Discussion: airbag polo 2004
Vieux 14/10/2013, 12h50
nimbus
Avatar de nimbus
Pouvoir de réputation: 73
nimbus has a reputation beyond reputenimbus has a reputation beyond reputenimbus has a reputation beyond reputenimbus has a reputation beyond reputenimbus has a reputation beyond reputenimbus has a reputation beyond reputenimbus has a reputation beyond reputenimbus has a reputation beyond reputenimbus has a reputation beyond reputenimbus has a reputation beyond reputenimbus has a reputation beyond repute
re je pense que ta pas compris avec le carprog ta une procedure qui s'appelle diag
qui est au dessus du direct mais tu le fait sur etabli tu branche ton +12v normalement pin 26 ta masse pin 51 et ton kline pin 54
ou tu efface direct ton crash ou tu fait un read fault memory
l'emplacement est celon ta ref si tu arrive pas post ta ref
nimbus est connecté maintenant   Réponse avec citation
The Following 2 Users Say Thank You to nimbus For This Useful Post:
h'mida13 (14/10/2013), MecaTech (17/10/2013)
