Vieux 24/01/2025, 20h46
Oliv
Avatar de Oliv
Oliv is on a distinguished road
J'ai ça sur logiciel avec ta ref 98221VA050 si jamais
Mais attention, voilà ce qui est dit avec :
1.Before[ClearCrash] and [WriteFlash] operations, remove 0Ω resistor and connect 10kΩ resistor between 2 points as shown on "Write Mode Connection" image. When done, turn all the details back.
2.!!! Before performing the [ReadDTC] and [ClearErrors] operations, the external 10KΩ resistor must be removed and the ECU must be restored before proceeding, otherwise an "airbag ECU malfunction" error may occur!!!
3.Make sure you have a Flash file before performing the [WriteFlash] operation because after this operation all data will be erased and you will not be able to recover your airbag ECU..
4.When writing data,wirte back the original data.
J'espère que ça pourra t'aider
---------- Post added at 20h46 ---------- Previous post was at 20h37 ----------
La pièce jointe était trop lourde, je te la mets en lien ici :
https://www.transfernow.net/dl/20250124gMrWZ37T
Oliv est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to Oliv For This Useful Post:
phil1 (24/01/2025), Snatsh (24/01/2025)
