Vieux 03/02/2024, 00h24
Zabrzanin94
Avatar de Zabrzanin94
Zabrzanin94 is an unknown quantity at this point
Open the hood of the car and remove the cover on the left side of the windshield.
The engine controller is located there.
Disconnect the cable harness and check the connector to see if power is reaching the controller when the ignition is on. I suspect you have msv70. If not, look for another diagram on the Internet.
If the voltage is there, but too low, I would look for a ground problem.
it is probably a brown cable near the positive terminal under the engine hood, it may even enter it from the bottom.
---------- Post added at 23h24 ---------- Previous post was at 23h23 ----------
Envoyé par Zabrzanin94 Voir le message
Tutaj masz zdjęcie
https://files.fm/u/3fcb7q8xpk
Zabrzanin94 est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to Zabrzanin94 For This Useful Post:
icee (03/02/2024), rapou30 (03/02/2024)
