Vieux 14/02/2018, 12h01   #31
Kennfeld
Avatar de Kennfeld
Envoyé par sharediag Voir le message
donc sur le edc15c2 1 plug pas de pin dans le dump?
si qlq1 peut voir un pin dans ce dump.
merci pour l eclaircissement.
Web EPROM Analyzer RESULTAT pour fichier : 5p08-13022018.bin
Mileage : 506204.228 km Immopin Calculé 1 PIN = J9XK or KX9J Immopin Calculé 2 PIN = J9XK or KX9J Immopin Calculé 3 PIN 3 = J9XK or KX9J
The Following 2 Users Say Thank You to Kennfeld For This Useful Post:
sharediag (14/02/2018), whitepearl-soft (20/05/2022)
Vieux 14/02/2018, 13h18   #32
amrougafsa
Avatar de amrougafsa
Pouvoir de réputation: 47
amrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond repute
le bon pin code: KX9J
donnes un poisson à un homme tu le nourris un jour apprends lui à pêcher tu le nourris pour la vie
amrougafsa est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to amrougafsa For This Useful Post:
sharediag (14/02/2018), soustourou (14/02/2018)
Vieux 14/02/2018, 13h36   #33
soustourou
Avatar de soustourou
soustourou has much to be proud ofsoustourou has much to be proud ofsoustourou has much to be proud ofsoustourou has much to be proud ofsoustourou has much to be proud ofsoustourou has much to be proud ofsoustourou has much to be proud ofsoustourou has much to be proud ofsoustourou has much to be proud ofsoustourou has much to be proud of
je confirme avec le soft de notre ami j-sky
Type de fichier : jpg g.JPG (24,2 Ko, 53 affichages)
On a souvent besoin d'un plus petit que soi
soustourou est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to soustourou For This Useful Post:
amrougafsa (14/02/2018), sharediag (14/02/2018)
Vieux 14/02/2018, 13h45   #34
Kennfeld
Avatar de Kennfeld
pas vraiment besoin de soft pour ça moi c'est internet explorer ou firefox chrome safari qui le supporte ;)
---------- Post added at 14h45 ---------- Previous post was at 14h43 ----------
et il peut réencoder également un autre pin évitant ainsi des immo off inutiles
déjà prouvé ici sur un ecu d'une voiture donneuse qui a redémarré juste en changeant le code pin sans nécessité de recodage à la valise elle démarre direct
The Following User Says Thank You to Kennfeld For This Useful Post:
Vieux 14/02/2018, 19h55   #35
j-sky
Avatar de j-sky
Pouvoir de réputation: 142
Envoyé par Kennfeld Voir le message
Bonjour Kennfeld
C'est bien aussi ta solution sauf qu'elle ne sais pas te donner avec certitude le bon PIN: J9XK or KX9J
Tu dis que tu n'a pas besoin de soft pour décoder l'eeprom !
Internet explorer ne sais pas faire ça nativement ou alors, ça se saurait
Je pense que tu oublies de dire que tu te connectes à un service web php qui te décode l'eeprom donc il y a du code derrière tout ça donc c'est un logiciel mais en ligne
Rappel des règles du forum
The Following 3 Users Say Thank You to j-sky For This Useful Post:
amrougafsa (14/02/2018), lioneldu77 (15/02/2018), soustourou (14/02/2018)
COde pin EDC15C2 1 broche !!!!! neocol Transponder, code pin 5 31/12/2016 15h56
pin code pour edc15c2 taneuse65 Transponder, code pin 5 19/08/2016 13h36
pin code peugeot 307 EDC15C2 SALASH1610 Transponder, code pin 9 12/12/2014 05h49
code pin ecu xsara edc15c2 charifcharif Transponder, code pin 4 01/12/2014 17h54
Code PIN 807 EDC15C2 Youri Transponder, code pin 5 04/06/2013 09h03
Fuseau horaire GMT +1. Il est actuellement 17h12.
