Discussion: edc15 vm+ immo off
Vieux 05/04/2024, 17h04
Momo-02
Avatar de Momo-02
Momo-02 is a jewel in the roughMomo-02 is a jewel in the roughMomo-02 is a jewel in the rough
Sur certains il faut faire flash également , autrement je joint la procédure pour adapter pompe :
Select]
[01 - Engine]
[Login - 11]
4-digit PIN
The PIN needs to be entered as 5-digit number. For example, if your PIN is 1234, enter 01234.
[Do it!]
[Adaptation - 10]
Enter 050 in "Channel Number".
[Read]
4-digit PIN
[Save]
[Done, Go Back]
[Close Controller, Go Back - 06]
Switch OFF the ignition and let the car sit for ~1 minute, then switch ON the ignition again.
Start the Engine to verify the adaptation was successful.
Momo-02 est déconnecté   Réponse avec citation
