Vieux 26/01/2014, 00h57
Meziane93
Avatar de Meziane93
Pouvoir de réputation: 29
Meziane93 has much to be proud ofMeziane93 has much to be proud ofMeziane93 has much to be proud ofMeziane93 has much to be proud ofMeziane93 has much to be proud ofMeziane93 has much to be proud ofMeziane93 has much to be proud ofMeziane93 has much to be proud ofMeziane93 has much to be proud of
Donc si je reprend le debut du probleme tu as une chute de tension sur le 5volt alors ce que tu dois faire c debranche tous les capteurs qui font pas demarre ta voiture c a dire tu laisses le pmh aac et pression rail tout le reste tu debranches evidemment controle l hygiene de tes prises et faisceau au passage et tu est ayant deja eu le pblm ct le capteur temperature de carburant hs voila a toi de jouer
Meziane93 est déconnecté   Réponse avec citation
The Following User Says Thank You to Meziane93 For This Useful Post:
bricol (26/01/2014)
