Vieux 14/09/2026, 08h33
jupteck
Avatar de jupteck
jupteck will become famous soon enough
Envoyé par zoubirna Voir le message
Hello everyone,
I need some help with a 1997 Toyota Land Cruiser KZJ95, 1KZ-TE.
The original engine ECU was stolen, so I no longer have it.
The vehicle still has the original immobilizer box, antenna and key/transponder.
I have another ECU with the following references:
Toyota: 89661-60540
Denso: 175800-1703
Engine: 1KZ-TE
Connectors: 26P / 16P / 22P
The vehicle has the older DLC1 diagnostic connector in the engine bay, not OBD2/DLC3.
I know that on some Toyota models with OBD2, there is a procedure to synchronize the ECU and immobilizer by bridging two pins on the OBD2 connector (for example pins 4 and 13).
However, my vehicle has DLC1, and I cannot find the equivalent two pins/procedure for this system. I don't want to assume that the OBD2 4–13 procedure applies to this vehicle.
I would like to know what options I have to make this replacement ECU work with the vehicle.
Option 1 – Immobilizer synchronization:
Is there a specific procedure using the DLC1 diagnostic connector to register/synchronize this replacement ECU with the original immobilizer box? If so, which pins should be connected and what is the exact procedure?
Option 2 – Immobilizer OFF:
If synchronization is not possible because I don't have the original ECU, is it possible to modify this 89661-60540 / Denso 175800-1703 ECU to disable the immobilizer?
If IMMO OFF is possible, I would also like to know which EEPROM/memory contains the immobilizer data and what programming method is normally used.
I have experience working with ECUs and EEPROM programmers, so technical information about the ECU, memory location, procedure, or required tools would be very helpful.
Thank you in advance for any help or technical information.
try this one
Type de fichier : jpg a3037938c56a4c40002799c094a3c8f3.jpg (28,7 Ko, 13 affichages)
jupteck est déconnecté   Réponse avec citation
