Vieux 17/09/2026, 21h00
Aleksey-MS
Avatar de Aleksey-MS
Pouvoir de réputation: 46
Aleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond repute
Par défaut Peugeot & Citroen Dealer Diagnostics: PSA Diagbox VMware Images & Player
Software Information:
PSA Diagbox is a comprehensive dealer-level diagnostic software for Peugeot and Citroen vehicles. It allows you to perform fault code reading, clearing, live data monitoring, and electronic module programming.
- PSA Diagbox 9.129 (VMware Image) - Pre-configured virtual machine (recommended for newer car models).
- PSA Diagbox 9.68 04.2020 (VMware Image) - Pre-configured virtual machine.
- VMWare Workstation Pro Player v15.5.6
- Instructions.txt - Step-by-step setup guide on how to load and run the virtual machines correctly.
Supported Vehicles:
Almost all Peugeot and Citroën models from 1995 to 2020-2022 are supported (for Diagbox 9.xx versions).
Peugeot:
Passenger cars: 106, 107, 108, 206, 206+, 207, 207+, 208 (I & II), 301, 306, 307, 308 (I, II & III), 406, 407, 408, 508 (I & II), 607.
SUVs & Crossovers: 2008 (I & II), 3008 (I & II), 4007, 4008, 5008 (I & II).
Minivans & Coupes: 806, 807, 1007, RCZ.
Commercial vehicles: Bipper, Partner, Rifter, Expert, Traveller, Boxer.
EVs & Hybrids: iOn, Partner Electric, e-208, e-2008.
Citroën:
Passenger cars: AX, Saxo, C-Zero, C1 (I & II), C2, C3 (I, II & III), C3 Pluriel, C4 (I, II & III), C4 Cactus, C5 (I, II, III / Tourer), C6, C-Elysée.
Crossovers: C3 Aircross, C4 Aircross, C5 Aircross, C-Crosser.
Minivans: Xsara, Xsara Picasso, C3 Picasso, C4 Picasso / Grand C4 Picasso (SpaceTourer), C8.
Commercial vehicles: Nemo, Berlingo, Jumpy / SpaceTourer, Jumper.
Supported Diagnostic Interfaces:
- Lexia 3 / PSA XS Evolution (Full Chip): The main and mandatory scanner for full operation. A dual-board Full Chip version with Revision C is required (serial number 921815C in PSA Interface Checker). Must have NEC/Tokakin relays, HCPL optocouplers, and original MCU. (Lite versions/Revision B do not work correctly with 9.xx).
- Actia PSA Core XS / XS 2G: Original new generation dealer multiplexer.
- VXDIAG VCX-SE PSA or similar, and doesn't work with J2534 Pass-Thru VCI
Important Technical Notes:
- Boxer III / Jumper III / Bipper / Nemo: These models are built on a FIAT platform. A standard Lexia 3 cable will only read the Engine and ABS. For full diagnostics (BSI, airbags, dashboard), an additional S.1279 adapter module is strictly required.
- Telecoding limitations: Offline diagnostics, live data, and error clearing work perfectly on all vehicles up to 2020-2022. However, deep telecoding/configuration on fresh vehicles (produced after 2016-2017) was moved to PSA online servers and requires an official dealer token.
- Older models (pre-2000): Vehicles like the 106, 306, Saxo, and AX use older 2-pin or round 30-pin diagnostic connectors. A standard 16-pin OBD2 cable will not physically connect without specific vintage adapters.
- VMware First Run: When launching the virtual machine for the first time, ALWAYS click "I Moved It" (never "I Copied It"), otherwise software activation will fail. Make sure to connect the Lexia USB interface to the guest VM (VM -> Removable Devices).
Need it? Push button Thanks, PM for pass | or by email right now.
I will install diagnostic/auto repair programs, and select diagnostic/chip tuning equipment.
Aleksey-MS est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to Aleksey-MS For This Useful Post:
cabsax (20/09/2026), Farouest (17/09/2026)
