Vieux 27/04/2013, 02h06
tony76
Avatar de tony76
Pouvoir de réputation: 29
tony76 has much to be proud oftony76 has much to be proud oftony76 has much to be proud oftony76 has much to be proud oftony76 has much to be proud oftony76 has much to be proud oftony76 has much to be proud oftony76 has much to be proud oftony76 has much to be proud of
tu n'as qu'un fil a passer de ta pedale a ton calculo l'alim est commune au 3 capteurs donc repicage de l'alim et envoie de l'info au calculo moteur au final sois tu change ton capteur pour un double contact ou tu schinte par un relais
Tony76
tony76 est déconnecté   Réponse avec citation
