Envoyé par sami55
Bonjour Fastdiag
Dans la d'injection INJ HR16DEg3 5M40 HJB BFB RJI LJL BJA, je trouve les commandes suivantes :
1 - AC005 [Command] INJECTEUR CYLINDRE 1
2 - AC006 [Command] INJECTEUR CYLINDRE 2
3 - AC007 [Command] INJECTEUR CYLINDRE 3
4 - AC008 [Command] INJECTEUR CYLINDRE 4
5 - AC013 [Command] VOLET DE TURBULENCES
6 - AC015 [Command] RELAIS POMPE A ESSENCE
7 - AC017 [Command] ELECTROVANNE PURGE CANISTER
8 - AC036 [Command] VANNE EGR
9 - AC102 [Command] ARRET INHIBITION ALIMENTATION CARBURANT
10 - AC122 [Command] DECALEUR ARBRE A CAMES ADMISSION
11 - AC195 [Command] POMPE A EAU ELECTRIQUE
12 - AC275 [Command] GMV
13 - AC280 [Command] VOLET D'AIR ECHAPPEMENT
14 - AC286 [Command] VOLET PILOTE D'ADMISSION AIR SUR FACE AVANT
15 - AC287 [Command] ELECTROVANNE DE COUPURE DE MISE A L'AIR LIBRE
16 - AC318 [Command] SIGNAL DE COMMANDE POMPE A CARBURANT
17 - CF198 [Command] MODE MAINTENANCE
18 - RZ001 [Command] MEMOIRE DEFAUT
19 - RZ030 [Command] ADAPTATIFS FILTRE A PARTICULES
20 - RZ031 [Command] APPRENTISSAGES BUTEES PAPILLON
21 - RZ033 [Command] APPRENTISSAGE REGULATION DE RICHESSE
22 - RZ179 [Command] RAZ COMPTEUR
23 - SC001 [Command] ECRITURE DONNEES SAUVEGARDEES
24 - SC003 [Command] SAUVEGARDE DONNEES CALCULATEUR
25 - SC017 [Command] REGENERATION DU FILTRE A PARTICULES
26 - SC047 [Command] SAUVEGARDE DONNEES CALCULATEUR
27 - SC048 [Command] ECRITURE DONNEES SAUVEGARDEES
28 - SC049 [Command] APPRENTISSAGE CHAINE D'AIR - MODE REPARATION
29 - SC050 [Command] APPRENTISSAGE CHAINE D'AIR - MODE USINE
37 - VP036 [Command] INHIBITION ALIMENTATION CARBURANT
38 - VP040 [Command] REGENERATION DU FILTRE A PARTICULES
Ou vouliez-vous dire EVC HEVC_LOCOBOX (P)HEV?
1 - AC009 [Command] COMMANDE POMPE A EAU CHAUFFAGE
2 - AC018 [Command] EV REFROIDISSEUR BATTERIE TRACTION
3 - AC028 [Command] TENSION DE CONSIGNE DCDC
4 - AC030 [Command] ELECTROVANNE REFROIDISSEMENT BATTERIE DE TRACTION
5 - AC031 [Command] COMMANDE POMPE A EAU REFROIDISSEMENT MACHINE ELECTRIQUE
6 - AC032 [Command] COMMANDE POMPE A EAU REFROID. BATTERIE DE TRACTION
7 - AC034 [Command] ELECTROVANNE DE RECHAUFFAGE AIR D'ADMISSION
8 - AC035 [Command] POMPE A HUILE PILOTEE
9 - AC036 [Command] DEMANDE POSITION LEVIER BVA
10 - CF005 [Command] MODE MAINTENANCE
11 - CF007 [Command] AUTORISATION TEST DE CHARGE
12 - CF011 [Command] RELAIS BATTERIE DE TRACTION
13 - RZ002 [Command] APPRENTISSAGE REGULATEUR/LIMITEUR DE VITESSE
14 - RZ003 [Command] MEMOIRE DE DEFAUT
15 - RZ008 [Command] RAZ COMPTEUR
16 - RZ009 [Command] RAZ COMPTEUR
17 - SC001 [Command] SAUVEGARDE DONNEES CALCULATEUR
18 - SC002 [Command] ECRITURE DONNEES SAUVEGARDEES
19 - SC003 [Command] CONFIGURATION AUTOMATIQUE
21 - VP003 [Command] ECRITURE V.I.N.
78 - VP070 [Command] DEGAZAGE CIRCUIT DE REFROIDISSEMENT TRACTION ELEC
82 - VP081 [Command] APPRENTISSAGE LOCOBOX
83 - VP082 [Command] TEST DE COMPRESSION
Je t'ai envoyé un MP
Envoyé de mon 2406APNFAG en utilisant Tapatalk
