Discussion: probleme abs megane 3
Vieux 04/02/2014, 12h51
purpleskull
Avatar de purpleskull
purpleskull is an unknown quantity at this point
sounds like his pump is failing try to do a segment test on your abs pump if you cannot do this try to manually check the fuses .if all elese fails try +checking the leads from the ecu for voltage see if its getting power,if theres power and motor is not pumping pump is bad get new one.
purpleskull est déconnecté   Réponse avec citation
