Précédent   Tlemcen Car electronics > Outils & Diag > Outils de diagnostique > MBStar, Xentry, DAS
Vieux 18/04/2016, 23h47   #1
3atman
Avatar de 3atman
3atman has much to be proud of3atman has much to be proud of3atman has much to be proud of3atman has much to be proud of3atman has much to be proud of3atman has much to be proud of3atman has much to be proud of3atman has much to be proud of
Par défaut Xentry DAS 05-06.2014_full_b1_s1_v1
telecharger Xentry DAS 05-06.2014_full_b1_s1_v1
DAS - Xentry 05.2014 Installed Image Dell E5500 D630 / 620, IBM Acronis
Here is an Xentry DAS image for a Dell E5500, which will work on Dell D630 / 620, IBM T40/T43, Pana. CF19 and many other laptops.
This is 05-06.2014 version. Tested and working
PLEASE READ THE FOLLOWING
The image was made with Acronis True Image 2014 boot cd, so use this to recover the image.
This was made on a basic Windows XP (SP3) install, no drivers are installed, you need to install the ones for your particular laptop.
The multiplexer type is set for for PART D (C3), but there is a bin folder for SDConnect (C4), which you can copy over. Look in F:\Programme\DAS\
To change to SDconnect, rename the bin folder (to bin_PartD ,for example) and then change the name of the folder "original bin" to bin
No keys are installed. (keys are unique to your laptop / PC)
Use the KEYGEN MHH (on desktop) for DAS key (remember to set a date)
Use the Xentry Developer.exe (also on desktop) for Xentry key
Adobe Acrobat and Virtual CloneDrive are installed.
Fixes have been applied for SDstartup, Xentry Blacklist and missing pictures.
WIS, EPC and Starfinder are not installed, to keep the torrent size low. All of these are easy to add.
The password for user STAR is the default, User$star2004
Type de fichier : zip Xentry DAS 05-06.2014_full_b1_s1_v1.tib.zip (51,5 Ko, 175 affichages)
3atman est déconnecté   Réponse avec citation
The Following 7 Users Say Thank You to 3atman For This Useful Post:
adcsytes (05/12/2023), benazze38 (15/06/2018), chipshop (10/11/2017), cristian89ra (28/03/2024), liilmrll (29/01/2023), mecanodiag93 (03/05/2016), Milkdelish (06/07/2022)
Vieux 01/05/2016, 22h10   #2
BILAUTO
Avatar de BILAUTO
Pouvoir de réputation: 56
Bonsoir, quelqu'un pourrait il m'aider pour l'installation de Xentry DAS 05-06.2014_full_b1_s1_v1.
j'ai téléchargé le logiciel et je n'ai pas compris comment procéder.
The Following User Says Thank You to BILAUTO For This Useful Post:
3atman (03/05/2016)
Vieux 05/05/2016, 07h42   #3
BILAUTO
Avatar de BILAUTO
Salut les amis.
Personne pour me renseigner?????
Vieux 05/05/2016, 08h53   #4
kitty-hawk
Avatar de kitty-hawk
Pouvoir de réputation: 44
Hello,
Qu'est ce que ça veut dire "b1_s1_v1"??
Vieux 05/05/2016, 09h14   #5
BILAUTO
Avatar de BILAUTO
salut, je n'arrive tous simplement pas à comprendre comment proceder pour l'installation de xentry. pourrais tu me donner la methodologie.
le fichier est telecharger, acronis egalement. j'ai plusieurs partition c d e f .
mais je ne comprend pas l'histoire de bin........
Vieux 05/05/2016, 09h19   #6
kitty-hawk
je n'ai pas téléchargé cette version,
Il y a un tuto d'installation avec? si oui peux tu le poster ici?
Quelle sonde veux-tu utiliser? C3? SDconnect?...
Vieux 05/05/2016, 10h00   #7
BILAUTO
Avatar de BILAUTO
Vieux 05/05/2016, 10h01   #8
BILAUTO
Avatar de BILAUTO
jutilise c3 mb star
Vieux 05/05/2016, 10h31   #9
kitty-hawk
Dans ce cas tu n'as pas besoin du fichier Bin, il est seulement utilisé pour les sondes SDConnect (C4).
Vieux 05/05/2016, 14h31   #10
BILAUTO
Avatar de BILAUTO
ok mais je dois executer quelle fichier pour mon installation
Vieux 05/05/2016, 16h44   #11
kitty-hawk
Cette version de xentry ne peut pas être utilisée pour une installation en "natif", c'est une image de restauration.
Tu dois utiliser Acronis True Image pour "restaurer" ton pc.
En gros c'est une sauvegarde pouvant être utilisée sur d'autre pc.
Si tu veux une vrai installation en natif tu dois télécharger une autre version de Xentry.
Vieux 06/05/2016, 06h44   #12
BILAUTO
Avatar de BILAUTO
lors de la restauration, quelle partition dois je restaurer?
j'aimerai qu'une personne me donne la methodologie car je suis perdu!!!!
Vieux 29/05/2016, 10h19   #13
NewSmart
Avatar de NewSmart
Pouvoir de réputation: 8
NewSmart will become famous soon enough
j'arrive peut etre un peut tard mais en fait " 3atman " a poster une image disque d'un ordinateur Dell E5500, qui fonctionne aussi sur Dell D630 / 620 et etc...
1- il te suffit de telecharger " Acronis True Image 2014 boot cd " de la graver sur un cd
2 - puis de telecharger " Xentry DAS 05-06.2014_full_b1_s1_v1.tib.zip " en pieces jointe dans le 1ere poste de cette discussion ( " 3atman " )
3 - Telecharger "utorrent" ou autres et l'installer
4 - ouvrir " Xentry DAS 05-06.2014_full_b1_s1_v1.tib.zip " et cliquer deux fois sur " Xentry DAS ........................tib.torrent "
5 - une fois le télécharger du torrent terminé le mettre sur un disque externe ou clef usb externe formater un fat32 ou NTSF ou exfat
6- mettre CD "Acronis True Image 2014" dans un ordi Dell ou autre compatible avec cette version de "xentry" voir 1ere Poste de cette discussion
ATTENTION LE DISQUE DUR VA ETRE EFFACER SAUVEGARDE TES DONNÉES
7 - Booter sur CD souvent sur le PC Dell faut appuie sur F12 aussitôt après avoir allumer le pc
8 - un Menu S'affiche choisir avec les fleche du clavier Haut et Bas Le Lecteur CD DVD et appuie sur la touche entrée pour valide le choix
9 - Pendant démarrage de "Acronis True Image 2014" branche disque dur externe ou cle usb sur lequel ta mis le torrent télécharger avec "utorrent"
10 - se laisser Guider tout en choisissant de restaurer l'image disque !!!!
essayer et tiens nous au courant
NewSmart est déconnecté   Réponse avec citation
The Following User Says Thank You to NewSmart For This Useful Post:
chipshop (16/11/2017)
Vieux 31/05/2016, 00h18   #14
NewSmart
Avatar de NewSmart
Testé et approuvé sur Dell D630 100% fonctionnel
Vieux 12/01/2017, 06h48   #15
marikette
Avatar de marikette
marikette has a spectacular aura aboutmarikette has a spectacular aura about
Je viens de restaurée l'image sur un pana cf 19 mais ça ne fonctionne pas ça au démarrage j'ai une erreur xp sûrement du au fait qu'il est prévu pour un Dell.
Di quelqu'un aurrait une idée pour l'installation sur mon panasonic toughbook cf 19
Chercher n'est pas forcément trouver et ce que tu trouves n'est pas toujours ce que tu cherchais.
marikette est déconnecté   Réponse avec citation
clé xentry Das wis jp59 MBStar, Xentry, DAS 13 11/12/2015 18h47
DAS Xentry medcapot MBStar, Xentry, DAS 20 29/07/2015 14h46
das xentry nimbus Mercedes Benz 7 05/02/2013 13h12
Fuseau horaire GMT +1. Il est actuellement 15h33.
