Vieux 01/10/2026, 17h29
a3pughjolu
Avatar de a3pughjolu
Pouvoir de réputation: 22
a3pughjolu has much to be proud ofa3pughjolu has much to be proud ofa3pughjolu has much to be proud ofa3pughjolu has much to be proud ofa3pughjolu has much to be proud ofa3pughjolu has much to be proud ofa3pughjolu has much to be proud ofa3pughjolu has much to be proud ofa3pughjolu has much to be proud ofa3pughjolu has much to be proud of
Envoyé par matt978 Voir le message
ci joint le dump de la 93c06 du boitier airbag
est ce que quelqu'un peut y regarder merci?
Salut Matt
Es ce que tu a essayé de mettre directement ta resistence sur les pins, pour eliminer probleme faisceau...
Aider et etre Aidé Pas de Thanks Pas de réputation Plus d'aide
The Following User Says Thank You to a3pughjolu For This Useful Post:
matt978 (01/10/2026)
