Vieux 16/05/2024, 13h07
nafan
Avatar de nafan
nafan is an unknown quantity at this point
Je viens de regarder les logs de ce matin, et il y a une valeur qui m'intrigue (en bleu), et une autre qui pourrait expliquer la panne (en rouge). Cf 2ème pavé.
Ecran FAP (au démarrage)
Code:
	@ 08:59:02.308
	Screen : Fap state	Request : DataRead.Engine speed
		{"Engine speed": "899"}
	@ 08:59:02.541
	Screen : Fap state	Request : DataRead.Final indicated torque raw
		{"Final indicated torque raw": "53.375"}
	@ 08:59:02.776
	Screen : Fap state	Request : DataRead.Engine coolant temperature
		{"Engine coolant temperature": "28.900000000000034"}
	@ 08:59:03.014
	Screen : Fap state	Request : DataRead.Combustion mode
		{"Combustion mode": "regular injection"}
	@ 08:59:03.190
	Screen : Fap state	Request : DataRead.Temperature before turbine
		{"Temperature before turbine": "154.5"}
	@ 08:59:03.375
	Screen : Fap state	Request : DataRead.Temperature before turbine setpoint
		{"Temperature before turbine setpoint": "460"}
	@ 08:59:03.543
	Screen : Fap state	Request : DataRead.Post injection quantity
		{"Post injection quantity": "0"}
	@ 08:59:03.719
	Screen : Fap state	Request : DataRead.Main injection advance
		{"Main injection advance": "-3.98"}
	@ 08:59:03.893
	Screen : Fap state	Request : DataRead.Main injection quantity
		{"Main injection quantity": "4.72"}
	@ 08:59:04.074
	Screen : Fap state	Request : DataRead.CSF upstream temperature
		{"CSF upstream temperature": "76.4"}
	@ 08:59:04.246
	Screen : Fap state	Request : DataRead.Soot mass in CSF
		{"Soot mass in CSF": "40.88"}
	@ 08:59:04.428
	Screen : Fap state	Request : DataRead.CSF downstream temperature
		{"CSF downstream temperature": "41.9"}
	@ 08:59:04.612
	Screen : Fap state	Request : DataRead.Mass air flow
		{"Mass air flow": "417.4"}
	@ 08:59:04.779
	Screen : Fap state	Request : DataRead.Boost pressure
		{"Boost pressure": "1012"}
	@ 08:59:04.962
	Screen : Fap state	Request : DataRead.Vehicle speed
		{"Vehicle speed": "0"}
	@ 08:59:05.128
	Screen : Fap state	Request : DataRead.CSF upstream temperature setpoint
		{"CSF upstream temperature setpoint": "580"}
	@ 08:59:05.312
	Screen : Fap state	Request : DataRead.Pre injection 1 quantity
		{"Pre injection 1 quantity": "1.59"}
	@ 08:59:05.478
	Screen : Fap state	Request : DataRead.Pre injection 2 quantity
		{"Pre injection 2 quantity": "1.65"}
	@ 08:59:05.663
	Screen : Fap state	Request : DataRead.CSF - Number of regeneration success
		{"CSF - Number of regeneration success": "0"}
	@ 08:59:05.829
	Screen : Fap state	Request : DataRead.CSF - Indicates the number of regeneration failures since the last sucess
		{"CSF - Indicates the number of regeneration failures since the last sucess": "0"}
	@ 08:59:05.987
	Screen : Fap state	Request : DataRead.Old requirement value of combustion mode
		{"Old requirement value of combustion mode": "starting"}
	@ 08:59:06.131
	Screen : Fap state	Request : DataRead.Post-treatment requirement value of combustion mode
		{"Post-treatment requirement value of combustion mode": "regular injection"}
	@ 08:59:06.263
	Screen : Fap state	Request : DataRead.CSF statemachine status for aftersale diagnosis regeneration
		{"CSF statemachine status for aftersale diagnosis regeneration": "wait state"}
	@ 08:59:06.419
	Screen : Fap state	Request : DataRead.Estimated soot mass left in CSF during regeneration
		{"Estimated soot mass left in CSF during regeneration": "3.89"}
	@ 08:59:06.563
	Screen : Fap state	Request : DataRead.CSF differential pressure before after-sales regeneration
		{"CSF differential pressure before after-sales regeneration": "1"}
	@ 08:59:06.696
	Screen : Fap state	Request : DataRead.CSF differential pressure after after-sales regeneration
		{"CSF differential pressure after after-sales regeneration": "1"}
	@ 08:59:06.850
	Screen : Fap state	Request : DataRead.Exhaust gas air mass flow for estimation of downstream pressure and temperature models
		{"Exhaust gas air mass flow for estimation of downstream pressure and temperature models": "0.01256"}
	@ 08:59:06.980
	Screen : Fap state	Request : DataRead.CSF - Mass gaz flow in exhaust line
		{"CSF - Mass gaz flow in exhaust line": "0.1256"}
	@ 08:59:07.130
	Screen : Fap state	Request : DataRead.Catalyst exhaust gas 1 upstream temperature
		{"Catalyst exhaust gas 1 upstream temperature": "94.9"}
	@ 08:59:07.280
	Screen : Fap state	Request : DataRead.Boolean indicating that the statemachine manual mode is on
		{"Boolean indicating that the statemachine manual mode is on": "no RGN request"}
Ecran Générique (Après 10 minutes de parcours urbain) :
Code:
	@ 09:11:20.555
	Screen : Generic screen	Request : DataRead.Engine speed
		{"Engine speed": "851.5"}
	@ 09:11:20.637
	Screen : Generic screen	Request : DataRead.Accelerator pedal position
		{"Accelerator pedal position": "0"}
	@ 09:11:20.721
	Screen : Generic screen	Request : DataRead.Engine status
		{"Engine status": "engine autonomious"}
	@ 09:11:20.803
	Screen : Generic screen	Request : DataRead.Battery voltage
		{"Battery voltage": "12.62"}
	@ 09:11:20.870
	Screen : Generic screen	Request : DataRead.Rail pressure
		{"Rail pressure": "285"}
	@ 09:11:20.957
	Screen : Generic screen	Request : DataRead.Fuel temperature
		{"Fuel temperature": "18.7"}
	@ 09:11:21.038
	Screen : Generic screen	Request : DataRead.Engine coolant temperature
		{"Engine coolant temperature": "71.60"}
	@ 09:11:21.118
	Screen : Generic screen	Request : DataRead.State of glow plug control actuator relay
		{"State of glow plug control actuator relay": "deactivated"}
	@ 09:11:21.204
	Screen : Generic screen	Request : DataRead.Key state
		{"Key state": "key on"}
	@ 09:11:21.273
	Screen : Generic screen	Request : DataRead.Effective engine torque setpoint requested by real (pedal) and virtual (ACC/CC/SL) drivers
		{"Effective engine torque setpoint requested by real (pedal) and virtual (ACC/CC/SL) drivers": "1.25"}
	@ 09:11:21.354
	Screen : Generic screen	Request : DataRead.Estimated effective engine torque
		{"Estimated effective engine torque": "1.46875"}
	@ 09:11:21.438
	Screen : Generic screen	Request : DataRead.Engine torque without gearbox request
		{"Engine torque without gearbox request": "1.25"}
	@ 09:11:21.523
	Screen : Generic screen	Request : DataRead.Effective engine torque target requested by real (pedal) and virtual (ACC/CC/SL) drivers
		{"Effective engine torque target requested by real (pedal) and virtual (ACC/CC/SL) drivers": "1.25"}
	@ 09:11:21.588
	Screen : Generic screen	Request : DataRead.Minimum engine torque
		{"Minimum engine torque": "1.25"}
	@ 09:11:21.683
	Screen : Generic screen	Request : DataRead.Maximum engine torque
		{"Maximum engine torque": "150"}
	@ 09:11:21.761
	Screen : Generic screen	Request : DataRead.Maximum engine torque with dynamic limitations
		{"Maximum engine torque with dynamic limitations": "97.40625"}
	@ 09:11:21.843
	Screen : Generic screen	Request : DataRead.Engine torque losses
		{"Engine torque losses": "37"}
	@ 09:11:21.923
	Screen : Generic screen	Request : DataRead.Final indicated torque raw
		{"Final indicated torque raw": "38.71875"}
	@ 09:11:21.989
	Screen : Generic screen	Request : DataRead.Final indicated torque target
		{"Final indicated torque target": "38.75"}
	@ 09:11:22.073
	Screen : Generic screen	Request : DataRead.Final indicated torque setpoint
		{"Final indicated torque setpoint": "39"}
	@ 09:11:22.151
	Screen : Generic screen	Request : DataRead.Mass air flow
		{"Mass air flow": "399.3"}
	@ 09:11:22.230
	Screen : Generic screen	Request : DataRead.Mass air flow setpoint
		{"Mass air flow setpoint": "285.6"}
	@ 09:11:22.323
	Screen : Generic screen	Request : DataRead.EGR valve position
		{"EGR valve position": "0"}
	@ 09:11:22.389
	Screen : Generic screen	Request : DataRead.EGR valve PWM command
		{"EGR valve PWM command": "-10.69"}
	@ 09:11:22.473
	Screen : Generic screen	Request : DataRead.Inlet throttle PWM command
		{"Inlet throttle PWM command": "9.509999999999991"}
	@ 09:11:22.553
	Screen : Generic screen	Request : DataRead.Atmospheric pressure
		{"Atmospheric pressure": "1003"}
	@ 09:11:22.631
	Screen : Generic screen	Request : DataRead.Intake air temperature
		{"Intake air temperature": "17.19999999999999"}
	@ 09:11:22.723
	Screen : Generic screen	Request : DataRead.Main injection advance
		{"Main injection advance": "-4"}
	@ 09:11:22.789
	Screen : Generic screen	Request : DataRead.Main injection quantity
		{"Main injection quantity": "3.34"}
	@ 09:11:22.874
	Screen : Generic screen	Request : DataRead.Pre injection 1 quantity
		{"Pre injection 1 quantity": "1.43"}
	@ 09:11:22.963
	Screen : Generic screen	Request : DataRead.Pre injection 2 quantity
		{"Pre injection 2 quantity": "1.18"}
	@ 09:11:23.040
	Screen : Generic screen	Request : DataRead.After injection quantity
		{"After injection quantity": "0"}
	@ 09:11:23.123
	Screen : Generic screen	Request : DataRead.Post injection quantity
	@ 09:11:23.190
	Screen : Generic screen	Request : DataRead.Late post injection quantity
		{"Late post injection quantity": "0"}
	@ 09:11:23.273
	Screen : Generic screen	Request : DataRead.Pre injection 1 desired time
		{"Pre injection 1 desired time": "1600"}
	@ 09:11:23.358
	Screen : Generic screen	Request : DataRead.Pre injection 2 desired time
		{"Pre injection 2 desired time": "1598"}
	@ 09:11:23.440
	Screen : Generic screen	Request : DataRead.After injection desired time
		{"After injection desired time": "0"}
	@ 09:11:23.522
	Screen : Generic screen	Request : DataRead.Post injection angle
		{"Post injection angle": "0"}
	@ 09:11:23.590
	Screen : Generic screen	Request : DataRead.Boost pressure
		{"Boost pressure": "1034"}
	@ 09:11:23.674
	Screen : Generic screen	Request : DataRead.Boost pressure setpoint
		{"Boost pressure setpoint": "1029"}
	@ 09:11:23.757
	Screen : Generic screen	Request : DataRead.Boost regulation state
		{"Boost regulation state": "shut off because of exhaust pressure sensor disconnected"}
	@ 09:11:23.840
	Screen : Generic screen	Request : DataRead.Total fuel quantity
		{"Total fuel quantity": "5.95"}
	@ 09:11:23.923
	Screen : Generic screen	Request : DataRead.Camshaft/crankshaft synchronization state
		{"Camshaft/crankshaft synchronization state": "synchronized"}
	@ 09:11:23.991
	Screen : Generic screen	Request : DataRead.Rail pressure setpoint.value
		{"Rail pressure setpoint.value": "286"}
	@ 09:11:24.074
	Screen : Generic screen	Request : DataRead.Boost pressure PWM command (diesel).value
		{"Boost pressure PWM command (diesel).value": "333.04"}
	@ 09:11:24.158
	Screen : Generic screen	Request : DataRead.EGR valve position setpoint.value
		{"EGR valve position setpoint.value": "-4"}
	@ 09:11:24.241
	Screen : Generic screen	Request : DataRead.Inlet throttle position setpoint.value
		{"Inlet throttle position setpoint.value": "94.98919999999998"}
Si je traduis correctement, un capteur de pression serait débranché (ou défectueux).
Mais de quel capteur on parle ? Un des capteurs de pression différentielle du FAP ? Un capteur de pression de sortie de turbo ?
Est-ce que ça a un lien avec la différence entre la consigne de flux d'air (Mass air flow setpoint = 285,6) et le flux réel (Mass air flow = 399,3) ?
Désolé si ces questions vous paraissent insensées, et encore merci pour votre aide !
nafan est déconnecté   Réponse avec citation
