Vieux 16/12/2013, 15h52
karera 1
Avatar de karera 1
karera 1 has much to be proud ofkarera 1 has much to be proud ofkarera 1 has much to be proud ofkarera 1 has much to be proud ofkarera 1 has much to be proud ofkarera 1 has much to be proud ofkarera 1 has much to be proud ofkarera 1 has much to be proud ofkarera 1 has much to be proud of
salut pour infos les fg tech clone decone au niveau du cable alimentation il faut debrancher et rebrancher il se produit un petit clic comme un relais au niveau du boitier et la tension en voltage s'initialise !
parfois la solution au probleme et dans la question !
karera 1 est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to karera 1 For This Useful Post:
MecaTech (16/12/2013), vortex (16/12/2013)
