Vieux 25/07/2009, 16h01   #1
toumi111
T-E Confirmé
Avatar de toumi111
toumi111 is an unknown quantity at this point
Par défaut Auto Tuning & Diagnostic Software
1- AutoEnginuity ScanTool 6.0.2 for PC
AutoEnginuity's® OBD2 Scan Tool Performance Analyzer
Don't buy into claims of increased horsepower or added torque; you can verify whether that new, expensive part really works. Do your own dynamometer and acceleration testing at your own convenience and without having to rent expensive dynamometer time.
With AutoEnginuity's® SpeedTracer you can measure:
AutoEnginuity's ScanTool PC-based OBD2 Connector
* 0-60ft time
* 0-60 MPH
* 1/8 mile time
* 1/8 mile speed
* 1/4 mile time
* 1/4 mile speed
* G Forces
* SAE Horsepower
* Torque
* Boost Pressure
* SAE Horsepower and Torque vs RPM graphing
* Speed vs Time graphing
Note: Work with Autoenginuity OBD cable (original or cloned)
2- Carsoft BMW 6.5
Manufacturer-information about the control units, reading out the complete fault storage, concrete repair-information to nearly every stored fault, erasing of the fault storage & reset function, component activation, important adjustments, printing out a diagnostic-report, New Live Data, Synchronization, Service Interval Management, Coding, Adaptation, Smooth Running Test / Injector Test etc.
3- Carsoft Mercedes-Benz 7.4
Manufacturer-information about the control units reading out the complete fault storage, concrete repair-information to nearly every stored fault, erasing of the fault storage & reset function, life data, service Interval reset and other important adjustments, printing out a diagnostic-report, New CODING, ADAPTATION, LIVE DATA ACTIVATIONS, TEST, Freeze Frame Data etc...
4-Renault DDT2000 (Diagnostics SW for Renault)
5- Digimoto 4.03
Digimoto is a software application that uses a elm interface to talk to your vehicle. It is an application that is used primarily to assist in vehicle diagnostics (reading sensors, clearing error codes), but also offers many other valuable tools. It can also be used to measure vehicle performance and the state of your vehicle's systems at any given point in time.
6- Diagnose 4.1
These programs run on a PC and communicate with the interface. They will run on most computers which have a serial port. (Some PCs only have USB ports, but you may be able to use a USB/serial convertor cable) The programs can also run in a "simulated" mode even if there is no serial port, interface, or vehicle attached. This allows you to examine the program or learn how it works. The programs are full versions, not Demos; they will work with BR interfaces.
Features:
* Monitors general Obd-2 data: Fuel system (open/ loop status), Engine load, Coolant temperature, Manifold Pressure, Engine Rpm, Vehicle speed, Timing advance, Intake air temperature, Intake air flow rate, Throttle position, Secondary air status.
* Multiple display modes; Digital, graph, or gauge style displays.
* Selectable units; Metric or English (U.S)
* Oxygen sensor Voltage / Current and Fuel trim plots. Works with conventional or wideband sensor types.
* On-board test results (also called Obd2 readiness); Indicates whether each test category or subsystem test has been completed (passed). Often used as a criterion in emission testing.
* On board tests (detailed report); Numeric values of individual test IDs that the vehicle has performed with test limits.
* Freeze frame; Standard data stored by the vehicle at the instant it set a diagnostic trouble code (DTC).
* Diagnostic trouble code reader; Displays "P" codes, including manufacturer specific codes reported under mode 3.
o Automatic or manual code definition lookup (all standard Obd II codes and most manufacterer specific dtc).
o Ability to enter any arbitrary code for lookup purposes.
o Ability to periodically poll for active trouble codes and malfunction indicator lamp status while simultaneously monitoring other types of data.
* Pending trouble codes: These are similar to normal trouble codes, but they are set after a single driving cycle, and usually before the check engine light is illuminated. Useful after repair work has been finished.
* Clear function; Requests vehicle to clear its diagnostic trouble codes, on board test results, and freeze frame data.
* DataLogger; Optionally records and reads back most raw data on disk drive.
o Timetag option to periodically insert computer time into data stream.
o Place Markers can be inserted into file to facilitate locating the same position later.
o Playback functions: Sequential (single step or continuous), Jump to record numbers or place markers, rewind.
* Printout; Option to send most data to the default system printer.
* Mileage monitor; Computes miles per gallon (instantaneous and averaged) as well as cumulative fuel used and distance travelled. Currently calibrated for gasoline engines only.
* Simulate mode; Runs without interface attached. Useful to explore and become familiar with the program.
7- ECM2001 3.2 (SW for ECU remapping)
8-Fiat Finalist 1.0 (Diagnostics SW for Fiat)
9-FordScan 2.02 (Diagnostics SW for Ford)
10-Galleto 1.2.5.0 (SW for ECU flashing)
11-BMW INPA 5.0 (Diagnostics SW for BMW)
12-KWP2000 (SW for ECU flashing)
13-OBDTool 1.2.60 (Diagnostics SW for VAG)
14-Opel-Tech2 (Diagnostics SW for Opel)
15-PCMScan 2.4.5
PCMSCAN is a fully featured generic OBD-II scanner and diagnostic tool that supports a wide variety of OBD-II hardware interfaces. It allows viewing, charting, logging and playback of diagnostic data in real time via the vehicle's OBD-II diagnostic data port. It also allows viewing of vehicle Diagnostic Trouble Codes (DTC's), Freeze Frame data, and other vehicle information.
16-VAG Eeprom Programmer
17-VAG-COM 311.2+VAG-COM 409.1+VAG-COM 704.1
VAG-COM is the first aftermarket VAG-Tool that:
* Is fully compatible with all VW, Audi, Seat and Skoda models through 2007, including models using a direct CAN connection for diagnostics.
* Has a database of more than 9000 fault-codes and measuring-block texts.
* Can use the new 7-Digit PIN/SKC codes to match new keys in all immobilizer equipped VW/Audi/Seat/Skoda models.
* Allows you to view, log, and graph 3 groups of Measuring Blocks at once
* Can access all control modules which require proprietary VAG modes running the new KWP-2000 protocols (2001+ Teves Mk.60 ABS, numerous 2002+ modules)
* Can display critical timing information on TDI engines in graphic form
18-Vol-FCR 1.3.06 (Diagnostics SW for Volvo)
19-VW-AUDI LOGIN READER 3.08 (immo)
20-Webasto Thermo Test
21-OPEL TIS 2008
All you need for OPEL, Diagnostic, ECU tuning...
22-Tuning Car Studio 2008
Tuning Car Studio is a premiere software package, allowing users to tune their cars with nothing more then the picture of their vehicle.
By uploading a photo of the car to the program, users can instantly change the bodywork color or choose new aluminum rims. Most elements of the car's frame can be changed with the available tools in a second - add new stickers, type words or slogans, or add headlamp eyebrows... in a moment! The program also gives you the ability to shade the head and rear lamps, and the windows. All the optical car tuning changes can be instantly viewed in the program. The new design can then be printed on paper. During their design work, users can listen to any music they wish, thanks to the inbuilt MP3 player. Using TUNING CAR STUDIO is easy and intuitive. All the tools are thoroughly described in the help file, implemented into the program.
If you're looking to tune your car and design new elements, remember to try it out first in TUNING CAR STUDIO - the latest optical car tuning software utility.
23-Car Electronic and Diagnostic
CAPS (Computer Aided Problem Solving) software is invaluable in helping to diagnose faults within modern electronically controlled vehicle systems.
CAPS is essentially a practical fault diagnostic workshop manual on computer screen for engine management systems, fuel injection, ABS, traction control, SRS and automatic transmission. Instead of thumbing through many bulky manuals the correct specific information can be quickly and easily accessed through a user-friendly menu with the click of a mouse button.
24-CAR CODE CALCULATORS
Car Stereos Unlockers
Audi - VW
Becker
Blaupunkt
Calcgen
Car radio code calculator v1.1
Clarion
Daewoo
Dump collection
Ford
Grundig
Hyundai
Mercedes Alpine 10
Philips
Volvo
Ford radio code finder
25-All 1979-2007 Vehicle Wiring Diagrams v4.2
Code:
ACURA
1997-2004 CL
2002-2006 EL
1986-2001 Integra
1986-1995 Legend Sedan
1987-1995 Legend Coupe
2001-2006 MDX
1991-2005 NSX
1997-2002 NSX-T
2007-2007 RDX
1996-2007 RL
2002-2006 RSX
1996-2000 SLX
1995-2007 TL
2004-2007 TSX
1995-2006 Type S
1991-1994 Vigor
ALFA ROMEO
1990-1994 164
1984-1989 Graduate
1983-1986 GTV-6
1987-1989 Milano
1984-1992 Quadrifoglio
1987-1993 Spider Veloce
AMC
1983-1987 Alliance
1979-1981 AMX
1979-1983 Concord
1983-1987 Eagle
1984-1986 Encore
1987-1987 GTA
1979-1979 Pacer
1979-1983 Spirit
AUDI
1988-1992 80
1988-1994 90
1989-1994 100
1992-1993 100 Quatro
1989-1993 200
1992-1993 200 Quatro
1980-1987 4000
1980-1990 5000
1985-1988 5000 Quatro
1995-2007 A4
1995-2007 A6
2007-2007 A7
1997-2007 A8
2001-2004 Allroad
1995-1996 Cabriolet
1993-2002 S4
2002-2004 S6
2003-2003 S8
1999-2008 TT Coupe
1999-2008 TT Roadster
BMW
1995-2005 3 Series
1983-1994 318i
2002-2002 325ci
1984-1987 325e
1984-1987 325es
1984-1996 325i
1992-1996 325i Conv
1988-1991 325ic
1984-1996 325is
2002-2002 330ix
1991-2003 5 Series
1985-1986 524td
1989-1990 525i
1982-1988 528e
1983-1984 533i
1985-1991 535i
1987-1988 535is
1987-1988 535 M5
2006-2006 545
1984-1984 633csi
1985-1991 635csi
1998-2001 7 Series
1984-1984 733i
1985-1992 735i
1988-1992 735il
1993-1995 740i
1993-1995 740il
1988-1993 750il
1993-1998 8 Series
1991-1993 850i
1987-1987 L7
2003-2003 M3
1999-2002 M3 Coupe
1996-2002 M3 Roadster
2003-2003 M5
1987-1987 M6
2006-2007 X3
2001-2006 X5
1999-2002 Z3 Coupe
1996-2002 Z3 Roadster
1996-2002 Z3 Series
2003-2005 Z4 Series
2001-2003 Z8
BUICK
1981-2005 Century
1987-1990 Electra
2005-2007 Lacrosse
1983-2005 LeSabre
2006-2007 Lucerne
1985-2005 Park Ave
1997-2002 Park Ave Ultra
2004-2007 Rainier
1988-1991 Reatta
1988-2004 Regal
1978-1988 Regal (RWD)
2002-2007 Rendezvous
1979-1999 Riviera
1991-1996 Roadmaster
1983-1989 Skyhawk
1980-1998 Skylark
1985-1988 Somerset
2005-2007 Terraza
CADILLAC
1988-1993 Allante
1985-1995 Brougham
1997-2002 Catera
1982-1988 Cimarron
1994-1999 Concours
1980-1993 Coupe Deville
2003-2007 CTS
1987-2005 DeVille
2006-2007 DTS
1978-2002 Eldorado
1999-2007 Escalade
2003-2007 Escalade ESV
2002-2007 Escalade EXT
1980-1996 Fleetwood
1978-1993 Sedan Deville
1984-2004 Seville
2004-2007 SRX
2005-2007 STS
2004-2007 XLR
CHEVROLET
1985-2005 Astro
2002-2007 Avalanche
2004-2007 Aveo
1987-1996 Beretta
2004-2005 Blazer
1979-1994 Blazer Full Size
1978-2002 Camaro / Z28
1981-1996 Caprice
1982-2005 Cavalier
1981-1990 Celebrity
1983-1987 Chevette
1980-1985 Citation
2005-2007 Cobalt
2004-2007 Colorado
1987-1996 Corsica
1980-2007 Corvette
1980-1987 El Camino
2005-2007 Equinox
1997-2007 Express
1978-2007 Full Size Pickup
2006-2007 HHR
1981-2007 Impala
1994-1996 Impala SS
1990-2000 Lumina
1990-1996 Lumina APV
1980-2007 Malibu
2004-2005 Malibu Classic
2004-2007 Malibu Maxx
1999-2000 Metro
1980-2007 Monte Carlo
1985-1988 Nova
1999-2002 Prizm
1982-2004 S-10 Blazer
1982-2004 S-10 Pickup
2003-2007 Silverado
1985-1988 Spectrum
1987-1988 Sprint
2003-2006 SSR
1982-2007 Suburban
1995-2007 Tahoe
1999-2004 Tracker
2002-2007 Trailblazer
2005-2007 Uplander
1983-1998 Van
1997-2005 Venture
CHRYSLER
2005-2007 300
2005-2007 300C
1999-2006 300M
2007-2007 Aspen
1995-2000 Cirrus
1993-2004 Concorde
1980-1983 Cordoba
2004-2007 Crossfire
1983-1984 E Class
1983-1993 Fifth Avenue
1981-1993 Imperial
1988-1995 Lebaron Conv
1987-1994 Lebaron Coupe
1985-1988 Lebaron GTS
1983-1994 Lebaron Sedan
1993-2001 LHS
1979-1997 New Yorker
2004-2007 Pacifica
2001-2002 Prowler
2001-2007 PT Cruiser
1996-2008 Sebring Conv
1995-2006 Sebring Coupe
2001-2007 Sebring Sedan
1984-2007 Town & Country
2001-2003 Voyager
DAEWOO
1999-2002 Lanos
1999-2002 Leganza
1999-2002 Nubira
DAIHATSU
1988-1992 Charade
1990-1992 Rocky
DODGE
1983-1983 400
1983-1988 600
1995-2000 Avenger
2006-2007 Caliber
1984-2007 Caravan
1983-1983 Challenger
2006-2007 Charger
1984-1996 Colt
1984-1993 Colt Vista
1989-1991 Colt Wagon
1984-1989 Conquest
1987-2007 Dakota
1984-1993 Daytona
1983-1990 Diplomat
1998-2007 Durango
1988-1993 Dynasty
1984-2006 Grand Caravan
1993-2006 Intrepid
1985-1989 Lancer
2005-2007 Magnum
1980-1983 Mirada
1990-1992 Monaco
1995-2005 Neon
2007-2007 Nitro
1980-1990 Omni
1986-1989 Raider
1981-1993 Ram 50
1981-1993 Ram D50
1983-2005 Ram Full Size Pickup
2006-2007 RAM 1500
2006-2007 RAM 2500
2006-2007 RAM 3500
1983-2003 Ram Van
1983-1994 Ramcharger
1983-1984 Rampage
1987-1994 Shadow
1989-1995 Spirit
2003-2007 Sprinter
1991-1997 Stealth
1995-2000 Stratus
2001-2006 Stratus Coupe
2001-2006 Stratus Sedan
1996-2002 Viper GTS/RT/10
2003-2008 Viper SRT/10
EAGLE
1988-1988 Medallion
1988-1992 Premier
1989-1996 Summit
1989-1996 Summit Wagon
1990-1998 Talon
1993-1997 Vision
FERRARI
1983-1983 308
1988-1988 328
1992-1992 348
1990-1990 Testarossa
FORD
1986-1997 Aerostar
1995-1997 Aspire
1983-1996 Bronco
1984-1990 Bronco II
1995-2000 Contour
1983-2007 Crown Victoria
1983-2007 Econoline / E-Series
2007-2007 Edge
2001-2008 Escape
1981-2003 Escort
1997-2003 Escort ZX2
2000-2005 Excursion
1981-1985 E X P
1997-2007 Expedition
1989-2007 Explorer
2002-2003 Explorer Sport
2001-2006 Explorer Sport Trac
1988-1994 Festiva
2005-2007 Five Hundred
2000-2007 Focus
2004-2007 Freestar
2005-2007 Freestyle
2007-2007 Fusion
1979-1986 LTD
1979-2007 Mustang
1983-1996 F-Series
1997-2007 F-150
1997-2007 F-Series Super Duty
2006-2007 F-650
2006-2007 F-750
2006-2007 Fusion
2005-2006 GT
1979-1980 Pinto
1989-1997 Probe
1984-2007 Ranger
1986-2006 Taurus
1984-1994 Tempo
1980-1997 Thunderbird
2002-2005 Thunderbird II
1995-2003 Windstar
GEO
1989-1998 Metro
1989-1998 Prizm
1989-1989 Spectrum
1990-1993 Storm
1989-1998 Tracker
GMC
1983-1987 Caballero
2004-2007 Canyon
1991-1993 Cyclone
1999-2002 Denali
1999-2007 Envoy
2002-2007 Envoy XL
2004-2005 Envoy XUV
1978-1991 Full Size Jimmy
1981-2007 Full Size Pickup
1995-2001 Jimmy
1983-2001 S-15 Jimmy
1982-1994 S-15 Pickup
1985-2005 Safari
2003-2007 Savana / Van
2003-2007 Sierra / Sierra Denali
1991-2006 Sonoma
1982-2002 Suburban
1991-1993 Typhoon
1987-1995 Vandura
1992-2007 Yukon
2003-2007 Yukon Denali
2000-2007 Yukon XL
2003-2007 Yukon XL Denali
HONDA
1979-2007 Accord
2006-2007 Accord Hybrid
1980-2007 Civic
1993-1998 Civic Del Sol
1997-2007 CR-V / CRV
1985-1991 CRX
2003-2007 Element
2006-2007 FIT
2000-2006 Insight
1995-2007 Odyssey
1995-2003 Passport
2003-2007 Pilot
1983-2001 Prelude
2006-2007 Ridgeline
2000-2007 S2000
HUMMER
2002-2007 H1
2003-2007 H2
2006-2007 H3
HYUNDAI
1995-2007 Accent
2006-2007 Azera
1992-2007 Elantra
2007-2007 Entourage
1986-1994 Excel
2001-2007 Santa Fe
1991-1995 Scoupe
1989-2007 Sonata
1998-2007 Tiburon
2005-2007 Tuscon
2001-2002 XG300
2001-2003 XG350
INFINITI
2003-2007 FX35
2003-2007 FX45
1991-2002 G20
2003-2007 G35 Coupe
2003-2007 G35 Sedan
1996-2001 I30
2002-2005 I35
1993-1997 J30
1990-1992 M30
2006-2007 M35
2003-2007 M45
1990-2005 Q45
1996-2005 QX4
2004-2005 QX45
2004-2007 QX56
ISUZU
1989-2000 Amigo
2003-2007 Ascender
2001-2004 Axiom
1996-2002 Hombre
2006-2007 I-280
2006-2007 I-350
1982-1989 I-Mark
1984-1994 Impulse
1996-2000 Oasis
1981-1995 Pickup
1991-2004 Rodeo / Rodeo Sport
1991-2004 Rodeo Sport
1990-1994 Stylus
1988-2002 Trooper
1984-1991 Trooper II
1999-2002 Vehicross
JAGUAR
2000-2007 S-Type
2002-2007 X-Type
2004-2004 XJ-Series
1980-1997 XJ6
1986-1987 XJ6 III
1998-2003 XJ8
1994-1996 XJ12
1998-2003 XJR
1982-1996 XJS
1997-2006 XK8
2000-2006 XKR
JEEP
1983-2001 Cherokee
1997-2001 Cherokee Sport
2006-2007 Commander
2007-2007 Compass
1983-1986 CJ5
1983-1986 CJ7
1986-1992 Comanche
1993-2007 Grand Cherokee
1984-1994 Grand Wagoneer
2002-2007 Liberty
1983-1987 Pickup
1983-1986 Scrambler
1983-1990 Wagoneer
1987-2007 Wrangler
KIA
2004-2007 Amanti
2002-2003 Magentis
2001-2007 Optima
2001-2007 Rio / Rio5
2007-2007 Rondo
2002-2007 Sedona
1996-2002 Sephia
2003-2007 Sorento
2000-2007 Spectra
1995-2007 Sportage
LAND ROVER
1995-1995 4.0SE
1993-1997 Defender
1994-1999 Discovery
2000-2004 Discovery II
2002-2006 Freelander
2005-2006 LR3
1997-2005 Range Rover
LEXUS
1990-1991 ES 250
1992-2003 ES 300
2004-2007 ES 330
1993-2007 GS 300
1998-2000 GS 400
2001-2007 GS 430
2003-2007 GX 470
2006-2007 IS 250
2001-2005 IS 300
2006-2007 IS 350
1990-2000 LS 400
2001-2007 LS 430
2007-2007 LS 460
1996-1997 LX 450
1998-2007 LX 470
1999-2003 RX 300
2004-2007 RX 330
2006-2007 RX Hybrid
1992-2001 SC 300
1992-2001 SC 400
2002-2007 SC 430
LINCOLN
2003-2007 Aviator
2002-2002 Blackwood
1983-2002 Continental
2000-2006 LS
1988-1992 LSC
2006-2007 Mark LT
1980-1983 Mark VI
1984-1992 Mark VII
1993-1999 Mark VIII
2007-2007 MKX
2007-2007 MKZ
1997-2007 Navigator
1997-2007 Navigator L
1981-2006 Town Car
2006-2007 Zephyr
MASERATI
1974 Bora
MAZDA
1986-1996 323
1983-2002 626
1988-1996 929
2003-2007 B-Series Pickup
1979-1986 B2000
1982-1993 B2200
1994-1998 B2300
1998-2002 B2500
1987-1993 B2600
1994-2002 B3000
1994-2002 B4000
2007-2007 CX-7
1981-1983 GLC
1982-1985 GLC Wagon
2004-2007 Mazda3
2006-2007 MAZDASPEED3
2006-2007 Mazda5
2003-2007 Mazda6
2006-2007 MAZDASPEED6
1990-2007 Miata
1994-2002 Millenia
2002-2004 MP3 / Protege 5
1989-2006 MPV
1992-1996 MX-3
1990-2007 Miata MX-5
1988-1997 MX-6
1991-1995 Navajo
1990-2004 Prot?g?
1982-1996 RX7
2004-2007 RX-8
2001-2007 Tribute
MERCEDES BENZ
1984-1993 190D
1984-1993 190E
1979-1983 240D
1987-1988 260E
1979-1993 280CE
1979-1981 280E
1979-1979 300
1988-1992 300 Series
1980-1985 300CD
1980-1992 300D
1986-1993 300E
1983-1985 300SD
1986-1987 300SDL
1992-1992 300SE
1991-1991 300SL
1979-1987 300TD
1991-1992 350 Series
1985-1985 380SE
1982-1983 380SEL
1982-1985 380SL
1988-1992 400 Series
1992-1993 400E
1986-1991 420SEL
1988-1992 500 Series
1993-1993 500SEL
1991-1992 500SL
1986-1991 560SEC
1986-1991 560SEL
1986-1991 560SL
1994-2003 C Class
1994-1996 C220
1997-2000 C230
1994-2000 C280
1998-1999 CL Class
1998-2000 CLK Class
1996-2002 E Class
1995-1996 E300
1994-1996 E320
1993-1993 E320 Conv
1994-1996 E420
1994-1994 E500
2001-2006 ML Class
1998-2000 ML320
1999-2000 ML430
1994-2003 S Class
1994-1997 S320
1994-1997 S420
1994-1997 S500
1996-1996 S600
1998-1999 SL Class
1990-1992 SL300
1990-1995 SL500
1996-1996 SL600
1998-2002 SLK Class
1998-1998 Vito
MERCURY
1979-1980 Bobcat
1979-1994 Capri
1980-2002 Cougar
1980-2007 Grand Marquis
1982-1983 LN-7
1981-1987 Lynx
2003-2004 Marauder
2005-2008 Mariner
2006-2007 Milan
2005-2007 Montego
2004-2007 Monterey
1997-2007 Mountaineer
1995-2000 Mystique
1987-2005 Sable
1984-1994 Topaz
1987-1999 Tracer
1993-2002 Villager
MERKUR
1988-1989 Scorpio
1985-1988 XR4T1
MINI
2002-2007 Cooper
2002-2007 Cooper Conv
MITSUBISHI
1991-1999 3000GT
1983-1988 Cordia
1992-2005 Diamante
1989-2007 Eclipse
2004-2007 Endeavor
1992-1995 Expo
1985-2007 Galant
2003-2007 Lancer
2005-2007 Lancer Evolution
2004-2004 Lancer Sportback
1981-1996 Mighty Max
1985-2001 Mirage
2002-2002 Mirage Coupe
1987-2006 Montero
1997-2004 Montero Sport
2003-2006 Outlander
1987-1993 Precis
1990-1991 Sigma
1984-1989 Starion
1983-1988 Tredia
1987-1991 Van
1987-1991 Wagon
NISSAN
1980-1998 200SX
1989-1998 240SX
1979-1983 280ZX
1984-1996 300ZX
2003-2007 350Z
1993-2007 Altima
2004-2007 Armada
1989-1990 Axxess Van
1998-2007 Frontier
1982-2007 Maxima
2003-2007 Murano
1987-2007 Pathfinder
2004-2007 Pathfinder Armada
1980-1997 Pickup
1983-1994 Pulsar
1993-2007 Quest
1982-2007 Sentra
2001-2001 Skyline GTR
1982-1992 Stanza
1986-1988 Stanza Wagon
2004-2007 Titan
1987-1988 Van
2007-2007 Versa
2000-2007 Xterra
OLDSMOBILE
1992-1998 Achieva
1999-2004 Alero
1995-2003 Aurora
1991-2004 Bravada
1983-1992 Custom Cruiser
1997-1999 Cutlass
1985-1991 Cutlass Calais
1982-1996 Cutlass Ciera
1989-1995 Cutlass Cruiser
1981-1997 Cutlass Supreme
1983-1990 Delta 88
1991-1999 Eighty-Eight
1998-1999 Eighty-Eight LSS
1983-1988 Firenza
1998-2002 Intrigue
1983-1998 Ninety-Eight
1980-1984 Omega
1997-1999 Regency
1990-2004 Silhouette
1981-1992 Toronado
1990-1992 Touring Sedan
1989-1992 Trofeo
PLYMOUTH
1989-1995 Acclaim
1996-2000 Breeze
1985-1988 Caravelle
1992-1993 Colt Vista
1993-1994 Duster
1983-1989 Grand Fury
1980-1990 Horizon
1984-1994 Laser
1995-2001 Neon
1999-2000 Prowler
1983-1989 Reliant
1983-1983 Sapporo
1983-1983 Scamp
1987-1994 Sundance
1983-1987 Turismo
1983-2000 Voyager
PONTIAC
1981-1991 6000
1986-1989 6000 STE
2001-2005 Aztek
1980-2005 Bonneville
1984-1988 Fiero
1981-2002 Firebird
2007-2007 G5
2005-2007 G6
1985-2006 Grand AM
1980-2007 Grand Prix
2004-2007 GTO
1982-1987 J2000
1988-1993 LeMans
1998-2006 Montana
2004-2006 Montana SV6
1984-1986 Parisienne
1980-1984 Phoenix
1997-2000 Savana
2006-2007 Solstice
1984-1994 Sunbird
1995-2005 Sunfire
1983-1987 T1000
2006-2007 Torrent
1990-2000 Transport
2003-2007 Vibe
PORSCHE
1984-1988 911 Carrera
1989-1993 911 Carrera 2/4
1995-1998 911 Carrera 993
1999-2004 911 Carrera 996
1979-1983 911 SC
1979-1987 924
1979-1992 928
1979-1984 928 S
1983-1992 944
1992-1995 968
1997-2004 Boxster
SAAB
2005-2006 9-2X
1999-2007 9-3 Conv
1999-2007 9-3 Sports Sedan
2006-2007 9-3 SPORTCOMBI
1998-2007 9-5
2005-2007 9-7
2006-2007 9-7 / 9-7X SUV
1980-1998 900
1986-1993 900 Conv
1986-1996 9000
SATURN
2007-2007 Aura
1998-1999 Coupe
2003-2007 ION
2000-2005 L-Series
2005-2007 Relay
2006-2007 Relay2
2006-2007 Relay3
2000-2002 S-Series
1991-2002 SC Coupe
1998-1999 Sedan
2007-2007 SKY
2007-2007 SKY Conv Redline
1991-1997 SL Sedan
1993-1997 SW Wagon
2002-2007 Vue
1998-1999 Wagon
SCION
2004-2007 Scion xA
2004-2007 Scion xB
2005-2007 Scion tC
SUBARU
1982-1983 1600
1982-1984 1800
2006-2007 B9 Tribeca
2003-2007 Baja
1984-1987 Brat
1987-1989 Coupe
1984-1984 DL
1998-2007 Forester
1979-1981 General
1984-1984 GL
1985-1988 Hatchback
1995-2007 Impreza
1996-1999 Impreza Outback
1987-1993 Justy
1990-2007 Legacy
1995-1999 Legacy Outback
1990-1993 Loyale
1999-2007 Outback
2000-2002 Outback Sport
1985-1989 Sedan
1992-1997 SVX
2007-2007 SX4
1985-1989 Wagon
1985-1991 XT Coupe
1988-1991 XT-6
SUZUKI
2002-2007 Aerio
1995-2002 Esteem
2004-2007 Forenza
1999-2007 Grand Vitara
2005-2007 Reno
1986-1993 Samurai
1989-1999 Sidekick
1989-2001 Swift
2004-2006 Verona
1999-2004 Vitara
1996-1998 X-90
2001-2006 XL-7
TOYOTA
1984-2007 4Runner
1995-2007 Avalon
1983-2007 Camry
1999-2007 Camry Solara
1982-2005 Celica
1983-2007 Corolla
2003-2006 Corolla Matrix
1980-1994 Cressida
2000-2006 Echo
2006-2007 FJ Cruiser
2001-2007 Highlander
2006-2007 Highlander Hybrid
1979-2007 Land Cruiser
2003-2007 Matrix
1985-2005 MR2
1992-1998 Paseo
1982-1995 Pickup
1991-1997 Previa
2001-2005 Prius
1996-2007 RAV4
2001-2007 Sequoia
1998-2007 Sienna
1999-2007 Solara
1983-1984 Starlet
1982-1999 Supra
1993-1999 T100
1995-2007 Tacoma
1981-1999 Tercel
2000-2007 Tundra Access Cab
2000-2007 Tundra Double Cab
2000-2007 Tundra Standard Cab
1984-1989 Van
2006-2007 Yaris
VOLKSWAGEN
1998-2007 Beetle
1995-2002 Cabrio
1986-1993 Cabriolet
1990-1995 Corrado
1992-1992 Corrado
1993-2003 Euronvan
1987-1993 Fox
1985-2004 Golf
1993-1998 Golf III
1995-2007 GTI
1981-2007 Jetta
1991-2007 Passat
1982-1982 Quantum
2007-2007 Rabbit
1979-1988 Scirocco
1980-1991 Vanagon
VOLVO
1981-1993 240 Series
1985-1992 740 Series
1983-1990 760 Series
1987-1990 780
1993-1997 850
1991-1995 940 Series
1992-1997 960
1998-2004 C70
1999-2004 C70 Conv
2000-2007 S40
2001-2007 S60
1998-2000 S70
1999-2006 S80
1998-2000 S90
2000-2004 V40
2005-2007 V50
1998-2007 V70
1998-1999 V90
2003-2007 XC70
2003-2006 XC90
26-Peugeot Service Box
27-Volkswagen - Audi ETKA 7 + Updates
ETKA stands for "Elektronische Teilkatalog" - or electronic parts catalogue, for Volkswagen and Audi. It's easy to use even for dummies. It contains very detailed informations about every part of any Volkswagen or Audi created from the begining until today, and that is the reason what makes this program perfect also for old timer collectors.
It has an individual search option using unique chassis number of a car, so if you are buying a used car you can see the exact data how it was when it was produced, what color it was, what kind of audio and other equipment it had, what kind of seats, headlights, extras... so you can easily discover if the one that you are buying has been modified by some means...
ETKA is automatically installed with more than 10 languages... English, German, Italian, Russian, Spanish...
Please, READ THE INSTRUCTIONS ABOUT INSTALLING UPDATES, IT'S VERY EASY IF YOU JUST READ IT!!!
All around the web you will find new updates as the time passes. There are some updates for Skoda and Seat cars also. Works on all kinds of windows, both 64 and 32 bit, except older than XP. Works even under virtual machines.
toumi111 est déconnecté   Réponse avec citation
The Following User Says Thank You to toumi111 For This Useful Post:
thundermasta (27/07/2009)
Sponsored Links
Vieux 27/07/2009, 23h13   #2
thundermasta
Avatar de thundermasta
Pouvoir de réputation: 4
thundermasta is on a distinguished road
slt,je vois que vous ettes amateur de tuning,bien venus au club:5: je suis tuner pratiquant avec plusieures realisations a mon actif
thundermasta est déconnecté   Réponse avec citation
Vieux 11/06/2010, 17h29   #3
radoine
Avatar de radoine
radoine is an unknown quantity at this point
Mode service tvc condor slim74
radoine est déconnecté   Réponse avec citation
Bookmarks
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is oui
software qwerty Outils de diagnostique 4 01/11/2009 10h38
Carchip-tuning (Surprise) toumi111 Vente, Achat, Echange 0 25/07/2009 15h30
User guide diagnostic Delphi bzkmatrix Renault, Dacia, Nissan 0 20/07/2009 00h20
Upa Software francois 58 Programmeur de chip 4 15/01/2009 23h26
Chip Tuning WINDOWW Chiptuning 6 28/12/2008 09h13
Fuseau horaire GMT +1. Il est actuellement 07h21.
- GSM-ALGERIE - [ Box & outils Gsm ] - Guide Algérie- Musique Algérienne - Musique Kabyle - Bled Music" - Clinique-Auto: L'attelier Officiel T-E - Rafplus.com le gratuit sur internet - presse algerie - OBDFR.COM, France Diag - Vente Algerie - Info Algerie - Dz-Vendre:Publiez votre Annonce Gratuitement - Informastore - Boutique Informatique & Multimedia - Sat-Hitec
Flag Counter
