Discussion: programmation clé
Vieux 24/02/2013, 13h26
meca
Avatar de meca
meca is a name known to allmeca is a name known to allmeca is a name known to allmeca is a name known to allmeca is a name known to allmeca is a name known to all
je crois avec op-com tu peut recuperer le code sur tigra en lisant l'eprom ecu depuis op-com voici:
For programming new keys and immoboliser, functions the Security Code is required.
This code can normally be found on the Pass. Unfortunately, the Car Pass is often lost.
With OP-COM you can read the security code from the following models:
 Corsa-C
 Meriva
 Tigra-B
Model selection
Corsa-C / Meriva / Tigra-B
 Choose Body
 Choose Instrument
 Choose EPROM info
 Now the Security Code can be read from EPROM
bon courage
meca est déconnecté   Réponse avec citation
The Following 3 Users Say Thank You to meca For This Useful Post:
4@nt00ra (04/01/2014), br25 (30/08/2014), MecaTech (28/08/2013)
