23/10/2026, 13h14
Envoyé par Aleksey-MS
Carly Pro 48.03 + 90.36 beta All Car Brands (phone diagnostics)
These are supported by the following car brands: Audi, BMW, Lexus, Mercedes, Mini, Porsche, Renault, Seat, Skoda, Toyota, and VW. Every car is unique, so specific features will vary with every model, build year, hardware, and software.
Check the car’s health and save money
With Carly car diagnostics, you’ll have the right scanner tool to read from all built-in electronic control units (ECUs), including engine, transmission, ABS, airbag, & multimedia, keep track of your car’s health, gauge the severity of problems, clear fault codes, and more.
Monitor live data
Live parameters or live data can help you take the guesswork out of understanding what your car needs and detect the fault origins.
Code and customize features
Access hidden features already set by the manufacturer and customize your car to fit your needs. This feature is only available on certain car brands/models, and the coding options vary.
Perform simple car maintenance independent of the workshop
Analyze emission and engine gauges, change and register your car battery, perform an oil reset, and much more, all with your smartphone.
Detect mileage manipulation
Car mileage manipulation is on the rise. Don’t get tricked. Use Carly to perform a used car inspection before buying.
Recent versions only work with the original Carly device.
Need it? Push buttons Rate (Reputation) and Thanks, PM for pass.
