Discussion: WMware 25h2
Vieux 25/01/2026, 00h44
pimo
Avatar de pimo
Par défaut WMware 25h2
Bonsoir pour ceux que ça intéresse voici la dernière version wmware workstation 25h2. (Plus besoin d'activation c'est gratuit maintenant cool)
Pour maximiser les performances sous windows11 il faut supprimer hyperV de Microsoft pour utiliser uniquement hyperV de wmware.
Pour ceci avant l’installation il faut appliquer cette méthode ci dessous.
Bonne installation ;)
How to Disable Hyper-V in Windows 11 24H2 | VMware Workstation
In this guide, I will explain how to disable Hyper-V in Windows and use Intel VT-x/EPT or AMD-V/RVI in any virtualization program, such as VirtualBox or VMware (in my case). The final step (6) is the key to disabling it in version 24H2, which has a bug that prevents it from being disabled.
Step 1: Stop Any Currently Running Hyper-V Services
Click on the Start menu.
Type services (without quotes) and press [ENTER].
In the Services window, browse through the list and look for any services that include "Hyper-V" (e.g., "HV Host Service").
If any of these services are running, right-click on them and select Stop.
Close the Services window.
Step 2: Ensure Hyper-V and Related Features Are Not Installed
Type Features (without quotes) and select "Turn Windows Features on or off".
In the Windows Features window, ensure the following options are unchecked:
Hyper-V (including all sub-items).
Windows Hypervisor Platform.
Linux subsystem for windows
Click OK and wait for the changes to apply.
Restart your computer if prompted.
Step 3: Disable "hypervisorlaunchtype"
Type powershell (without quotes), right-click on Windows PowerShell, and select Run as administrator.
In the PowerShell window, type the following command and press [ENTER]:
bcdedit /set hypervisorlaunchtype off
Close the PowerShell window.
Step 4: Disable Device Guard (If Applicable)
Note:
This step may not apply to all versions of Windows.
The Group Policy Editor (gpedit.msc) is not available in Windows 11 Home.
Type gpedit.msc (without quotes) and press [ENTER].
In the Group Policy Editor, navigate to:
Local Computer Policy > Computer Configuration > Administrative Templates > System > Device Guard
Double-click on "Turn on Virtualization Based Security".
Select Disabled and click OK.
Step 5: Disable "Memory Integrity" in Core Isolation
Type core isolation (without quotes) and press [ENTER].
In the Core Isolation window, ensure that "Memory Integrity" is turned Off.
Close the window.
Step 6: Mandatory step for Windows 11 24H2
Windows 11 24H2 has a known issue where Hyper-V might still interfere even after following the above steps. To resolve this, you'll need to use the Microsoft Device Guard and Credential Guard Hardware Readiness Tool:
Download the Device Guard and Credential Guard hardware readiness tool from Microsoft.
https://www.microsoft.com/en-us/down....aspx?id=53337
Extract the downloaded ZIP file.
Use the tool to disable Device Guard and Credential Guard:
Open PowerShell window as an administrator.
Navigate to the folder where you extracted the tool.
Firs run this command to get Execution Policy:
Set-ExecutionPolicy Unrestricted -Scope Process
Now run the script with the -disable parameter to disable Device and Credential Guard
DG_Readiness_Tool_v3.6.ps1 -Disable
Reboot your computer.
During the boot process, Windows will ask you to confirm the changes. Follow the on-screen instructions to proceed (Just press F3).
Note: Disabling Device Guard and Credential Guard will temporarily disable your Windows Hello PIN. However, you can re-enable it later without any issues.
Step 7: Confirm Hyper-V is Fully Disabled
After rebooting, open a PowerShell window as an administrator.
Run the following command to ensure Hyper-V is fully disabled:
Reboot your computer again.
Additional Notes
This method worked for me on Windows 11 24H2 for VMware Workstation and Virtualbox After completing these steps. I hope this ******ly helps someone, because I almost lost my mind trying to fix this
As far as I understand, this happens because in the new version, the security of the Windows Hello PIN and others things are based on the hypervisor, although it should be disabled if you want to disable the hypervisor, Microsoft should provide a simpler option to disable it completely and take the risks.
I am not responsible if someone breaks their system or creates a security breach. I'm just trying to help, something Microsoft doesn't do, considering that the original deactivation guide is the same as always.
