Vieux 29/06/2013, 04h24
electronicscars
Avatar de electronicscars
electronicscars has a spectacular aura aboutelectronicscars has a spectacular aura aboutelectronicscars has a spectacular aura about
Par défaut dump BANK 1 AND 2 for st flasher for FIAT whit marelli iaw 4ASF,4SD,4GF
this file is stflasher format to make a boot pin and flasher whit ecu in table of work in next post i atach the interface and the soft to run whit this file to virginise these ecu's , after you mount the ecu in the car and it learns: bsi inmo code, the throttle buterfly in ralenti and wot , and Accelerator Pedal Electronic position in minimun position .after you turn off ignition and the ecu turn in power latch to lear the values in the intern flasch memori
you can use a used ecu in other car if you virginise these after whit this
Type de fichier : rar IAW 4SF 4SD 4GF reset immo bloques 1 y 2.rar (1,5 Ko, 21 affichages)
electronicscars est déconnecté   Réponse avec citation
The Following 4 Users Say Thank You to electronicscars For This Useful Post:
dell 66 (29/06/2013), hout31 (19/05/2014), mahfoud lichani (29/06/2013), milerk (30/08/2013)
