Précédent   Tlemcen Car electronics > Categorie principale > Section for english users
Section for english users English talking about cars, problems and solutions ...
IMPORTANT MESSAGE FOR OUR USER
si vous avez été banni pour une raison de spam sur le forum (hacked account) c'est parce que votre compte a été utilisé par des Bots, merci d'envoyer un message via le formulaire de contact en bas de cette page afin de récupérer votre compte, les messages/discussions supprimés ne seront malheureusement pas restaurés.
Vieux 26/04/2014, 20h41   #1
biohead
Avatar de biohead
biohead is an unknown quantity at this point
Par défaut Diagbox Windows 7 Install
Have any members on here had issues when installing Diagbox on Windows 7?
I'm using 32-bit, Pro version - in a Virtual Machine on my Mac (VMWare Fusion 6). When it gets to the initial activation, it fails with a status code of 0. I've got the language set to US, I've tried with the network adaptor enabled and disabled, and also with and without UAC working.
If I do exactly the same process using Windows XP, it's works as it should.
I've been using XP + Lexia 46 for some years now, and would like this opportunity to upgrade both the OS and software.
biohead est déconnecté   Réponse avec citation
Vieux 27/04/2014, 07h37   #2
Geri
Avatar de Geri
Geri has a spectacular aura aboutGeri has a spectacular aura aboutGeri has a spectacular aura about
No problems with install Diagbox on Win7 en 32bit. I have also installed Diagbox on pc with Win8.1 en 32 bit. OS must be 32 bit.
Geri est déconnecté   Réponse avec citation
The Following User Says Thank You to Geri For This Useful Post:
adiago (27/04/2014)
Vieux 27/04/2014, 12h28   #3
biohead
Avatar de biohead
I'm using 32-bit Windows 7. Its strange that it works fine with XP, but activation issues with Windows 7. I'm going to try creating a Virtual Machine using a different software first, and then import it into VMWare. I've seen a few posts on the internet that VMWare has caused issues in the past.
Vieux 29/04/2014, 17h25   #4
biohead
Avatar de biohead
As mentioned, it worked fine in Virtual Box. I've tried subsequently importing into VMWare but then Diagbox needs reactivating.
I'll just have to get used to using Virtual Box I guess!
Vieux 16/05/2014, 21h38   #5
Iggie
Avatar de Iggie
Iggie is an unknown quantity at this point
Envoyé par biohead Voir le message
I have installed MD and Diagbox many times on VMware 8/9 without problem.
Iggie est déconnecté   Réponse avec citation
Vieux 17/05/2014, 10h20   #6
biohead
Avatar de biohead
I wonder if VMWare Fusion is a bit different then? It's the latest VMWare fusion 6 running on OS X.
Vieux 19/05/2014, 09h23   #7
adv
Tuto Maker
Avatar de adv
adv is a splendid one to beholdadv is a splendid one to beholdadv is a splendid one to beholdadv is a splendid one to beholdadv is a splendid one to beholdadv is a splendid one to beholdadv is a splendid one to behold
Hey guys, same issue there ! No way to enable DB 7 in a virtual machine with Win7 and VMplayer (even in an XP VM if my memory is good) !
I tried many things arround network NAT, firewall, internet connection sharing, UAC, NO WAY !!!
You're not alone guys ^^
I'll try with VirtualBox !
adv est déconnecté   Réponse avec citation
Vieux 24/05/2014, 05h37   #8
przygodap
Avatar de przygodap
przygodap is an unknown quantity at this point
It is not the problem with vmware VM, but with controler on which boot HDD is insatled. it must be IDE no SCSI, which vmware choose by default (as can not be changed to IDE other way than editing wmx file). As with SCSI you get activation error = 0.
przygodap est déconnecté   Réponse avec citation
The Following User Says Thank You to przygodap For This Useful Post:
biohead (26/05/2014)
Vieux 04/06/2014, 13h53   #9
lurchy666
Avatar de lurchy666
lurchy666 is an unknown quantity at this point
burn the iso to a disc as it has to be installed from a physical disc, i had this problem untill i figured that out, the updates can be done from hard drive but the 1st install has to be done from a disc
lurchy666 est déconnecté   Réponse avec citation
Vieux 24/06/2014, 10h25   #10
BackONct
Avatar de BackONct
BackONct will become famous soon enough
the problem can be that the diagbox installer detects the virtual machine and doesnt install?. Try This
Edit the VM Settings and add this
isolation.tools.getPtrLocation.disable = "TRUE"
isolation.tools.setPtrLocation.disable = "TRUE"
isolation.tools.setVersion.disable = "TRUE"
isolation.tools.getVersion.disable = "TRUE"
monitor_control.disable_directexec = "TRUE"
monitor_control.disable_chksimd = "TRUE"
monitor_control.disable_ntreloc = "TRUE"
monitor_control.disable_selfmod = "TRUE"
monitor_control.disable_reloc = "TRUE"
monitor_control.disable_btinout = "TRUE"
monitor_control.disable_btmemspace = "TRUE"
monitor_control.disable_btpriv = "TRUE"
monitor_control.disable_btseg = "TRUE"
BackONct est déconnecté   Réponse avec citation
The Following User Says Thank You to BackONct For This Useful Post:
betrescudan (31/08/2014)
Vieux 30/07/2014, 05h52   #11
kowalma
Avatar de kowalma
kowalma is an unknown quantity at this point
From my expirience it will be enought to add 1mb IDE drive to VMware virtual machine to make sure that activation code is different than 0
kowalma est déconnecté   Réponse avec citation
Vieux 17/10/2015, 08h49   #12
piranha--
Avatar de piranha--
piranha-- is an unknown quantity at this point
i've used 7.65 on windows 10.
no issues till 16/10. now looking for update
piranha-- est déconnecté   Réponse avec citation
Vieux 17/10/2015, 12h02   #13
bugmenot111
Avatar de bugmenot111
bugmenot111 has a brilliant futurebugmenot111 has a brilliant futurebugmenot111 has a brilliant futurebugmenot111 has a brilliant futurebugmenot111 has a brilliant futurebugmenot111 has a brilliant futurebugmenot111 has a brilliant futurebugmenot111 has a brilliant futurebugmenot111 has a brilliant futurebugmenot111 has a brilliant futurebugmenot111 has a brilliant future
Hello i have just one question? Why are you bothering with Windows 10?
bugmenot111 est déconnecté   Réponse avec citation
diagbox et windows 8.1 tonio5766 LEXIA, PP2000, DiagBox 2 14/04/2014 19h08
diagbox windows 7 32b sur netbook alexio LEXIA, PP2000, DiagBox 0 24/02/2014 20h17
tout les drivers windows pour diagbox deedee LEXIA, PP2000, DiagBox 10 31/07/2013 12h36
Fuseau horaire GMT +1. Il est actuellement 23h37.
