Vieux 03/10/2022, 08h37   #31
33300
Avatar de 33300
33300 is an unknown quantity at this point
Patch rtl clone Board
c:\CLIP\Config\
probesConfiguration.xml
Code:
<?xml version="1.0" encoding="utf-8"?>
<!-- Keywords PVCS : Begin -->
<!--?DoC_Info Revision="$Revision:   1.8  $" Author="$Author:   acarref  $" Date="$Date:   Dec 13 2005 18:58:24" ?-->
<!-- Keywords PVCS : end -->
<Conf_Root>
	<Conf_Set name="Borneo">
		<Conf_Set name="Acquisition" doc="Acquisition layer configuration, see NT021027.001">
			<Conf_Param name="DriverPath" value="../Drivers"/>
			<Conf_Param name="DriverIniPath" value="../../../CLIP/Data/Appli/Params/"/>
			<Conf_Param name="FirmwarePath" value="../../../CLIP/Data/Appli/Params/"/>
			<Conf_Param name="ProbesInfoPath" value="../../../CLIP/Data/User/probesInformation.xml"/>
			<Conf_Set name="Boards">
				<!-- BoardNis04VI -->
				<Conf_Set name="BoardNis04VI">
					<Conf_Param name="DriverFile" value="Nis04_VI_DrvUsr.dll"/>
					<Conf_Param name="DriverIniFile" value="VIDrvUsr.ini"/>
					<Conf_Param name="AppliFirmwareFile" value="NISVI04_firmware.s28"/>
					<Conf_Param name="BootFirmwareFile" value="BOOTNISVI04.s28"/>
					<Conf_Param name="BTFirmwareFile" value="UnspecifiedAsFirmwaresAreNeverUpdated.dfx"/>
					<Conf_Param name="Adapter" value="borneo:/AcqBoardNis04VIAdapter"/>
					<Conf_Param name="ProtocolesServicesFile" value="../../Data/Appli/Params/AcqProtocolServices.xml"/>
					<Conf_Param name="EnumTimeout" value="180" dmtype="int"/>
					<!--Conf_Param name="PortKwpProtocolName" value="PR2003_0.AP" dmtype="string"/-->
					<!-- uncomment this line to executre PR2003_0 in native mode -->
					<Conf_Param name="PortKwpProtocolName" value="PR2000_R.AP"/>
					<Conf_Param name="PortDdl1ProtocolName" value="PRDDL1V2.AP"/>
					<Conf_Param name="EnumPriority" value="1" dmtype="int"/>
				</Conf_Set>
				<!-- Board16 -->
				<Conf_Set name="Board16">
					<Conf_Param name="DriverFile" value="JcaeCan.dll"/>
					<Conf_Param name="DriverIniFile" value="JCAECanIso.ini"/>
					<Conf_Param name="FirmwareFile" value="Applican.s19"/>
					<Conf_Param name="Adapter" value="borneo:/AcqBoard16Adapter"/>
					<Conf_Param name="BusyRetry" value="60"/>
					<Conf_Param name="EnumPriority" value="2" dmtype="int"/>
				</Conf_Set>
				<!-- Board17 -->
				<Conf_Set name="Board17">
					<Conf_Param name="DriverFile" value="JcaeIso.dll"/>
					<Conf_Param name="FirmwareFile" value="Appliiso.s19"/>
					<Conf_Param name="Adapter" value="borneo:/AcqBoard17Adapter"/>
				</Conf_Set>
				<!-- BoardJ2534 -->
				<Conf_Set name="BoardJ2534">
					<Conf_Param name="Adapter" value="borneo:/AcqBoardJ2534Adapter"/>
					<Conf_Param name="APIVersion" value="04.04"/>
					<Conf_Param name="EnumPriority" value="3" dmtype="int"/>
				</Conf_Set>
			</Conf_Set>
			<!--  Tm089755 Firwmare update: only X91 performs it (it is overriden in that application's config file) -->
			<Conf_Param name="FwUpdateBehavior" dmtype="int" value="4" type="integer" min="1" max="4" doc="{UpdateAlways=1;UpdateIfDifferent=2;UpdateIfLower=3;UpdateNever=4}. UpdateIfLower recommanded."/>
			<!-- Acq internals, insignificant impact if changed -->
			<Conf_Param name="ReadingLoopDelay" value="50" doc="the thread reading messages from the driver wakes up every 'ReadingLoopDelay' to ensure application does not want to exit"/>
			<Conf_Param name="OverloadWarningLevel" value="200" doc="a warning message is logged if the ECU answer buffer contains more than 'OverloadWarningLevel' messages"/>
		</Conf_Set>
		<!-- Acquisition -->
	</Conf_Set>
</Conf_Root>
probesConfiguration.logs
Code:
<?xml version="1.0" encoding="UTF-8"?>
<Conf_Root>
					<Conf_Param name="DriverFile" value="JcaeCan_avec_log.dll"/>
					<Conf_Param name="DriverIniFile" value="JCAECanIso_logs.ini"/>
				</Conf_Set>
				<!-- Board16 -->
					<Conf_Param name="DriverFile" value="JcaeIso_avec_log.dll"/>
				</Conf_Set>
				<!-- Board17 -->
					<Conf_Param name="DriverFile" value="Nis04_VI_DrvUsr_avec_log.dll"/>
					<Conf_Param name="DriverIniFile" value="VIDrvUsr_logs.ini"/>
				</Conf_Set>
					<!-- no provisions for logs exist in current version, maybe it will have to be added here in the future -->
				</Conf_Set>
			</Conf_Set>
		</Conf_Set>
	</Conf_Set>
</Conf_Root>
Type de fichier : zip CLIP.zip (5,6 Ko, 84 affichages)
33300 est déconnecté   Réponse avec citation
The Following 5 Users Say Thank You to 33300 For This Useful Post:
bzkmatrix (16/11/2023), kevin22 (01/11/2022), khalil84 (27/11/2022), mohaalba (03/10/2022), sachscott (15/04/2024)
Vieux 21/10/2022, 10h37   #32
madinina84
Avatar de madinina84
madinina84 is on a distinguished road
Par défaut Merci
Envoyé par mohaalba Voir le message
je vous partage Renault CAN Clip v220 et le patch par "julie.long"
Lien en fichier joint
n'oubliez pas like merci svp
MERCI POUR LE PARTAGE
madinina l'ile aux fleurs
madinina84 est déconnecté   Réponse avec citation
Vieux 21/11/2022, 09h04   #33
Maimeun
Avatar de Maimeun
Maimeun is a glorious beacon of lightMaimeun is a glorious beacon of lightMaimeun is a glorious beacon of lightMaimeun is a glorious beacon of lightMaimeun is a glorious beacon of lightMaimeun is a glorious beacon of light
Bonjour, j'ai récupérer le v220 mais je n'arrive pas a le faire fonctionné avec mon ancienne sonde rtl2002. Pourtant j'ai bien patch rtl clone board 16.17.
Quelqu'un a t'il les 2 patch fonctionnels svp
Envoyé de mon SM-G965F en utilisant Tapatalk
Maimeun est déconnecté   Réponse avec citation
Vieux 22/11/2022, 08h35   #34
Maimeun
Avatar de Maimeun
Bonjour personne pour m'aider [emoji17]
Vieux 22/11/2022, 10h53   #35
zatazk
Avatar de zatazk
zatazk is just really nicezatazk is just really nicezatazk is just really nicezatazk is just really nice
bonjour reste a la version 214 pour l'interface rtl
The Following 2 Users Say Thank You to zatazk For This Useful Post:
eescham (15/02/2023), Maimeun (22/11/2022)
Vieux 22/11/2022, 21h14   #36
Maimeun
Avatar de Maimeun
Merci j'vais essayer de trouver sa alors [emoji4]
Vieux 26/11/2022, 17h57   #37
khalil84
Avatar de khalil84
khalil84 has a little shameless behaviour in the past
bonne journée
es que Il fonctionne passthru avec scanmatik?
khalil84 est déconnecté   Réponse avec citation
Vieux 15/02/2023, 16h52   #38
eescham
Avatar de eescham
eescham will become famous soon enough
Par défaut clip 214
Envoyé par zatazk Voir le message
tu aurais la version 214 stp ?
Merci beaucoup
Se prêter aux autres, se donner à soi-même...
eescham est déconnecté   Réponse avec citation
Patch probleme borneo 1 clip ronan4982 LEXIA, PP2000, DiagBox 6 02/03/2022 00h31
clip Renault patch + activation 2029 + DRIVER Redha-TE Renault clip, DDT2000, Nissan consult 9 31/12/2021 22h11
Je cherche patch clip tarik_electronic Renault clip, DDT2000, Nissan consult 5 07/11/2021 07h53
Immo off pour Vito V220 CDI de 2002 type 638.294 nha78 Immobilizer dumps/solutions 2 09/04/2015 11h09
Besoin de renaut patch can clip v130 registration electro_bordeaux1 Renault clip, DDT2000, Nissan consult 1 20/03/2014 21h16
Fuseau horaire GMT +1. Il est actuellement 15h04.
