Discussion: ios terminal
Vieux 02/01/2014, 07h27
amourh59
Avatar de amourh59
Pouvoir de réputation: 22
amourh59 is a splendid one to beholdamourh59 is a splendid one to beholdamourh59 is a splendid one to beholdamourh59 is a splendid one to beholdamourh59 is a splendid one to beholdamourh59 is a splendid one to beholdamourh59 is a splendid one to behold
Envoyé par Meziane93 Voir le message
Peut être mais en tous cas il est capable de gérer une dae de clio et modus par obd
bonjour l' I/O TERMINAL est pour psa , il prend en charge
SUPPORTED ECU LIST:
DAEWOO SIEMENS/KEMSCO D3
OPEL SIMTEC 71.1
OPEL SIMTEC 75.5
Land Rover Siemens SID201
Jaguar Siemens SID204
VAG Siemens SIMOS 6.2
VAG Siemens SIMOS 7.1
VAG Siemens SIMOS 7.1A
Ford Siemens SIM210 ECU Tool
Ford Siemens SIM22 ECU Tool
Ford Siemens SIM24 ECU Tool
Ford Siemens SIM28 ECU Tool
Ford Siemens SIM29 ECU Tool
Ford Siemens SID802 ECU Tool
Ford Siemens SID803 ECU Tool
Ford Siemens SID803A ECU Tool
Ford Siemens SID804 ECU Tool
Volvo Siemens SID803 ECU Tool
Volvo Siemens SID803A ECU Tool
PSA ECU Detect
PSA Siemens SID 201
PSA Siemens SID 801 ECU Tool
PSA Siemens SID 801A ECU Tool
PSA Siemens SID 802 ECU Tool
PSA Siemens SID 803 ECU Tool
PSA Siemens SID 803A ECU Tool
PSA Siemens SID 804 ECU Tool
PSA Siemens SID 805 ECU Tool
PSA Siemens SID 806 ECU Tool
attention il faut recalculer le cheksum pour les carto
pour la DAE il faut utiliser : Renault CAN/K-line ECU Tool
il prend en charge :
EDC15C3 (both CAN-BUS and WIRE immo systems) - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
EDC15C13 - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
SIRIUS 32[N] (both CAN-BUS and WIRE immo systems) - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
SIRIUS 34 (both CAN-BUS and WIRE immo systems) - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
SIRIUS 35 - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
EMS3132 (both CAN-BUS and WIRE immo systems) - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
EMS3134 (both CAN-BUS and WIRE immo systems) - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
SID301 - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code, Clear IMPACT DETECTED, Read stored mileage
SIM32 - Read/Write EEPROM, Read/Write FLASH from HD64F7055, Clear Immo Code (NEW!)
SAFIR / SAFIR2 / SFR200 (35 / 55 pin connector) - Read TMS374 EEPROM, Clear Immo Code (car runs without immobilizer code)
IAW 6R.20 - Read/Write TMS370 EEPROM
IAW 6R.30 - Read TMS370 EEPROM, Clear Immo Code (car runs without immobilizer code)
VALEO BII for ESPACE Mk3 - Read/Write (9)08AZ60 EEPROM, Read/Write mileage, Clear for Replacement
SIEMENS UCH for MEGANE/SCENIC ('98-'02) - Read/Write 705B32 EEPROM, Read/Write configuration, Learn Keys
LAGUNA II, ESPACE IV, VELSATIS, LAGUNA II Ph2, ESPACE IV Ph2, VELSATIS Ph2 - KeyCard Programming
MEGANE II, SCENIC II, MEGANE II Ph2, SCENIC II Ph2 - KeyCard Programming
INSTRUMENT CLUSTER for SCENIC II ('04-'08) - Wake-Up by CAN-BUS for repair or to check a mileage
CLIO II Ph2, KANGOO, TRAFIC, MASTER, VIVARO, MOVANO (-'06) - Read/Write EEPROM 93C66, Key Programming
MODUS / CLIO III ELECTRIC POWER ASSISTED STEERING (TRW DAE/PAS) - Clear Immo Code by OBDII
pour la dae modus et clio il fait que verginisé l'ecu donc je ne saie pas si on peut lire , édité, écrire l'eprom !
amourh59 est déconnecté   Réponse avec citation
The Following User Says Thank You to amourh59 For This Useful Post:
MecaTech (02/01/2014)
