Vieux 26/01/2014, 00h48
Meziane93
Avatar de Meziane93
Pouvoir de réputation: 29
Meziane93 has much to be proud ofMeziane93 has much to be proud ofMeziane93 has much to be proud ofMeziane93 has much to be proud ofMeziane93 has much to be proud ofMeziane93 has much to be proud ofMeziane93 has much to be proud ofMeziane93 has much to be proud ofMeziane93 has much to be proud of
Mon ami il va te falloir aux mieux un pp2000 ensuite un programmateur pour recuperer ton pin dans l ecu ou pour le reinjecter, flasher ta bsi pour la faire repartir sur de nouvel base (telecodage) ou bien un bon immo off que tu injectes sur le 29f mais cela ne solutionnera pas ton probleme juste un depannage si tu as besoin je t aiderais
Meziane93 est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to Meziane93 For This Useful Post:
khalil84 (03/03/2024), planglais (26/01/2014)
