En complément de mon précédent message j'ai retrouvé ceci sur un forum US
During the installation of PROGMAN SSS you need to install a changes*.iso file to tell the software what type of interface you are using. Have a look at Randomy's instructions. Installation of the correct changes file is one of the last steps. Alternatively, Dracon has posted information on how to modify the installation so that you can select the type of interface you need after the software has been installed. For example, if you were working on a car that required an EDIC inteface, you would use changes_v2.iso, for your car, use SSS_Full_Start.iso, for a DCAN car, use Changes_By_XDrive_v2.iso etc...
