Discussion: mettre en immo off
Vieux 25/10/2013, 17h21
abdel_ren
Avatar de abdel_ren
abdel_ren has a spectacular aura aboutabdel_ren has a spectacular aura aboutabdel_ren has a spectacular aura about
1- Disconnect and Open ECU.
2- Disolder eeprom flash 29f400.
3- Solder a support PLCC adaptator.
4- Write on a new eeprom the file that is in this
folder and put the eeprom temporarely in this ECU.
5- Put back ECU in the car and turn ignition on for a 30 seconds
6- Substitute the new eeprom with the original eeprom again.
7- In order for the car not to block immo identify the pin 48 and cut the path.
8- By doing the following steps the ECU will be totally unblocked.
If you have problem after this operation cut the wire on ECU pin 48 (immobilzer).
abdel_ren est déconnecté   Réponse avec citation
The Following User Says Thank You to abdel_ren For This Useful Post:
nabrayane (25/10/2013)
