Vieux 19/09/2026, 13h48
Aleksey-MS
Avatar de Aleksey-MS
Pouvoir de réputation: 46
Aleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond repute
Par défaut Official PSA Stellantis Diagbox: Complete Dealer Diagnostics & Pro Coding
Software Information:
PSA Diagbox is a comprehensive dealer-level diagnostic program for diagnosing, coding, and adapting PSA Group (now Stellantis) vehicles.
Included versions (native install files):
- PSA Diagbox 9.268
Supported Vehicles (Up to new Stellantis platforms):
Peugeot:
Passenger cars: 106, 107, 108, 206, 206+, 207, 207+, 208 (I & II, incl. e-208), 301, 306, 307, 308 (I, II & III), 406, 407, 408, 508 (I & II), 607.
SUVs & Crossovers: 2008 (I & II, incl. e-2008), 3008 (I & II, Hybrid4 / e-DCS6), 4007, 4008, 5008 (I & II).
Minivans & Coupes: RCZ, 1007, 806, 807.
Commercial vehicles: Bipper*, Partner, Rifter, Expert, Traveller, Boxer*.
EVs & Hybrids: iOn, Partner Electric, e-Rifter, e-Expert, e-Traveller.
Citroën:
Passenger cars: AX, Saxo, C-Zero, C1 (I & II), C2, C3 (I, II & III), C3 Pluriel, C-Elysée, C4 (I, II & III, incl. C4 X), C4 Cactus, C5 (I, II, III / Tourer, incl. C5 X), C6.
Crossovers: C3 Aircross, C4 Aircross, C5 Aircross, C-Crosser.
Minivans: Xsara, Xsara Picasso, C3 Picasso, C4 Picasso / Grand C4 Picasso (SpaceTourer), C8.
Commercial vehicles: Nemo*, Berlingo, Jumpy / SpaceTourer, Jumper*.
EVs & Hybrids: Ami, e-C4, e-Berlingo, e-SpaceTourer, e-Jumpy.
DS Automobiles:
DS 3, DS 3 Crossback, DS 4 (I & II), DS 4S, DS 5, DS 5LS, DS 6, DS 7 Crossback, DS 9.
Opel / Vauxhall (PSA/Stellantis platforms ONLY):
Corsa F (incl. Corsa-e), Astra L, Mokka B (incl. Mokka-e), Crossland / Crossland X, Grandland / Grandland X, Combo E, Vivaro C, Zafira Life, Rocks-e.
Supported Diagnostic Interfaces:
- Actia Lexia 3 (XS Evolution Full Chip Revision C) or a high-quality clone. Must have original NEC/Tokakin relays, HCPL optocouplers, and a proper MCU. Lite versions or Revision B do not work correctly with 9.xx software.
Important Technical Notes:
- Boxer III / Jumper III / Bipper / Nemo: These models are built on a FIAT platform. A standard Lexia 3 cable will only read the Engine and ABS. For full diagnostics (BSI, airbags, dashboard), an additional S.1279 adapter module is strictly required.
- Telecoding limitations & SGW: Offline diagnostics, live data, and error clearing work perfectly on all vehicles. However, deep telecoding, module pairing, and configuration on fresh vehicles (especially those with Security Gateway - SGW) are factory-locked and require an official Stellantis online token.
- Older models (pre-2000): Vehicles like the 106, 306, Saxo, and AX use older 2-pin or round 30-pin diagnostic connectors. A standard 16-pin OBD2 cable requires a specific vintage adapter.
Need it? Push button Thanks, PM for pass | or by email right now.
I will install diagnostic/auto repair programs, and select diagnostic/chip tuning equipment.
Aleksey-MS est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to Aleksey-MS For This Useful Post:
ldevent59 (25/09/2026), Scanworld2020 (21/09/2026)
