Vieux 22/11/2023, 15h57
munga
Avatar de munga
munga is an unknown quantity at this point
bonjour , je connais le probleme du changement de langue , c'est pas simple mise à jour qui va resoudre le probleme .
J'en ai deja eu quelque un avec ce cas là , faut que je retrouve l'info que j'avais recu de chez Skoda
---------- Post added at 15h57 ---------- Previous post was at 15h53 ----------
This CD shall solve the "Language Change not possible" problem reported by
Skoda, which may appear after an update with SWL-CD using SW 6276 or SW 5274.
Attention: Please use this CD only for this use case!
How to proceed:
1) PIN input necessary:
If the RNS starts with PIN input screen, please enter the PIN.
Acknowledge all the "Language" poups. If the RNS does not react on button
presses and shows a popup without possiblity for acknowledge,
please restart the RNS via "3 finger reset" and continue with 2)
2) No PIN input necessary:
3)
Insert the CD 99980. Acknowledge the popup with "Continue".
After the "Please Wait" disappears, wait for about 1min.
Press the Eject-Button and remove the CD.
4)
Restart the RNS via "3 Finger Reset"
5)
Wait (about 2-3min) till the language change is executed automatically.
The RNS is not able to run the change successfully, so acknowledge all the
"Language" poups.
6)
Change to "Setup" menue and select "System". Press the "Factory Settings"
(down below) and select (also down below) the "System". Execute the reset.
No again a language change is executed. There appears a popup showing
"Die gewünschte Sprache wird geladen...". When the display (bar graph) is
completed, please wait for about 1 min.
Remark: the popup stays in foreground even when pressing other buttons
(e.g. "MAP").
7)
8)
Check if the change was successful by pressing "MAP" and afterwards the right
DDS. A German announcement "Die Zielführung ist nicht aktiviert" should be
hearable.
9)
Ready. The customer can choose now the wanted language.
munga est déconnecté   Réponse avec citation
