06/12/2023, 03h28 | #1 |
Pouvoir de réputation: 0 |
MMI VIM login generator
1. Select control module 5F in VAG-COM/VCDS 2. Select “Advanced ID – 1A” 3. Decode the value from the “Serial number” field. If there is more than one serial number field, use the first one. VIM Code Generator: Enter the 5F Information Electric Serial number in the box below and click “Generate”. VIM Code 1: VIM Code 2: Always start with VIM Code 1. Write down your codes and with VCDS connected to your car follow the steps below. 4. Select “Security Access – 16” 5. Enter VIM code 1 from the VIM code generator. 6. Click “Do It!”. If you get a “code not valid” message try the alternate code. If the second code does not works it’s likely that your control module doesn’t support VIM adaptation. 7. Select “Adaptation – 10” 8. Select channel 48 9. Click read 10. Set the value to 255 11. Click test 12. Click save 13. Click “Done, Go Back”, close the controller and exit VCDS 14. Reset the MMI. WinRar Password:Κοmotini1-MHH Auto.com |
07/12/2023, 03h36 | #2 | |
MMI_VIMGen
The Following User Says Thank You to komotini1 For This Useful Post: | uncleseb (07/12/2023) |
07/12/2023, 12h25 | #3 |
Pouvoir de réputation: 15 |
Description du logiciel ?
07/12/2023, 13h30 | #4 |
Pouvoir de réputation: 1 |
a priori c'est pour calculer le code de déblocage d'activation de la Video In Motion (VIM) sur les MMI VAG, je vois pas trop l'interet du truc, on trouve des calculateurs comme ça partout sur internet, c'est pas vraiment un calculateur en plus, il isole juste certain chiffre du numéro de série.
Sponsored Link |
Liens sociaux |
Discussions similaires | ||||
Vag pin login | DIAGSYSTEM25 | programmation & synchronisation de clé | 13 | 28/04/2020 13h53 |
Login bsi citroen | haikoaper | Peugeot, Citroën | 7 | 26/04/2014 09h58 |
les code login adaptation vag-com | dichar | Vw, Audi, Skoda, Seat, Bentley | 7 | 20/04/2013 20h10 |
recherche login psa a acheter | touf | Vente, Achat, Echange | 3 | 18/12/2011 19h38 |
dacia login immo off | mehdifree | Immobilizer dumps/solutions | 12 | 13/09/2009 21h21 |
