Vieux 28/02/2024, 22h00
alp.renia
Avatar de alp.renia
alp.renia is an unknown quantity at this point
If you want to use passthru with your car then only solution is Scanmatik2.
I've been using it for a while and this is only unit that was able to connect and work with older Benz cars. But be aware that not all older (before CAN) cars it will support anyway.
I've tested it on 2004 W211 in almost all functions. Only there was a problem with brake bleeding but had no time to take a closer look at problem and used other tool to finish job.
Openport2.0 wont do the same. Not sure about other J2534 devices.
alp.renia est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to alp.renia For This Useful Post:
Christou (01/03/2024), ck32 (30/03/2024)
