Vieux 30/08/2025, 15h45
vwseb
Avatar de vwseb
Voila le scan complet
Saturday,30,August,2025,1545:16365
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 25.3.1.0 HEX-V2 CB: 0.4671.4
Data version: 20250408 DS365.0
Ross-Tech: Home
VIN: WAXXXXXXXXXXXXXXX EN MP,Merci ! License Plate:
Mileage: 126731km-78746mi Repair Order:
Gateway Installation List: 4N2 907 468 AB
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1B-Active Steering -- Status: OK 0000
32-Differential Locks -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 0010
6D-Trunk Elect. -- Status: OK 0000
74-Chassis Control -- Status: OK 0000
81-Gear Shift -- Status: OK 0000
82-Head Up Display -- Status: OK 0000
84-Night Vision -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
AC-Reductant Control -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
C4-DC/DC Converter -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CB-Rear Axle Steering -- Status: OK 0000
CC-Starter-Generator -- Status: OK 0000
CD-Laser Scanner -- Status: Malfunction 0010
CF-Lane Chge Asst 2 -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
DB-Frt Corner Rdar 1 -- Status: OK 0000
DC-Frt Corner Rdar 2 -- Status: OK 0000
DD-Sunroof 2 -- Status: OK 0000
DE-Charger 1 for mobile dev -- Status: OK 0000
Chassis Type: F2-AU58 (4N2)
Scan: 01 02 03 09 13 15 16 17 19 1B 32 36 3C 42 44 46 52 5F 61 6D
74 81 82 84 A5 AC BB BC C4 CA CB CC CD CF D6 D7 DB DC DD
VIN: WAXXXXXXXXXXXXXXX EN MP,Merci ! Mileage: 126731km-78746miles
A5-Frt Sens. Drv. Assist -- Status: Malfunction 0010
Address 01: Engine (J623-DDVB) Labels: Redir Fail!
Part No SW: 4K0 907 401 K HW: 059 907 309 L
Component: 3.0l V6 TDI H26 0003
Revision: CAH26--- CVN: 17249E2E7965F614755A2113755A211300000000D6C3ECFE
Coding: 122A4012056E050334286000000400000000000000000000
Shop #: WSC 13000 004 1048576
ASAM Dataset: EV_ECM30TDI0114K0907401K 001003
ROD: EV_ECM30TDI0114K0907401J.rod
VCID: 2F3B13A1D79EB2A2261-807A
VINID: 9D196AAAA58225B780044140203F2935B4
No fault code found.
Readiness: 0 0 0 0 1
Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
Part No SW: 4K0 927 158 AP HW: 0D5 927 156 P
Component: 0D5 30TDIRdW H05 0001
Revision: --H05--- CVN: 7D0A815600009238
Coding: 100000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_TCMALX52011 002015
ROD: EV_TCMALX52011.rod
VCID: 0059801D3A80FDDA8FB-8054
ATF pump:
Subsystem 1 - Part No SW: 4M0 927 154 AA HW: 0D7 321 281 A
Component: V552 ATFP H01 0705
Serial number: 1806280012
Address 03: ABS Brakes (J104) Labels: 4M0-907-379-V1.clb
Part No SW: 4N0 907 379 AC HW: 4N0 907 379 P
Component: ESP9 Premium H06 0850
Dataset Number: 4K0909504H 0001 CVN: D11B0B40
Coding: 1CAA329731A30B9A11A34C91588551E6F5B9C9384C8CD08832 1A8A67AF9D93
Shop #: WSC 22195 182 00000
ASAM Dataset: EV_ESP9BOSCHCMP 004011
ROD: EV_ESP9BOSCHCMP_004_AU58.rod
VCID: 79AFEDF9595AAC12C85-802C
Address 09: Cent. Elect. (J519) Labels:* 4N0-907-063-V2.clb
Part No SW: 4N0 907 063 DE HW: 4N0 907 063 AE
Component: BCM1 MLBevo H10 0652
Dataset Number: 4K0909514B 0022
Coding: 07000143C13900DD074C57889CEB9C68131B37100406009781 010A001B3316810A450A0280100000000003030041081A0C02 000144010100000000000000000000
Shop #: WSC 12345 123 61029
ASAM Dataset: EV_BCM1BOSCHAU651 014010
ROD: EV_BCM1BOSCHAU651_014.rod
VCID: 74B1DCCD7E38D17A9B3-8020
Wiper motor control module:
Subsystem 1 - Part No SW: 4K1 955 119 HW: 4K1 955 119
Component: J400FRWISCH 063 0730
Serial number: 00000001802210405503
Coding: 7DC727
Rain/Light Recognition Sensor:
Subsystem 2 - Part No SW: 81A 955 555 A HW: 81A 955 555
Component: G397_RLFSS H06 0002
Serial number: 21526681X81A955555A0
Coding: 0200FF
Light switch:
Subsystem 3 - Part No SW: 4K1 941 501 A HW: 4K1 941 501 A
Component: E1 - LTM H09 0086
Serial number: 13S28.06.1800300384
Garage door opener control module:
Subsystem 4 - Part No SW: 4N0 907 410 A HW: 4M0 907 410 A
Component: USHL5 H10 0100
Serial number: 0000009600350Z00SC02
Coding: 210000
Automatic dimming interior mirror:
Subsystem 5 - Part No SW: 8W0 857 511 HW: 8W0 857 511
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE119041823811681
Coding: 010000
Interior Light Module:
Subsystem 6 - Part No SW: 4K0 947 135 H HW: 4K0 947 135 H
Component: Dachmodul H42 0413
Serial number: C00045858
Coding: 0D0101
Front windshield washer pump:
Subsystem 7 - Part No SW: 4N0 907 605 A HW: 4N0 907 605 A
Component: J1100/SWP H09 0005
Serial number: 00000000001816400561
Coding: 040000
2 Faults Found:
393476 - High Pressure Sensor
B10AE 21 [00001001] - Signal Amplitude Too Low
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 59
Mileage: 126731 km
Date: 2025.08.30
Time: 1536
average_Voltage_terminals: 11.00 V
Outside air temperature sensor-Resistance: 0.00 kOhm
Outside air temperature sensor-Outside air temperature on CAN: 30.50 °C
interior_temperature: 29.50 °C
Vehicle speed: 0.00 km/h
Terminal activation-Terminal 75 status: On
Terminal activation-Terminal 15 status signal: On
Terminal activation-Terminal 15 via CAN: On
Terminal activation-Term 75: qualification: OFF
405507 - Functional Limitation due to Energy Management
B10CD 00 [00001001] - -
[Function limitation due to energy management system]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 59
Mileage: 126731 km
Date: 2025.08.30
Time: 1541
Outside air temperature sensor-Outside air temperature on CAN: 31.00 °C
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 4K0 907 561 E HW: 760 907 561 A
Component: LRR4R H04 0332
Dataset Number: 4K1909863L 0001
Coding: 5265FF5478082C00010360E0000000BE4A1246484481009E00
ASAM Dataset: EV_ACCBOSCHAU65X 002023
ROD: EV_ACCBOSCHAU65X_VW53.rod
VCID: 303910DDCAA0AD5A3FB-8064
Address 15: Airbags (J234) Labels:| 80A-959-655.clb
Part No SW: 4N0 959 655 R HW: 4N0 959 655 R
Component: AirbagVW31 H10 2710
Serial number: 003Z0M0053B- Dataset Number: 4K0909602AC 0004
Coding: AAFCF0C00CC00000985400FFF01D41AC00C5
ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
ROD: EV_AirbaVW31SMEAU65x_001.rod
VCID: 4BC367314346EE822A9-801E
Left seat belt tensioner:
Subsystem 1 - Part No SW: 4N0 980 945 A HW: 4N0 980 945 A
Component: BeltPretRevFL H10 0115
Serial number: 00AI2018164651200000
Coding: 04F001
Right seat belt tensioner:
Subsystem 2 - Part No SW: 4N0 980 946 A HW: 4N0 980 946 A
Component: BeltPretRevFR H10 0115
Serial number: 00AI2018164361500000
Coding: 04F001
Crash sensor for side airbag: driver side:
Subsystem 3 - Part No SW: ----------- HW: 480 001 906 18
Component: SideSensor_Df 001 0887
Serial number: 3570000000086299BD2W
Coding: 2D2D2D
Crash sensor for side airbag: passenger side:
Subsystem 4 - Part No SW: ----------- HW: 480 001 906 18
Component: SideSensor_Pf 001 0887
Serial number: 358000000009274CFD2.
Coding: 2D2D2D
Rear Side Airbag Crash Sensor (on driver's side):
Subsystem 5 - Part No SW: ----------- HW: 480 030 206 18
Component: SideSensor_Dr 002 0149
Serial number: 351001C10F3AD5801811
Coding: 2D2D2D
Passenger side rear thorax airbag crash sensor:
Subsystem 6 - Part No SW: ----------- HW: 480 030 206 18
Component: SideSensor_Pr 002 0149
Serial number: 352001C10F32DA808E4F
Coding: 2D2D2D
Crash sensor for front airbag: driver side:
Subsystem 7 - Part No SW: ----------- HW: 480 032 206 18
Component: FrontSensor_D 002 0149
Serial number: 355001C10F1D94E0EACX
Coding: 2D2D2D
Crash sensor for front airbag: passenger side:
Subsystem 8 - Part No SW: ----------- HW: 480 032 206 18
Component: FrontSensor_P 002 0149
Serial number: 356001C10F1D95B07DEU
Coding: 2D2D2D
Center pedestrian protection crash sensor:
Subsystem 9 - Part No SW: ----------- HW: 480 032 905 18
Component: PedP_Sensor_C 002 0149
Serial number: 230001C10F439620D9B5
Coding: 2D2D2D
Driver's side crash data pedestrian protection 2:
Subsystem 10 - Part No SW: ----------- HW: 480 001 906 18
Component: PedPSensor_D2 001 0887
Serial number: I0M00000000C07618DAB
Coding: 2D2D2D
Passenger's side crash data pedestrian protection 2:
Subsystem 11 - Part No SW: ----------- HW: 480 001 906 18
Component: PedPSensor_P2 001 0887
Serial number: I0N00000000B07618DAB
Coding: 2D2D2D
Belt tensioner second row left:
Subsystem 12 - Part No SW: 4N0 980 965 A HW: 4N0 980 965 A
Component: BeltPretRevRL H10 0115
Serial number: 00AI2018174619200000
Coding: 04F001
Belt tensioner second row right:
Subsystem 13 - Part No SW: 4N0 980 966 A HW: 4N0 980 966 A
Component: BeltPretRevRR H10 0115
Serial number: 00AI2018164039800000
Coding: 04F001
Address 16: Steering wheel (J527) Labels: 4M0-907-129.clb
Part No SW: 4N0 907 129 AJ HW: 4N0 907 129 AJ
Component: Lenks.Modul H03 0005
ASAM Dataset: EV_SMLSKLOAU736 007012
ROD: EV_SMLSKLOAU736_VW53.rod
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 4K0 920 790 A HW: 4K0 920 790 A
Component: FBenRDWACC--- H11 0151
Dataset Number: 4K0909525B 0021
Coding: 858538E27CA800080093E1609080480008002000
Shop #: WSC 22195 182 12345
ASAM Dataset: EV_DashBoardAU65X 001017
ROD: EV_DashBoardAU65X_001_AU58.rod
VCID: 2B0307B1E386CE820A9-807E
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 4N2 907 468 AB HW: 4N2 907 468 AB
Component: Gateway H14 0036
Revision: 8P020004 Serial number: 0488P580618620 Dataset Number: 4K0909515B 0027
Coding: 02010005008406408C960000005B0132DC9A004F9800000009 7D078E10000000
GVL: F1517C488804000002DC88000100C800110E00700100000000 00000000000000
ASAM Dataset: EV_CGateCONTIAU491 003150
ROD: EV_CGateCONTIAU491_003_AU58.rod
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 4K0 951 523 H HW: 4K0 951 523 H
Component: E221__MFL H06 0003
Serial number: 00000000000000000000
Battery Monitoring Control Module:
Subsystem 2 - Part No SW: 4K0 915 181 HW: 4K0 915 181
Component: J367-BDMConti H03 1050
Serial number: 74186311001806190105
2 Faults Found:
9502727 - Databus
U1123 00 [00001001] - Received Error Message
[BMS_No_Component_Function]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 59
Mileage: 126731 km
Date: 2025.08.30
Time: 1532
48V activation restriction-Airbag control module: not active
48V activation restriction-Engine Electronics: not active
48V activation restriction-Roll stabilization: not active
48V activation restriction-48 V activation restriction due to open circuit: not active
48V activation restriction-48 V activation restriction due to deactivation: not active
48V activation restriction-Battery management 2: active
48V activation restriction-Voltage converter: not active
48V activation restriction-Auxiliary Air Heater Control Module/PTC: not active
48V activation restriction-Electrical compressor: not active
8519683 - Energy Management Active
U140B 00 [00001001] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 59
Mileage: 126731 km
Date: 2025.08.30
Time: 1532
EM_vehicle_state: 02 10
Static current shut-off stage: Deactivation stage 1
Auxiliary heater activation restriction request-Parking heater: Permitted
Auxiliary heater activation restriction request-Allowed parking heater runtime: 0 min
Address 1B: Active Steering (J792) Labels: None
Part No SW: 4N0 907 144 C HW: 8W0 907 144 C
Component: SCU_MLBevo H03 0802
Serial number: 30303030303030 Dataset Number: 4K0909848G 0001
ASAM Dataset: EV_SCUZFLSAU65X 003019
ROD: EV_SCUZFLSAU65X.rod
VCID: 2E050EA5D094BBAA2D7-807A
Address 32: Differential Locks (J187) Labels: None
Part No SW: 8W0 907 163 HW: 8W0 907 163
Component: QSP QCU Gen2 H08 0060
Revision: 5WK12700 Serial number: 605824301202107
Coding: 0001
ASAM Dataset: EV_TVDCQSP22 001008
ROD: EV_TVDCQSP22.rod
Address 36: Seat Mem. Drvr (J136) Labels:* None
Part No SW: 4M4 959 760 HW: 4M4 959 760
Component: MEM-FS 009 0042
Serial number: 00000330035499 Dataset Number: 4K8909856B 0013
Coding: 00581A400000B4010003010101010000000000000000000000 000000004000
ASAM Dataset: EV_SCMDriveSideCONTIAU736 006009
ROD: EV_SCMDriveSideCONTIAU736_VW38.rod
Address 3C: Lane Change (J769) Labels:* None
Part No SW: 4N0 907 566 E HW: 4N0 907 566 A
Component: MRR_HR H12 0265
Dataset Number: 4K8909535D 0024
Coding: 0FFC00
ASAM Dataset: EV_RearRadarS1DelphAU651 001018
ROD: EV_RearRadarS1DelphAU651_AU58.rod
VCID: 382928FD22D0751A77B-806C
Address 42: Door Elect, Driver (J386) Labels:* None
Part No SW: 4M1 959 793 D HW: 4M1 959 793 D
Component: TSG FS001 0188
Serial number: YE007RFC32017 Dataset Number: 4K8909872B 0025
Coding: 001DDA0152000480A009B032
ASAM Dataset: EV_DCU2DriveSideMAXHKLO 001010
ROD: EV_DCU2DriveSideMAXHKLO_VW27.rod
VCID: 40D9401D7A003DDACFB-8014
Address 44: Steering Assist (J500) Labels:* None
Part No SW: 4N0 909 144 D HW: 4N0 909 144 A
Component: EPS_MLBEVO2BS H20 0504
Dataset Number: 4K0909852H 0002
Coding: E1002101010000
ASAM Dataset: EV_EPSVWBSAU426 009015
ROD: EV_EPSVWBSAU426_009.rod
VCID: 313F15D9C1AAA452305-8064
Address 46: Central Conv. (J393) Labels:* None
Part No SW: 4N0 907 064 BP HW: 4N0 907 064 P
Component: BCM2 MLBevo H14 0145
Dataset Number: 4K8909501D 0036
Coding: 013400000FB100606309A0046C04880203004004804F02502F 0400000504823F001F0100010F01
Shop #: WSC 26739 187 00000
ASAM Dataset: EV_BCM2CONTIAU651 008007
ROD: EV_BCM2CONTIAU651_008_VW53.rod
VCID: 7EA5FEE540748B2AFD7-802A
ID - sensor:
Coding: 000000
Anti-theft alarm system sensor:
Subsystem 2 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0316
Serial number: 000000000ZY1812004AA
Alarm horn:
Subsystem 3 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Sirene, DWA 005 0314
Serial number: 00000000000099428767
Heated Windshield Control Module:
Subsystem 4 - Part No SW: 4N0 907 133 HW: 4N0 907 133
Component: J505-FSH H08 0040
Serial number: 18115002309021120081
left tail lamp 1:
Subsystem 5 - Part No SW: 4K0 945 217 HW: 4K0 945 217
Component: SHL_li1 003 0001
Serial number: 00000000000000127043
Coding: 000000
Rear lid opener control module:
Subsystem 6 - Part No SW: 3G0 962 243 C HW: 3G0 962 243 C
Component: GEB.F.Heckoef H17 0906
Serial number: 11311794
Rear spoiler control module:
left tail lamp 2:
Subsystem 8 - Part No SW: 4K5 945 093 C HW: 4K5 945 093 C
Component: SHL_li2 003 0001
Serial number: 00000000000000127717
Coding: 000000
Right rear tail lamp 1:
Subsystem 9 - Part No SW: 4K0 945 218 HW: 4K0 945 218
Component: SHL_re1 003 0001
Serial number: 00000000000000089624
Coding: 000000
Right rear tail lamp 2:
Subsystem 10 - Part No SW: 4K5 945 094 C HW: 4K5 945 094 C
Component: SHL_re2 003 0001
Serial number: 00000000000000141318
Coding: 000000
Address 52: Door Elect, Pass. (J387) Labels:* None
Part No SW: 4M1 959 792 D HW: 4M1 959 792 D
Component: TSG BFS001 0188
Serial number: YE007RFL05773 Dataset Number: 4K8909873B 0025
Coding: 001DDA015E000480A009B030
ASAM Dataset: EV_DCU2PasseSideMAXHKLO 001010
ROD: EV_DCU2PasseSideMAXHKLO_VW27.rod
VCID: 3FDB43E107FE4222B61-806A
Address 5F: Information Electr. Labels:
VCID: 55F781499C02A8728CD-FFFE
Address 61: Battery Regul. (J1120) Labels: 4N0-915-105.clb
Part No SW: 4N0 915 105 B HW: 4N0 915 105 B
Component: BMS_48V_LiIon H06 0108
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_BMS48VLiIonLGAU536 001001
ROD: EV_BMS48VLiIonLGAU536_AU58.rod
VCID: 290FFDB9E97ADC92F85-807C
2 Faults Found:
28709 - HV Battery Pack
P0A7D 00 [00100111] - State of Charge Low
[Diag_F_SOC_LL1]
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 126731 km
Date: 2025.08.30
Time: 1532
28710 - HV Battery
P0B29 00 [00100111] - Complete Discharge
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Mileage: 126731 km
Date: 2025.08.30
Time: 1532
Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
Part No SW: 4M0 959 107 B HW: 4M0 959 107 A
Component: HDSG-Modul H13 0166
Revision: -------- Serial number: 31977548200000 Dataset Number: 4K0909541A 0008
Coding: 1270
ASAM Dataset: EV_DeckLidCONTIAU736 001016
ROD: EV_DeckLidCONTIAU736_VW27.rod
VCID: 323D1AD5C4AC9F4A49F-8066
Address 74: Chassis Control (J775) Labels:* 4N0-907-777.clb
Part No SW: 4K0 907 777 AS HW: 4K0 907 777 A
Component: Fahrwerk-SG H51 2016
Serial number: 1706180349 Dataset Number: 4K0909576G 0002
Coding: 746C3840DA40
ASAM Dataset: EV_ChassContrContiAU651 001011
ROD: EV_ChassContrContiAU651_001_AU58.rod
VCID: 0849983D12B0C59AC7B-805C
Air Suspension Compressor:
Subsystem 1 - Part No SW: 4M0 907 778 HW: 4M0 907 778
Component: V66LFKompOLV H06 0013
Serial number: 00000000004130330447
Coding: 303030
Address 81: Gear Shift (J587) Labels: 4KX-713-041-81.clb
Part No SW: 4K1 713 041 G HW: 4K1 713 041 H
Component: GSM-LL H14 0050
Serial number: 18.164 40352
ASAM Dataset: EV_GSMKAMAU581 001005
ROD: EV_GSMKAMAU581.rod
VCID: 270BFB81FF6EEAE2EE1-8072
Address 82: Head Up Display (J898) Labels:| 4Nx-919-617-V1.clb
Part No SW: 4K1 919 617 A HW: 4K1 919 617 A
Component: HeadupDisplay H11 1815
Coding: 5700E0
ASAM Dataset: EV_HeadUpDisplAU65X 001010
ROD: EV_HeadUpDisplAU65X_VW53.rod
Address 84: Night Vision (J853) Labels:| 4K0-907-547.clb
Part No SW: 4K0 907 547 HW: 4M0 907 547
Component: NV-ECU-Gen3 H11 0145
Serial number: 643208500201824
Coding: 400113
ASAM Dataset: EV_NightVisioG3AUTOLAU58x 001003
ROD: EV_NightVisioG3AUTOLAU58x.rod
VCID: 6FBBD3A1171EF2A2661-803A
Night vision system camera:
Subsystem 1 - Part No SW: 4G0 980 552 A HW: 4G0 980 552
Component: NV-CAM-Gen3 H06 0007
Serial number: 639589400B1817610889
Address A5: Frt Sens. Drv. Assist (J1121) Labels:* 4N0-907-107-V2.clb
Part No SW: 4KE 907 107 AC HW: 4N0 907 107 H
Component: zFAS Var C H09 0291
Dataset Number: 4K0909466J 0041
Coding: 040184000000000000FFD60000F0D50C5B9F76000000000000 0000000096D401009BA8000000000000000080000000000000 000000000000F98040000000000000007CD0008000B0008000 80000000000080400000E0
ASAM Dataset: EV_ZFASAU516 001005
ROD: EV_ZFASAU516_001.rod
3 Faults Found:
2117691 - Ethernet Databus
U11C4 00 [00001001] - No Communications
[Databus_Ethernet_no_communication]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 59
Mileage: 126731 km
Date: 2025.08.30
Time: 1533
Ethernet signal quality: no link
2117692 - Control unit for information electronics 1
U1054 00 [00001001] - No Communication
[Databus_Ethernet_missing_PDU]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 59
Mileage: 126731 km
Date: 2025.08.30
Time: 1531
282656 - Video Cable for Information Electronics 1
B13B9 01 [00001001] - Electrical Failure
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 59
Mileage: 126731 km
Date: 2025.08.30
Time: 1532
Address AC: Reductant Control (J880) Labels: 80A-907-355.clb
Part No SW: 80A 907 355 F HW: 80A 907 355 D
Component: SCR-Stg-G4H07 0004
Dataset Number: 4K0909571D 0003
ASAM Dataset: EV_RDCMHelbaAU426 003011
ROD: EV_RDCMHelbaAU426_003.rod
VCID: 2C0104ADE688C9BA033-8078
Address BB: Door Rear Drv (J388) Labels:* None
Part No SW: 4M1 959 795 D HW: 4M1 959 795 D
Component: TSG HFS003 0188
Serial number: YE007RFK18843 Dataset Number: 4K8909897B 0025
Coding: 000DD80100000480A008B020
ASAM Dataset: EV_DCU2RearDriveMAXHKLO 001010
ROD: EV_DCU2RearDriveMAXHKLO.rod
VCID: 42DD4A15740C2FCAD9F-8016
Address BC: Door Rear Pass (J389) Labels:* None
Component: TSG HBFS003 0188
Serial number: YE007RFK03758 Dataset Number: 4K8909896B 0025
ASAM Dataset: EV_DCU2RearPasseMAXHKLO 001010
ROD: EV_DCU2RearPasseMAXHKLO.rod
Address C4: DC/DC Converter (A7) Labels: 4M0-959-663.clb
Part No SW: 4M0 959 663 C HW: 4M0 959 663 C
Component: PCU10 022 0324
Dataset Number: 4K0909475A 0007
ASAM Dataset: EV_DCDC48V210ABOSCHAU736 001008
ROD: EV_DCDC48V210ABOSCHAU736.rod
VCID: 3A2D32F51CDC670A81F-806E
Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb
Part No SW: 4K0 907 594 AC HW: 4K0 907 594
Component: SAD_STG_1 005 0002
Dataset Number: 4K0909469F 0014
Coding: 668040058203
ASAM Dataset: EV_SunRoofCONTIAU736 009011
ROD: EV_SunRoofCONTIAU736_009_VW27.rod
VCID: 75B7E1C97542C872ACD-8020
Address CB: Rear Axle Steering (J1019) Labels:* 4M0-909-145.clb
Part No SW: 4N0 909 145 K HW: 4N0 909 145 C
Component: HAL_MLBevoH03 0398
Revision: -------- Serial number: CCC_098_B_9056_ Dataset Number: 4K0909904J 0001
Coding: 42244200
ASAM Dataset: EV_RearAxleSteerZFAU736 010018
ROD: EV_RearAxleSteerZFAU736_010_VW53.rod
VCID: 392F2DF919DA6C12885-806C
Address CC: Starter-Generator (C29) Labels:* None
Part No SW: 4N1 903 028 A HW: 4N1 903 028 A
Component: BSG-HP1-65 H18 0562
Serial number: 14062500030129
Coding: 28000000000000
Shop #: WSC 00001 000 00000
ASAM Dataset: EV_Start48VAU651 002007
ROD: EV_Start48VAU651_002.rod
VCID: 2A0D02B5EC7CD78AF1F-807E
Address CD: Laser Scanner (J1122) Labels: 4N0-907-660.clb
Part No SW: 4N0 907 660 E HW: 4N0 907 660
Component: LASER_SCANNER H36 0306
Dataset Number: 4K0909639T 0003
ASAM Dataset: EV_LaserScannAU651 015021
ROD: EV_LaserScannAU651_015.rod
VCID: 33331FD13BB69642429-8066
1 Fault Found:
11546627 - Laser for Adaptive Cruise
C12EB F1 [00001001] - Malfunction
[Heater_Resistance_too_high_error]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 81650 km
Date: 2023.06.05
Time: 15:03:44
Control Module temperature-Host: external temperature: 46 °C
Control Module temperature-Zynq: internal temperature: 60 °C
Control Module temperature-Host: internal temperature: 45 °C
Control Module temperature-Zynq: external temperature: 36 °C
Voltage terminal 15: 13.810 V
heating_resistor: 111.77 Ohm
heater-Medium power: 0.000 W
heater-Voltage: 0.000 V
heater-PWM value: 0 %
heater-Current draw (mean value): 0.000 A
Heating and cleaning management-Visibility: 0 %
Heating and cleaning management-Degree of contamination: 92 %
Heating and cleaning management-Heating status: 02
Heating and cleaning management-Cleaning status: 02
Outside temperature: 25 °C
Address CF: Lane Chge Asst 2 (J770) Labels:* None
Component: MRR_HL H12 0265
Dataset Number: 4K8909468D 0024
Coding: 0FFC00
ASAM Dataset: EV_RearRadarS2DelphAU651 001018
ROD: EV_RearRadarS2DelphAU651_AU58.rod
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-572.clb
Part No SW: 4K0 941 592 BC HW: 4K0 941 592 B
Component: LMS_MLBevo H11 0030
Dataset Number: 4K0909471H 0014
ASAM Dataset: EV_LMSLeftHELLAAU58X 001013
ROD: EV_LMSLeftHELLAAU58X_AU27.rod
VCID: 72BDDAD5042CDF4A89F-8026
Dynamic left front turn signal:
Subsystem 1 - Part No SW: 4K0 941 035 HW: 4K0 941 035
Component: M134DynTurnFL 003 0004
Serial number: 25051800005923001011
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-572.clb
Dataset Number: 4K0909472H 0014
ASAM Dataset: EV_LMSRightHELLAAU58X 001013
ROD: EV_LMSRightHELLAAU58X_AU27.rod
Dynamic right front turn signal:
Subsystem 1 - Part No SW: 4K0 941 036 HW: 4K0 941 036
Component: M135DynTurnFR 003 0004
Serial number: 08061800006523001011
Address DB: Frt Corner Rdar 1 (J1089) Labels:| 4N0-907-669.clb
Part No SW: 4N0 907 669 E HW: 4N0 907 669 A
Component: MRR_VR H12 0265
Dataset Number: 4K8909482C 0021
Coding: 003000
ASAM Dataset: EV_FrontCorneRadarS1AU651 001018
ROD: EV_FrontCorneRadarS1AU651_VW53.rod
VCID: 3C2134ED16E8593A933-8068
Address DC: Frt Corner Rdar 2 (J1088) Labels:| 4N0-907-669.clb
Component: MRR_VL H12 0265
Dataset Number: 4K8909483C 0022
Coding: 003000
ASAM Dataset: EV_FrontCorneRadarS2AU651 001018
ROD: EV_FrontCorneRadarS2AU651_VW53.rod
Address DD: Sunroof 2 (J392) Labels:* None
Part No SW: 4K0 907 594 AD HW: 4K0 907 594
Component: SAD_STG_2 005 0002
Dataset Number: 4K0909581C 0010
Coding: 629000058204
ASAM Dataset: EV_SunRoof2CONTIPO623 009011
ROD: EV_SunRoof2CONTIPO623_VW37.rod
VCID: 76B5E6C56844C36AA57-8022
End----(Elapsed Time: 02:46, VBatt start/end: 11.2V/11.1V. VIgn 11.1V)-----
------------------------------10 Faults Found------------------------------
Dernière modification par MecaTech ; 30/08/2025 à 18h07.
vwseb est déconnecté   Réponse avec citation
