Vieux 06/02/2014, 13h33
fedge
Avatar de fedge
Pouvoir de réputation: 30
fedge has much to be proud offedge has much to be proud offedge has much to be proud offedge has much to be proud offedge has much to be proud offedge has much to be proud offedge has much to be proud offedge has much to be proud offedge has much to be proud offedge has much to be proud of
Pour que le calculateur démarre en boot mode il faut que la patte 24 de l' af29...soit reliée a la masse a travers une résistance de 470 ohms ( pas au dessus) au moment ou tu branches l' alimentation 12v. Au bout de quelques secondes tu supprimes cette mise a la masse ( sans couper l' alim) , et çà démarre......
fedge est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to fedge For This Useful Post:
jope (06/02/2014), jpay2 (06/02/2014)
