Vieux 29/06/2026, 19h25
Aleksey-MS
Avatar de Aleksey-MS
Pouvoir de réputation: 46
Aleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond repute
Envoyé par Aleksey-MS Voir le message
Mazda IDS 136 — What's New:
2025–2026 Model Support: Full diagnostics and coding for the latest Mazda CX-90, CX-70, and updated CX-5 models.
Expanded Calibration Database: Updated firmware files (PATS, PCM, TCM) to correct factory errors in gear shifting algorithms and engine management.
Improved Hybrid Support (MHEV/PHEV): Added new special functions for checking the high-voltage battery condition and bleeding the inverter cooling system.
VCM II / VCM 3 Optimization: Improved connection stability and data transfer speed when using original adapters and high-quality clones.
On-Screen Menu Update: The interface has become slightly more responsive, and tooltips for new DTCs for ADAS systems (lane assist, adaptive cruise control) have been added.
Need it? Push buttons Rate+Thanks, PM for pass | or by email right now.
Added Mazda IDS 142.
What's New:
  • Updated calibration database: The final offline factory firmware files have been added to v142. This is essential if you need to “update” a crashed or empty unit to the latest version without purchasing online access.
  • VCI firmware update: A new firmware version for VCM II / VCM 3 has been integrated. If you’re using a third-party device (e.g., from VXDIAG or another J2534 device), you’ll need to update the software emulator (Ford/Mazda driver) itself for version 142 to prevent the device from disconnecting when reading fast CAN buses.
I will install diagnostic/auto repair programs, and select diagnostic/chip tuning equipment.
Aleksey-MS est déconnecté   Réponse avec citation
The Following User Says Thank You to Aleksey-MS For This Useful Post:
joel_191 (03/08/2026)
