Vieux 15/02/2014, 14h40
tony76
Avatar de tony76
Pouvoir de réputation: 29
tony76 has much to be proud oftony76 has much to be proud oftony76 has much to be proud oftony76 has much to be proud oftony76 has much to be proud oftony76 has much to be proud oftony76 has much to be proud oftony76 has much to be proud oftony76 has much to be proud of
avant otutes choses essaie de te procurez un LEXIA ou PP2000 pour faire un vrai diag , apres sur ce modele controle le faisceau calculateur il passe au dessus du support moteur (coté distrib) la gaine froppe et abime le faisceau ! , apres controle les alims calculateur , mais a ce que tu me dis ca ressemble a un probleme de relais double il te sert pour ta pompe de gavage et alimente le calculo !
affaire a suivre
Tony76
tony76 est déconnecté   Réponse avec citation
