Carly Pro Mobile Diagnostics Mega Pack: All Brands, VAG, MB & Renault
WHAT INSIDE:
- Carly+v49.77+Unlocked.apk
- Carly for VAG_19.03.apk
- Carly for Mercedes_19.03.apk
- Carly for Renault_19.02.apk
DESCRIPTION:
Carly is the most powerful tool for mobile devices designed for car diagnostics, coding, and maintenance. This Mega Pack contains the fully unlocked universal application for all major car brands, as well as dedicated Pro versions optimized specifically for VAG, Mercedes-Benz, and Renault.
1. CARLY PRO ALL CAR BRANDS (UNLOCKED)
Supported car brands: Audi, BMW, Lexus, Mercedes, Mini, Porsche, Renault, Seat, Skoda, Toyota, and VW. Every car is unique, so specific features will vary with every model, build year, hardware, and software.
CHECK THE CAR’S HEALTH AND SAVE MONEY: Read from all built-in electronic control units (ECUs), including engine, transmission, ABS, airbag, & multimedia. Gauge the severity of problems and clear fault codes.
MONITOR LIVE DATA: Live parameters help you take the guesswork out of understanding what your car needs and detect fault origins.
CODE AND CUSTOMIZE FEATURES: Access hidden features already set by the manufacturer and customize your car.
PERFORM SIMPLE CAR MAINTENANCE: Analyze emission and engine gauges, change and register your car battery, perform an oil reset, and much more, all with your smartphone.
DETECT MILEAGE MANIPULATION: Use Carly to perform a used car inspection before buying to avoid getting tricked.
2. CARLY VAG PRO FULL
Capable of working with VW, Audi, Seat, and Skoda since 1996.
- Coding: get access to the hidden features!
- Parameters: analyze engine parameters like a real professional!
- Check battery: replace the battery and register your car yourself!
- Service interval reset: be independent from your workshop!
- Soot filter: Turn on the regeneration of the soot filter with a single tap!
3. CARLY PRO MERCEDES-BENZ
The most powerful mobile tool that has been able to work with Mercedes cars since 2004.
4. CARLY RENAULT FULL PRO
Contains an unlimited license for health checks of all supported models. Includes Android diagnostics, coding, and real mileage check. Future updates for diagnostics-quality and all further functions like finding and clearing fault codes, full descriptions, and fault reports are included.
HARDWARE REQUIREMENTS:
To connect you need an OBD-II Bluetooth adapter (e.g., ELM327) or a K-DCAN cable. Recent versions work best with the original Carly device. The program receives all the information via the OBD2 interface.
HOW TO INSTALL:
1. Install the APK program.
2. Run the application.
3. Write any email.
4. Write any password.
Disclaimer: I provide links to APK files that I do not test myself. These should be full versions, but sometimes this is not the case.
Need it? Push button Thanks, PM for pass | or by email right now.
