27/01/2014, 23h49
Pouvoir de réputation: 182
En plus précis :
Autocom 2013.3 CLEANING OLD FILES OF PREVIOUS version Autocom:
WINDOWS XP:
1. Before start new installation of Autocom, first DEINSTALL OLD version of Autocom
2. Find and MANUAL DELETE this files
C:\Programs\Autocom\
C:\Documents and Settings\All Users\Application Data\Autocom\
C:\Documents and Settings\**USER**\Application Data\Autocom\
C:\Documents and Settings\**USER**\Application Data\Microsoft\SystemCertificates\My
C:\Documents and Settings\Default User\Application Data\Microsoft\SystemCertificates\My
C:\Documents and Settings\LocalService\Application Data\Microsoft\SystemCertificates\My
C:\Documents and Settings\NetworkService\Application Data\Microsoft\SystemCertificates\My
3. Open and "Edit" function via Notepad:
C:\WINDOWS\system32\drivers\etc\hosts
then DELETE:
127.0.0.1 activation.autocom.se
127.0.0.1 activation2.autocom.se
127.0.0.1 updates.autocom.se
then via command "Save" you save new editing Notepad files.
NOW YOU WILL HAVE "UPDATE" FROM INTERNET !
4. Run CCleaner and delete registar files.
5. Restart PC.
6. Finally, start install new Autocom 2013.3 version
7. After finish installing, run "AutocomDelphiPatch.exe"
8. Start Autocom, go to activation, klik on "Start"..and little wait , then you see of Autocom "Main screen"
__________________________________________________ _________________________
WINDOWS 7 & 8:
1. Before installing the new version 2013.1, first uninstall previous versions
If we have installed 2013.1 + we have the "error" after clicking on "start" activation , then "operation failed" you must:
2. Delete the following folders:
C:\Programsx86\Autocom\
C:\Programsx86\Delphi\
C:\users\**USERNAME**\AppData\Roaming\Delphi\
C:\users\**USERNAME**\AppData\Roaming\Autocom
C:\users\**USERNAME**\AppData\Roaming\Microsoft\Sy stemCertificates\My
3. Now we can start the first time delphi or autocom with or without internet connection. Same result.
