100]
0306801-vgma2w22q22225k622222227-76190421-464898-1883212 [Technische Daten Service]
0306801-225lxwphq22222gq22222224-76190421-464898-1683211 [Technische Daten Diagnose]
0306801-22222222q222222222222222-76190421-464898-1483219 [Technische Data Special]
0306801-22222222q2229xxxw2222222-76190421-464898-1883210 [WoW! Server]
0306801-vgptxwphq22225wu22222229-76190421-464898-1583216 [Diagnose SerieII S-Light]
0306801-22222222q2222222222222w2-76190421-464898-1183218 [Diagnose SerieII S-100 Extension]
autodiagauto est connecté maintenant   Réponse avec citation
The Following User Says Thank You to autodiagauto For This Useful Post:
Loupiot (09/02/2018)
Vieux 09/02/2018, 11h31   #3
Loupiot
Avatar de Loupiot
Je te remercie c'est super sympa par contre je dois mettre lequel ? Et le code client que dois je écrire ?
The Following User Says Thank You to Loupiot For This Useful Post:
autodiagauto (09/02/2018)
Vieux 09/02/2018, 12h43   #4
abdel93
Avatar de abdel93
abdel93 has a brilliant futureabdel93 has a brilliant futureabdel93 has a brilliant futureabdel93 has a brilliant futureabdel93 has a brilliant futureabdel93 has a brilliant futureabdel93 has a brilliant futureabdel93 has a brilliant futureabdel93 has a brilliant futureabdel93 has a brilliant futureabdel93 has a brilliant future
Envoyé par Loupiot Voir le message
slt met wow pro et pour le code client tu peut mettre nimoprte quoi il me semble ou sinon tu met 100251
The Following 2 Users Say Thank You to abdel93 For This Useful Post:
autodiagauto (09/02/2018), Loupiot (09/02/2018)
Vieux 09/02/2018, 13h07   #5
Loupiot
Avatar de Loupiot
Ok super merci les gars ça marche j'ai mis n'importe quoi et impeccable ;)
abdel93 (09/02/2018)
Vieux 09/02/2018, 13h37   #6
Loupiot
Avatar de Loupiot
J'ai un message d'erreur en parcourant le logiciel savez vous ce qu'il faut que je fasse ? ci joint une photo
Type de fichier : jpg wow erreur.jpg (92,7 Ko, 24 affichages)
Vieux 09/02/2018, 14h05   #7
abdel93
Avatar de abdel93
tu a déjà autocom ou delphi installer?
Vieux 09/02/2018, 14h13   #8
Loupiot
Avatar de Loupiot
Autocom je n'ai pas delphi
Vieux 09/02/2018, 15h41   #9
abdel93
Avatar de abdel93
tu prend le firmware de autocom tu le met dans wow ,comme ca taura plus ce pb la
Vieux 09/02/2018, 16h24   #10
Loupiot
Avatar de Loupiot
Et tu fais ça comment exactement ? Merci de ton aide
Vieux 09/02/2018, 17h21   #11
autodiagauto
Autocom tourne en .NET et envoie les mêmes commandes que WOW à la VCI
Wow tourne en JAVA et et envoie les mêmes commandes que Autocom à la VCI
Loupiot (10/02/2018)
Vieux 09/02/2018, 18h34   #12
martinn
Avatar de martinn
martinn is a splendid one to beholdmartinn is a splendid one to beholdmartinn is a splendid one to beholdmartinn is a splendid one to beholdmartinn is a splendid one to beholdmartinn is a splendid one to beholdmartinn is a splendid one to beholdmartinn is a splendid one to behold
tu prend dans ta base de fichier delphi tu as un dossier qui s appel firmware tu selectionne tout et tu copie dans C:wow/ac_diagnosis_module/firmware
et c est bon mais de preference avant de copierferme wow.
maintenant apres la copie lance ton wow en ayant ton botier relier en usb et tu va dans parametre, tu recherche ton port et tu flash micrologiciel et hop tu pourra utiliser tes 2 logiciel.
The Following 2 Users Say Thank You to martinn For This Useful Post:
abdel93 (10/02/2018), Loupiot (10/02/2018)
Vieux 10/02/2018, 10h45   #13
abdel93
Avatar de abdel93
je dirait même que tu n'a pas besoin de metre le micrologiciel a jour vue que tu la déjà fait avec wow,tu fait juste comme martinn ta dit sans le flash du micrologiciel
code injection immobilizer renault dacia code antidémarrage yahia1908 Transponder, code pin 0 19/10/2017 15h04
demande modification dump pour eliminer code code off ziamo Autoradio et Navigateur GPS 3 19/01/2013 00h07
jumpy code defaut p1613 code injecteur rrguillaume Peugeot, Citroën 6 30/12/2012 11h59
Fuseau horaire GMT +1. Il est actuellement 12h46.
