Vieux 30/01/2014, 23h50
Meziane93
Avatar de Meziane93
Pouvoir de réputation: 29
Meziane93 has much to be proud ofMeziane93 has much to be proud ofMeziane93 has much to be proud ofMeziane93 has much to be proud ofMeziane93 has much to be proud ofMeziane93 has much to be proud ofMeziane93 has much to be proud ofMeziane93 has much to be proud ofMeziane93 has much to be proud of
Par défaut Classe a 140 essence demarre et cale
BONSOIR JE VOUS EXPLIQUE MON PROBLEME DONC J AI UNE CLASSE A 140 DE 1999 QUI A EU UN PROBLEME DE DEBITMETRE D AIR LE CALCULOMOI JE DESSOUDE LE FLASH POUR LE REMETTRE SUR UN AUTRE LE SOUCI QU IL Y A C EST QU ELLE DEMARRE ET ELLE S ETEIND SI ONT TIENS PAS LE PIED SUR L ACCELERATEUR IL Y A COMME UNE COUPURE D UN RELAIS QUI COUPE L ALIMENTATION ELECTRIQUE DE LA VOITURE DU COUP LA POMPE S ARRETE DE FONCTIONNER LE TEMP DE CET COUPURE ET REMARCHE AUSSITOT QUE LE JUS REVIENT EST CE QUE CELA PEUT VENIR DU CALCULO MERCI DE VOS REPONSES
Meziane93 est déconnecté   Réponse avec citation
