Précédent   Tlemcen Car electronics > Outils & Diag > Outils de diagnostique > Opcom, Tech2
Vieux 18/02/2016, 11h49   #1
mara07
Avatar de mara07
mara07 has a reputation beyond reputemara07 has a reputation beyond reputemara07 has a reputation beyond reputemara07 has a reputation beyond reputemara07 has a reputation beyond reputemara07 has a reputation beyond reputemara07 has a reputation beyond reputemara07 has a reputation beyond reputemara07 has a reputation beyond reputemara07 has a reputation beyond reputemara07 has a reputation beyond repute
Par défaut Op-com FW update v1.64
Bonjour!
Je vous propose un petit tuto pour faire update d'interface opcom jusqu'au v1.64
Pass après petit thanks demande par MP
Merci!
spécialement pour tlemcen-electronic
https://yadi.sk/d/oZ4L5KVmp44HU
Type de fichier : jpg opcom1.64.JPG (71,3 Ko, 207 affichages)
mara07 est déconnecté   Réponse avec citation
The Following 18 Users Say Thank You to mara07 For This Useful Post:
atousof (10/09/2017), CARMADA (17/10/2018), djrusskof (03/07/2017), everson29 (12/03/2017), fethidiag (16/11/2017), ggvaniou (14/12/2019), ghut54 (09/07/2017), haythoumazz (13/01/2018), izouf (04/01/2019), melka (23/09/2020), microm22 (12/07/2017), nasisamy (04/11/2016), poladrix (05/06/2020), Roturbo (30/08/2017), Scanworld2020 (06/11/2016), stephane (23/01/2018), Terranhunt (23/03/2019), youcef_trik (12/07/2017)
Vieux 18/02/2016, 12h02   #2
jpay2
Avatar de jpay2
jpay2 has much to be proud ofjpay2 has much to be proud ofjpay2 has much to be proud ofjpay2 has much to be proud ofjpay2 has much to be proud ofjpay2 has much to be proud ofjpay2 has much to be proud ofjpay2 has much to be proud ofjpay2 has much to be proud ofjpay2 has much to be proud of
salut,moi j'utilise la version 1.39 tres stable,a tu deja utiliser la 1.64???
j'avais utilise pendant un certain temps la 1.44 mais trop de bug
super le partage merci!!
Vieux 18/02/2016, 12h41   #3
mara07
Avatar de mara07
Salut, je n'ai pas testé sur les nouvelles modèles mais dans toutes les cas après des tests tu peut revenir sur ta FW préféré (en utilisant OcFlashPro) .
Merci!
Vieux 19/02/2016, 18h12   #4
mara07
Avatar de mara07
Pour ce qui a rencontré un problème avec les pilotes opcom après un update la solution ici:
https://yadi.sk/d/n6xDi6eDp8qg3
MDP la même qu'en première post
J'ai testé avec cette logiciel opcom (VAUX-com):
https://yadi.sk/d/iaHh_43Jp8r5B
problème du pilote:
Type de fichier : jpg 1.JPG (92,5 Ko, 134 affichages)
Vieux 17/05/2016, 07h07   #5
Criptic
Avatar de Criptic
Criptic has a spectacular aura aboutCriptic has a spectacular aura aboutCriptic has a spectacular aura about
Hello friends, I want to share with you a diagram for in-circuit programming in opkom (PIC18F458) using pikit3.
Criptic est déconnecté   Réponse avec citation
Vieux 17/05/2016, 07h21   #6
Criptic
Avatar de Criptic
Par défaut diagram for in-circuit programming opkom
Hello friends, I want to share with you a diagram for in-circuit programming in OPCOM (PIC18F458) using pikit3. All successful update.
Type de fichier : jpg OP-COM in-circuit connection.jpg (84,4 Ko, 156 affichages)
Type de fichier : jpg PICKIT pinout.jpg (29,0 Ko, 126 affichages)
Vieux 17/05/2016, 07h52   #7
pouettedu76
Avatar de pouettedu76
Pouvoir de réputation: 75
Bonjour a tous Perso je n'est jamais réussis a diagnostiquer une Opel avec mon opcom que se soit les anciennes voiture ( avant 2001 ) ou même après ( récent ) que se soit avec opcom ou vaux - com ( opcom 2012 ou 2014 ) rien ne marche pourtant elle est bien reconnus dans le gestionnaire de périferique même en fesant le uograde c'était juste pour vous informer donc elle dort au chaud je verrais sa un peut plus tard bonne journée a tous cordialement
tico (17/01/2018)
Vieux 17/05/2016, 08h07   #8
S-keys
Avatar de S-keys
Pouvoir de réputation: 138
slt
j'utilise mon opcom sans probleme !! v1.39
Vieux 30/05/2016, 17h59   #9
E46
Avatar de E46
E46 has a spectacular aura aboutE46 has a spectacular aura about
Salut tout le monde,
Est-ce mieux de rester en v 1.39 ou de faire la maj du firmware ?
E46 est déconnecté   Réponse avec citation
Vieux 30/05/2016, 20h22   #10
pouettedu76
Bonsoir donc moi j'etais en v.01.59 et la je suis passer en V01.39 mes quand je vais sur le port usb je ne vois pas Op-com usb V-2 mes j'ai celle ci : USB Serial Converter :
[IMG][/IMG]
[IMG][/IMG]
Si l'un de vous et dans le meme cas que moi s'il vous plait faites moi le savoir et si vous avez aussi la solution pour moi je suis preneurs vus que maintenant je suis revenu a la V.01.39 version stable il ne me reste plus qu'a le tester sur une opel bonne soirée @ tous cordialement
[IMG][/IMG]
Vieux 02/06/2016, 14h10   #11
Red_One
Avatar de Red_One
Red_One is on a distinguished road
Hello est ce que quelqu'un peu m'envoyer le mdp par mp j'ai essayé de joindre l'auteur pas de feedback :).
qu'elle est la derniere version d'opcom qui fonctione j'ai essayé d'installer une version recente mais j'ai une erreur xyz et apres impossible de detecter le hw.
avec une vielle version 100219 pas de soucis...
Red_One est déconnecté   Réponse avec citation
Vieux 28/07/2016, 03h36   #12
PIC16F84
Avatar de PIC16F84
PIC16F84 is a name known to allPIC16F84 is a name known to allPIC16F84 is a name known to allPIC16F84 is a name known to allPIC16F84 is a name known to allPIC16F84 is a name known to all
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
je fais la programmation de pic et je sais ce qu'il arrive avec ton interface mais je connais pas op-com , dans le dossier de l'ancien pilote essayer de modifier l'ID (VIDxxxx/PIDxxxx) par le nouveau ID qui s'est changé a cause de mis a jour de l'interface, et après la modif réinstalle le pilote ,si ça ne marche pas utilise le pilote de mara07 voir (poste 08)
programmation apl & micropic12/16/18
communication i2c/spi/microwire/usb/rs232/rs485/jtag/CANbus
PIC16F84 est déconnecté   Réponse avec citation
Vieux 28/07/2016, 07h03   #13
pouettedu76
Salut et merci pour ton aides mes c'est bon j'ai tous refais au début et tout est nikel j'ai le le fait un diag sur une Opel astra et c'est passer nikel chrome résolus @+ et bonne journée
Vieux 29/10/2016, 13h23   #14
jmichel1204
Avatar de jmichel1204
jmichel1204 is an unknown quantity at this point
merci je vais pouvoir mettre a jour mon opcom
jmichel1204 est déconnecté   Réponse avec citation
Vieux 04/11/2016, 16h42   #15
alsacien
Avatar de alsacien
alsacien is on a distinguished road
Envoyé par Red_One Voir le message
mdp recu perso et tres rapidement au jour d'aujourd'hui
alsacien est déconnecté   Réponse avec citation
BMW DIS V57 FR update Nelss GT1, OPS, SSS, ICOM 51 28/01/2023 19h35
k-tag update fw 6.070 betrescudan Flasheur de calculateur 2 03/05/2015 20h40
Db update 7.32 to 7.33 fufounet LEXIA, PP2000, DiagBox 4 21/01/2014 21h36
ecu update formator2 Fichiers d'origine, carto, dump, fullbackup 1 25/11/2012 21h15
Fuseau horaire GMT +1. Il est actuellement 10h01.
