Vieux 30/03/2024, 10h10
Mutasim
Avatar de Mutasim
Mutasim is an unknown quantity at this point
Par défaut Renault Captur 2014 1.2tce
I've Renault Captur 2014 1.2 TCe, and I'm still getting those codes DTC019064 Fuel rail pressure sensor implausible signal, DTC059713 coolant circuit switching solenoid valve open circuit, DTC1525F3 consistent multiplex signals for CC/SL the data supplied to the cruise control or speed limiter are not correct. As per now I've changed fuel rail pressure sensor, high pressure fuel pump, all spark plugs, injectors, thermostat housing, oxygen sensor and cleaned dpf but still those codes are present.
Mutasim est déconnecté   Réponse avec citation
