Vieux 10/02/2025, 16h22
simonpbmeca49
Avatar de simonpbmeca49
Pouvoir de réputation: 3
Par défaut Interpretation erreur vcds
Bonjour. J'ai un VW Atlas de 2020 avec cette DTC qui apparait sur vcd :
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 085 CC HW: 5Q0 937 085 BG
Component: BCM MQBAB HNA H40 0312
Serial number: 0242035001ÿÿÿÿ Dataset Number: V03935335UV 0001
Coding: 00000000000000000000000000000000000000000000000000 0000000000
Shop #: WSC 06050 062 00200
ASAM Dataset: EV_BCMMQB 020001
ROD: EV_BCMBOSCH_020_VW41.rod
VCID: 7CA1F4ED5668993A0BB-8028
Rain/Light Recognition Sensor:
Subsystem 1 - Part No SW: 5Q0 955 555 A HW: 5Q0 955 555 A
Component: RLHSS 054 0207
Serial number: S6Y20M07D01H15M23S00
Coding: 0018DD
Steering Column Switch:
Subsystem 2 - Part No SW: 5Q1 953 521 AC HW: 5Q1 953 569 B
Component: Lenks.Modul H23 0170
Serial number: 0300040920200C200990
Blower 1 for left front backrest:
Subsystem 3 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Component: SysNameFanLin 014 0102
Serial number: ESE1706485
Blower 1 for left front seat cushion:
Subsystem 4 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE1680411
Blower 1 for right front backrest:
Subsystem 5 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE1706379
Blower 1 for right front seat cushion:
Subsystem 6 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE1680575
1 Fault Found
535060 - Databus
U1123 00 [00001001] - Received Error Message
[FLA_01 Datenbus empfangener Fehlerwert]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 82
Mileage: 60254 km
Date: 2025.02.09
Time: 0521
Terminal 15 status: On
Terminal 50 status: OFF
CAN-Bus_aktiv: On
Status Bremslichtschalter (HW): OFF
Status Bremslichtschalter (CAN): OFF
OFF: operated
Position lamps: Not operated
Automatic high beam assist: Not operated
Low beam: Not operated
Parking light left: Not operated
Parking light right: Not operated
last_wakeup: no cause for fault protection
Voltage: 12.1 V
Outside temperature: 35.0 °C
Comment savoir quel module à envoyé un message erroné ?
---------- Post added at 17h22 ---------- Previous post was at 17h20 ----------
Au cas où, J519 = BCM
[B]Un thanks encourage à participer[/B]
