Section for english users English talking about cars, problems and solutions ... |
26/04/2014, 20h41 | #1 |
Pouvoir de réputation: 0 |
Diagbox Windows 7 Install
Have any members on here had issues when installing Diagbox on Windows 7?
I'm using 32-bit, Pro version - in a Virtual Machine on my Mac (VMWare Fusion 6). When it gets to the initial activation, it fails with a status code of 0. I've got the language set to US, I've tried with the network adaptor enabled and disabled, and also with and without UAC working. If I do exactly the same process using Windows XP, it's works as it should. I've been using XP + Lexia 46 for some years now, and would like this opportunity to upgrade both the OS and software. |
27/04/2014, 07h37 | #2 |
Pouvoir de réputation: 14 |
No problems with install Diagbox on Win7 en 32bit. I have also installed Diagbox on pc with Win8.1 en 32 bit. OS must be 32 bit.
The Following User Says Thank You to Geri For This Useful Post: | adiago (27/04/2014) |
27/04/2014, 12h28 | #3 |
I'm using 32-bit Windows 7. Its strange that it works fine with XP, but activation issues with Windows 7. I'm going to try creating a Virtual Machine using a different software first, and then import it into VMWare. I've seen a few posts on the internet that VMWare has caused issues in the past.
29/04/2014, 17h25 | #4 |
As mentioned, it worked fine in Virtual Box. I've tried subsequently importing into VMWare but then Diagbox needs reactivating.
I'll just have to get used to using Virtual Box I guess! |
16/05/2014, 21h38 | #5 |
17/05/2014, 10h20 | #6 |
I wonder if VMWare Fusion is a bit different then? It's the latest VMWare fusion 6 running on OS X.
19/05/2014, 09h23 | #7 |
Tuto Maker
Pouvoir de réputation: 20 |
Hey guys, same issue there ! No way to enable DB 7 in a virtual machine with Win7 and VMplayer (even in an XP VM if my memory is good) !
I tried many things arround network NAT, firewall, internet connection sharing, UAC, NO WAY !!! You're not alone guys ^^ I'll try with VirtualBox ! |
24/05/2014, 05h37 | #8 |
It is not the problem with vmware VM, but with controler on which boot HDD is insatled. it must be IDE no SCSI, which vmware choose by default (as can not be changed to IDE other way than editing wmx file). As with SCSI you get activation error = 0.
The Following User Says Thank You to przygodap For This Useful Post: | biohead (26/05/2014) |
04/06/2014, 13h53 | #9 |
burn the iso to a disc as it has to be installed from a physical disc, i had this problem untill i figured that out, the updates can be done from hard drive but the 1st install has to be done from a disc
24/06/2014, 10h25 | #10 | |
the problem can be that the diagbox installer detects the virtual machine and doesnt install?. Try This
Edit the VM Settings and add this Citation:
The Following User Says Thank You to BackONct For This Useful Post: | betrescudan (31/08/2014) |
30/07/2014, 05h52 | #11 |
From my expirience it will be enought to add 1mb IDE drive to VMware virtual machine to make sure that activation code is different than 0
17/10/2015, 08h49 | #12 |
i've used 7.65 on windows 10.
no issues till 16/10. now looking for update |
17/10/2015, 12h02 | #13 |
Pouvoir de réputation: 28 |
Hello i have just one question? Why are you bothering with Windows 10?
diagbox et windows 8.1 | tonio5766 | LEXIA, PP2000, DiagBox | 2 | 14/04/2014 19h08 |
diagbox windows 7 32b sur netbook | alexio | LEXIA, PP2000, DiagBox | 0 | 24/02/2014 20h17 |
tout les drivers windows pour diagbox | deedee | LEXIA, PP2000, DiagBox | 10 | 31/07/2013 12h36 |
